/ALE/BCS
Block Format Keyword Describes the ALE boundary conditions.
| /ALE/BCS/bcs_ID | |||||||||
| bcs_title | |||||||||
| Grilag | skew_ID | grnd_ID | |||||||
| bcs_ID | Boundary conditions block
identifier. (Integer, maximum 10 digits) |
| bcs_title | Boundary condition block
title. (Character, maximum 100 characters) |
| Grilag | Codes for grid velocity
and Lagrange.
(6 Booleans) |
| skew_ID | Skew
identifier. (Integer) |
| grnd_ID | Node group to which
boundary conditions are applied. (Integer) |
Codes for Grid Velocity and Lagrange: Grilag
| (1)-1 | (1)-2 | (1)-3 | (1)-4 | (1)-5 | (1)-6 | (1)-7 | (1)-8 | (1)-9 | (1)-10 |
| WX | WY | WZ | LX | LY | LZ |
| WX | Code for grid velocity
WX
(Boolean) |
| WY | Code for grid velocity
WY
(Boolean) |
| WZ | Code for grid velocity
WZ
(Boolean) |
| LX | Lagrange code
WX =
VX
(Boolean) |
| LY | Lagrange code
WY =
VY
(Boolean) |
| LZ | Lagrange code
WZ =
VZ
(Boolean) |
- If a node is constraint with ALE boundary conditions and classical boundary conditions (/BCS), both boundary conditions must be set is the same skew system (skew_ID).
- The grnd_ID input is obligatory. The boundary conditions will only be applied to nodes belonging to a node group.
- Detail input format for Grilag is shown above. The three individual codes (one per direction), must be right justified in the ten character fields used by the variable Grilag.
