/SURF/PART
Block Format Keyword Describes the parts surfaces which belong to given parts.
| /SURF/PART/surf_ID/unit_ID | |||||||||
| surf_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
| surf_ID | Surface
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| surf_title | Surface
| item_ID1, item_ID2, ... item_IDn | List of part identifiers
4 (Integer) |
- All surface segments must belong to 2D elements (shell element or triangular shell element). 1D elements are ignored in /SURF/PART. With 3D elements, an additional keyword must be specified: see /SURF/PART/EXT and /SURF/PART/ALL
- A surface cannot be defined using Madymo surfaces.
- A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
- If item_ID is negative, the surface normals are inverted.
