Export Settings
Export settings for AMF, AVI, H3D, JPEG, and GIF files.
AMF and AVI
- Palette
- Full Color
- Save the image as a 24 or 32 bit uncompressed full color file as it appears on the screen.
- Motion JPEG
- Save the file as an animated JPEG file. The quality of the animation is controlled through the Options button.
- Reduced Color
- Reduce the number of colors included in the saved image. Reduced color means the file is 8 bit Microsoft RLE codec or 256 color.
- Grayscale
- Convert the image to gray scale. Reducing the size of the image results in a reduction in file size with some loss of detail.
- Window compressor
- Export the file using the default AVI compressor set in your Windows operating system.
- Size
- Size of the exported file as a percentage of the original. Select 100 percent, 75 percent, 50 percent or 33 percent. Thirty-three percent is the default.
- Frame rate (fps)
- Frame rate at which you want the file to be saved. The default frame rate is 25.000000.
- Encoding
- Select JPEG or ZLIB.
- JPEG Quality
- Value for the JPEG quality.
H3D
- Compression Maximum % Loss
- Suggested amount that the model's values can be perturbed when compressed. The value you provide will be compared to the results of an error estimation function to allow your compression algorithm to maintain an acceptable level of accuracy for your data. However, even a percentage of zero may result in some loss due to minute rounding errors.
- All models
- Export all the models in the window to individual files when two or more models are loaded.
- Entity Attributes
- Output specific attributes assigned to the model's entities, such as color and transparency. If deselected, the default attributes will be used when the file is loaded.
- Include Masked Elements
- Export all masked elements with the model.
- Include sets
- Export all sets with the model.
- Animation
- Export any animation settings applied.
- Results
- Export result values with the model. If not selected, only the model and animation are exported.
- View Attributes
- Output all attributes assigned to the model during a HyperView session. If deselected, the default attributes will be used when the file is loaded.
- HTML
- Create an HTML file for use with HyperView Player.
- Preview Image
- Export a preview image.
- If there is a streamline created for at least one rake, the exported H3D file will contain the datatypes/datasets used by the CFD/Streamlines panel. In addition, all of the rake definitions and streamline settings/display options will also be captured in the H3D file.
- If there are no streamlines available in the model, the exported H3D file will not contain any datatypes/datasets solely used by the CFD/Streamlines panel. In addition, none of the rake definitions or streamline settings/display options will be captured in the H3D file.
JPEG
- JPEG quality
GIF
The Animated GIF Export option allows you more flexibility in controlling the playback speed and size of the GIF image. You can specify the size and the time delay between frames which will be used for all of the animated GIFs exported in video capture or publish session. You can also specify whether or not the animated GIF has a transparent background.
Due to recent enhancements, the memory usage on the Animated GIF Export has been reduced in half. This is significant when exporting a large number of timesteps/frames on low end machines with limited RAM, or 32-bit machines which have process limits set by the operating system. It should also be noted that the animated GIF format is not really well suited to the production of feature length high definition movies, due in part to its very high memory consumption during creation, and also due to the unavoidable reduction in image quality, which comes with transformation from full color to a GIF’s 256 colors.
- Size
percent, 75 percent, 50 percent or 33 percent from the drop-down
menu.Note: One-hundred percent is the default setting.
- Time Delay (s)
- Time delay between frames (in seconds) to control the playback speed of the animated GIF. The default value is 1 second.
- Transparent Background
- Display the animated GIF with a transparent background.
