Rotate LCS
Rotate a local coordinate system on an evaluation point.
  1. From Setup group, select Setup > Manage E-Points.
    A guide bar opens.
  2. Click to open advanced options.
  3. Enter the rotation Angle value.
  4. Select the required LCS from the model.
    Figure 3.
    A microdialog opens.
  5. Enter the required rotation increments or select the values manually.
    This rotates the selected LCS at the evaluation point, about the X-axis by the provided rotation angle.
