Orientation
Orient the part in relation to the printing bed.
There are several orientation methods available:
- Optimize Orientation: Optimize the orientation of the print part to minimize print time, supports, and/or deformation.
- Max Build Height: Maximize the build height for efficient printing and cooling.
- Min Build Height: Minimize the build height to achieve the shortest printing time.
- Surface Orient the print part in relation to a surface on the part.
Optimize the orientation of the print part to minimize print time, supports, and/or deformation. You can also orient the part based on a weighted average of all three factors.
Maximize or Minimize Build Height
Maximize the build height for efficient printing and cooling, or minimize the build height to achieve the shortest printing time.
Click the Orientation
icon.
Select an orientation method.
- Click the Max Build Height
icon to maximize the build height for efficient printing and cooling. This orientation protects the part from cooling deformations, ensuring that the part prints according to design and build dimensions.
- Click the Min Build Height
icon to minimize the build height to achieve the shortest printing time.
- Enter a Distance in the Orientation table to configure the distance between the part and printing bed. The minimum distance is 0.002 m.
Optional: In the Orientation table, click the Save icon
to save the orientation.
Orient the Print Part to a Surface
icon.
Click the Surface
icon and then select a surface on the part. The selected surface will be rotated to face the printing bed with its normal oriented toward gravity.
Save an Orientation
Use the Orientation table to save the orientation of the print part .
- For surfaces on the part with angles of less than 45 degrees, support is
required. These areas are shown in yellow and update automatically as the
part is rotated using the Move
tool.
- If the part accidentally extends outside of the printing bed, select the Move Inside option on the Orientation table to place it inside of the printing bed.
- By default, undercuts are only shown in yellow when the Orientation tool is active. Enabling the Retain Undercuts option on the Orientation table makes the undercuts visible when using other tools. This is useful when you are modifying the geometry and want to see how the undercuts change as a result.
- If you rotate the part or create new orientations, the Current orientation values at the bottom of the table update automatically. Select a row in the Orientation table to restore that orientation.
