Use to run a quick thinning analysis when designing sheet metal parts that are thinned from flat blanks. Then interactively
view the results using the Analysis Explorer.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
Set up and view the results of a simple thinning analysis for stamping.
Run Analysis
Use to run a quick thinning analysis when designing sheet metal parts that are thinned from flat blanks. Then interactively view the results using the Analysis Explorer.
Analysis Explorer
Use to view the results of a thinning analysis. You can view thinning percentage, formability, and thickness results for a selected run and load case.
Run Status
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past runs, you need to view the run history.
Run History
View, sort, open, and delete past runs for the current and previous models.
