Delete Connection
Delete connection point(s) along an E-Line.
View new features for HyperWorks 2022.
Technology and problem evaluation approaches used in SnRD.
Explore the SnRD Pre-Processing user interface.
Use Setup Group to setup evaluation lines and define loadcases.
This tool is used to import all data required for the Squeak and Rattle Analysis preparation.
Use the Define Interface tool to create, import, and edit geometric lines.
Edit geometric lines.
Use the Create E-Lines tool to create evaluation lines at component interfaces.
Use the Manage E-Line tool to review and manage E-Lines.
Setup loadcases to solve and extract results.
Use a Variability Study to examine how squeak and rattle risks are affected by manufacturing variations.
Use Manage E-Points to modify local system collectors and evaluation points.
Rotate a local coordinate system on an evaluation point.
Evaluate Loadcase and export solver deck.
Explore SnRD Post Processing User Interface.
Use of Altair Ziegler SnR Material Database.
Figure 1. (c) 2021. Altair Engineering Inc. All Rights Reserved.
