Review and Edit Design Parameters
Review the explorations, inputs, responses, and goals in your design setup.
![](../../images/icons/icon_table_satellite.png)
In dialog, use the Summary tab to review your setup and control which parameters are active.
You can also control the active state from the Create/Details tab, as well as add, delete, and edit parameters.
