Determine what is made visible in the modeling window when viewing analysis results. You can show or hide the initial
shape, loads and supports, deformation, and/or contours.
Run a 3D Print Analysis
Run an additive manufacturing simulation for the selcted print parts.
View Print3D Results
View, animate, and plot the results of a 3D printing analysis.
Animate and Record Results
If you've previously run a 3D printing analysis, use the Animation toolbar to animate and record the results.
Show Options
Determine what is made visible in the modeling window when viewing analysis results. You can show or hide the initial shape, loads and supports, deformation, and/or contours.
Add Callouts to Results
Create callouts for selected result types at points of interest on your model.
Plot Print3D Results
If you've previously run a 3D printing analysis, you can plot the results from the Analysis Explorer.
