Feko Components and Workflow
View the typical workflow when working with the Feko components.
CADFEKO
Create or modify the geometry (or model mesh) in CADFEKO, import geometry or mesh, or use a component from the component library. Apply solution settings, define the frequency, specify the required sources and request calculations. Mesh the model to obtain a discretised representation of the geometry or model mesh. Validate the model using the CEM validate tool to ensure the model is correct. If any warnings or errors are given, correct the model before running the Solver.
Solver
Run the Solver to calculate the specified output requests.
POSTFEKO
Create a new graph or 3D view and add results of the requested calculations on a graph or 3D view. Results from graphs can be exported to data files or images for reporting or external post-processing. Reports can be created that export all the images to a single document or a custom report can be created by configuring a report template.
After viewing the results, it is often required to modify the model again in CADFEKO and then repeat the process until the design is complete.
