Use to view the results of a porosity analysis. You can view shrinkage percentage, temperature evolution, solid fraction,
and solidification times for a selected run and load case.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
Set up and view the results of a simple porosity analysis for casting.
Run Analysis
Use to run a quick porosity analysis when designing metal parts that are casted. Then interactively view the results using the Analysis Explorer.
Analysis Explorer
Use to view the results of a porosity analysis. You can view shrinkage percentage, temperature evolution, solid fraction, and solidification times for a selected run and load case.
Run Status
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past runs, you need to view the run history.
Run History
View, sort, open, and delete past runs for the current and previous models.
