Polyline
Create a polyline to be used either as a building block for constructing geometry or as a wire.
Polylines consist of consecutive straight lines and result in mesh vertices being created at each corner. The lines of a polyline should not cross itself, but if this is required, the polygon can be sub-divided.
On the Construct tab, in the Create curve group, click the|
Corner 1 (C1) | The first point of the polyline. |
| Corner 2 (C2) | The second point of the polyline. | |
| ...Corner n (Cn) | Additional points in the polyline. There may be an arbitrary number of points. |
