/GRTRIA
Block Format Keyword Describes a group of 3 node solid elements.
Input Type Keywords: 2D Solid Triangle Group
- Keyword
- Input Type
- /GRTRIA/BOX or /GRTRIA/BOX2
- Triangles from box identifiers
- /GRTRIA/GEN_INCR
- Generate list by increment
- /GRTRIA/GENE
- Triangles with generation (identifier range)
- /GRTRIA/GRTRIA
- Triangles using other group identifiers
- /GRTRIA/MAT
- Triangles from material identifiers
- /GRTRIA/PART
- Triangles from part identifiers
- /GRTRIA/PROP
- Triangles from property identifiers
- /GRTRIA/SUBMODEL
- Triangles from submodel identifiers
- /GRTRIA/SUBSET
- Triangles from subset identifiers
- /GRTRIA/TRIA
- /TRIA identifiers
- A 2D solid triangle is a set of /TRIA elements (only). It cannot contain any other type of element.
