Cylinder
Create and edit a cylinder or a cone.
A cone is a modified cylinder with a top or bottom diameter of 0.
Create a Cylinder or a Cone
Create a cylinder. You can then create a cone by changing the top or bottom diameter to 0.
Edit a Cylinder or a Cone
Resize the cylinder or cone, change the sweep angle, lock or unlock the radius ratio, and add or remove caps.
Manipulate the Shape of a Cylinder
Select a degree option and then reposition or change the number of the control points in order to manipulate the shape.
If you want to manipulate the shape, select one of the degree options.
Figure 1. Exact
