ADAPTFEKO Options
Specify ADAPTFEKO command-line parameters using the GUI.
Restart analysis number
This option can be used if the run was discontinued and the temporary files were not deleted. Restart the solution at the number of the first incomplete simulation.
Delete temporary files
This option allows you to delete the temporary files created during the ADAPTFEKO run.
