*SET_NODE
LS-DYNA Input Interface KeywordDefines a set of nodes based on a list of nodes in various ways.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SET_NODE_{OPTION} | |||||||
| set_ID | |||||||
| N_ID1 | N_ID2 | N_ID3 | N_ID4 | N_ID5 | N_ID6 | N_ID7 | N_ID8 |
| N_IDB1 | N_IDE1 | N_IDB2 | N_IDE2 | N_IDB3 | N_IDE3 | N_IDB4 | N_IDE4 |
| N_ID1 |
| TYPE | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 |
| ID8 | ID9 | ID10 | ID11 | ID12 | etc |
Definition
| OPTION |
No default |
| set_ID | Node set identifier. (Integer) |
| N_ID1 - N_ID8 | Node IDs, 8 per line. (Integer) |
| N_IDB1 - N_IDB4 | First node ID of the range, 4 ranges per
line. (Integer) |
| N_IDE1 - N_IDE4 | Last node ID of the range, 4 ranges per
line. (Integer) |
| TYPE |
| ID1, ID2, ID3 ... | Entity IDs, 7 per line. (Integer) |
- This keyword maps to /SET/GENERAL.
- The adding and removing of nodes in *SET_NODE_GENERAL depends on the order of the TYPE options used.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
