/SURF/BOX/EXT or /SURF/BOX2/EXT
Block Format Keyword Describes the surfaces which are inside the box (exclude inner segments).
| /SURF/BOX/EXT/surf_ID/unit_ID or /SURF/BOX2/EXT/surf_ID/unit_ID | |||||||||
| surf_title | |||||||||
| box_ID | |||||||||
| surf_ID | Surface
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| surf_title | Surface
| box_ID | Box identifier, which is
defined in Boxes (Integer, maximum 10 digits) |
- The format is the same as the corresponding options /SURF/type/surf_ID.
- Input format for
BOX:
- The external faces are built from all solids (the inner faces are not considered).
- The segments built from 3-node and 4-node shells are still selected the same way as with /SURF/type/surf_ID and segments from inside of volumic parts (inner segments) will also be excluded.
- If type is
BOX, all segments supported by solids, shells and 3-node
shells with all nodes inside the box or on its external surface are selected
(segments lying on solid elements are not considered).
- If type is BOX2, all segments with at least one node inside the box or on its surface are selected.
