*CONSTRAINED_GENERALIZED_WELD_SPOT
LS-DYNA Input Interface KeywordDefine a connection between 2 nodes with a possible force-based failure model.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONSTRAINED_GENERALIZED_WELD_SPOT_{OPTION} | |||||||
| ID | |||||||
| NSID |
| SN | SS | N | M |
Definition
| ID | Weld identifier. (Integer) |
| NSID | Nodal set identifier. (Integer) |
| SN | Normal tensile force at failure. (Real) |
| SS | Normal shear force at failure. (Real) |
| N | Exponent for the normal force. (Real) |
| M | Exponent for the shear force. (Real) |
- This keyword maps to rigid body element (/RBODY) with optional failure.
- Normal and shear directions for each node of spotweld are defined according to direction from node to geometrical COG of the nodes.
- The failure is defined with the following expression:
(1)
