Manage Subsystems
The Subsystem Browser allows you to organize the model into manageable subsystems to aide model management. Alternatively, it takes existing include model management and extends it to provide representation, revision, and configuration management. Management of subsystem connections should be controlled using Attachments.
Following the model build and assembly best practices, you use the Part Browser to go from CAD to CAE a model of subsystem. Then, you use the Subsystem Browser to create subsystems and assemble a system-level model.
