*CONSTRAINED_EXTRA_NODES
LS-DYNA Input Interface KeywordDefine extra nodes to add to a rigid body.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONSTRAINED_EXTRA_NODES_OPTION | |||||||
| part_ID | node_ID | Iflag |
| part_ID | set_ID | Iflag |
Definition
| OPTION | Entity type.
| part_ID | Part identifier of the rigid body defined as a rigid
material. (Integer) |
| node_ID | Node identifier to add to as a secondary node to the rigid
body. (Integer) |
| set_ID | Node set identifier to add to as a secondary nodes to the
rigid body. (Integer) |
| Iflag | Flag for merged rigid body property (used if part_ID is PART_INERTIA).
(Integer) |
- This keyword maps to /MERGE/RBODY.
