Radioss Interface 2021.1 Release Notes
Radioss Interface
New Features
- Exported Decks Formatting
- For the Radioss profile 2021, the format of the exported decks has been fully redefined, with the export of all solver keywords field names and the re-ordering of the keyword blocks in a more comprehensive and consistent way.
- Include Organization
- The Organize context menu option is now available for all entities. Furthermore, the organization of entities into an include file has been improved to automatically consider all references linked to the selected entities. This feature is also available performing drag and drop of an entity into an include file.
- New Reference Geometry Entities
- The Reference Geometry entity is introduced to provide a better support of the airbag reference geometry and foam reference geometry keywords. A dedicated graphical representation is used which allows the visualization of the airbag patches. The interactive modification of the nodes defining the /EREF is also possible directly on the graphic.
Enhancements
- New Keywords
- /SUBDOMAIN, /FUNCT_SMOOTH, /MAT/LAW108, /MAT/LAW113, /MONVOL/FVMBAG2, /PROP/TYPE23.
- Updated Keywords
- /FAIL/HASHIN, /INTER/TYPE25, /MAT/LAW44, /MAT/LAW83, /MAT/LAW100, /MONVOL/GAS, /ANIM/BEAM/EPSP.
- Support of RBE3
- The support of /RBE3 has been updated to remove all existing limitations and get a correct description of the element in the Entity Editor.
- Creation of Curves
- Efficiency improvement for creating/editing curves from any keyword entity editor by directly exposing the curve editor for a direct access to the (X;Y) data.
- Mechanism in Assembly Ribbon
- The Mechanism tool is now directly accessible into the Assembly ribbon, like in any other solver interfaces supporting this tool.
- Model Checker Enhancements
- New check for “Material and property are not compatible."
- New check for “Material and element type are not compatible."
- New check for “Property and element type are not compatible."
- New check for “Multiple RBODY sharing common nodes” and corresponding automatic correction to automatically merge the RBODYs.
- New check for “Empty Components” and “Empty Dampings” and corresponding automatic deletion of failed entities.
- Automatic correction added for the check “RBODY main node on element."
- Automatic correction added for the check “Small rigid body with non-spherical inertia."
- Correction of check “LAW2, 4, 15, 27, C and Eps0 defined but Fsmooth and Fcut blank."
- Correction of checks “Main set not defined” and “Secondary set not defined” for contacts TYPE19, TYPE24 and TYPE25.
Enhancements
- Reader
- Reader enhancement to support 3 nodes and 4 nodes spring elements when importing Radioss input deck.
Radioss Interface
Enhancements
- Reader Enhancements
- Radioss FEMZIP reader library upgraded to version v11.27.
- Reader enhancement to support 3 node and 4 node spring elements when importing a Radioss input deck.
Altair HyperCrash
Enhancements
- Radioss Keywords Support
- The following Starter keywords have been added or updated per the latest solver version: /AIRBAG/FVMBAG1, /DEF_SOLID, /INTER/TYPE25, /MAT/LAW104, /PROP/TYPE6, /PROP/TYPE14, /PROP/TYPE20, /PROP/TYPE21, /PROP/TYPE22, /PROP/TYPE43, /SENSOR/ENERGY
Resolved Issues
- Some issues in the Sub-modeling process are fixed:
- In some cases, a different number of nodes in the cutting section between the full and sub-model was generated.
- In specific cases, a segmentation error in the process was found.
- The initial velocity defined by /INIVEL/AXIS was not written properly.
- Correction in reading /PROP/USER2.
- Model Checker: Correction made in the check “Incompatible settings for iframe, isolid, and ismstr for Law 70.”
