Visualize Scatter Plots
Plot exploration inputs and outputs.
Visualize Clusters
Using advanced machine learning techniques, simulation results are classified into clusters.
- The prediction feature requires the EngDataSciFieldPredict license feature.
- To view the clusters, you have to have selected Generate Reports - Clustering in the Evaluate dialog when evaluating the exploration. Or, you can click Generate Clusters to generate a new report. Depending on the size of the results and number of runs in the exploration, this may take several minutes.
Animate Clusters
- Right-click on a cluster and select Animate Selection. This loads an animation in the active HyperView client, overlaying the final deformed shape of each run in the selected cluster. This can be useful for visualizing the deformed shape of the given cluster as a whole.
- Right-click on a cluster or in the white space of the Clusters column and select Animate all Clusters. This creates a new page and loads an animation for each cluster in a new HyperView client, overlaying the final deformed shape of each run in each cluster. This can be useful for visualizing the deformed shape of each cluster as a whole and comparing one cluster to another.
- Select one or more runs in the Runs in Cluster column, right-click, and select Overlay Selection. This loads an animation in the active HyperView client, overlaying the results, including all timesteps, for the selected runs. This can be useful for comparing two runs within a given cluster.
