Set conditions under which the process can continue.
If Tasks allow setting conditions under which the process can continue. The variables
need to be created prior to defining the condition.
The example below shows two variables: Critical Mass and Mass with their expression
name M and M0.
The mass is extracted by the previous task Mass Extraction and passed on to the If
task as variable Mass[M]. The If task sets the condition M<M0. Whereas the value
for M0 is given by you. If the condition is true, Pulse will execute the task
Truebranch or else it will execute the task Falsebranch. Figure 1.
The If condition is using OLM statements. The following conditions are supported:
