*MAT_034 (FABRIC)
LS-DYNA Input Interface KeywordThis keyword defines an orthotropic elastic material with softening in compression.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_034 or *MAT_FABRIC | |||||||
| mat_ID | E1 | E2 | v12 | ||||
| G12 | G23 | G32 | RE | ||||
| AOPT | |||||||
| A1 | A2 | A3 | |||||
| V1 | V2 | V3 | BETA | ||||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| E1, E2 | Young’s modulus in material directions 1 and
2. (Real) |
| v12 | Poisson’s ratio between directions 1 and 2. Default = 0 (Real) |
| G12, G23, G32 | Shear modulus in corresponding
directions. (Real) |
| RE | Stiffness reduction in compression option.
(Integer) |
| AOPT | Material axis flag.
(Real) |
| A1, A2, A3 | Vector defining first orthotropy direction for AOPT
= 2. (Real) |
| V1, V2, V3 | A vector which in combination with element normal defines the
first orthotropy direction for AOPT =
3. (Real) |
| BETA | Material angle for AOPT =
3,0. (Real) |
- This keyword maps to /MAT/LAW19 (FABRI).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
