Altair Multi Body Solutions 2021.1 Release Notes
Highlights
The Altair Multi Body Solutions v2021.1 release provides several enhancements and bug fixes to MotionView and MotionSolve.
  • Support for Pratt Miller Flexible Tire Model
  • 1D Electric Powertrain with Regenerative Braking
  • 1D Traction Controller for Car Library
  • Other Enhancements
  • Resolved Issues
MotionView v2021.1 supports a Pratt Miller flexible tire (PM-FlexTire) that can be modeled in Altair/EDEM to interact with particles representing soil, sand, gravel, and so on. The PM-FlexTire solution is available as an Altair Partner product (www.altairone.com/marketplace). MotionView allows you to set up the tire as part of vehicle modeling and transfer the tire to EDEM through the EDEM system panel.
The input needed to use this tire model are:
  1. Tire property file (.fxt) in TeimOrbit format.
  2. Tire geometry file (any CAD format supported by HyperMesh).
  3. Handling tire property file (*.tir, *.tpf) in TeimOrbit format.
The .fxt file references the geometry and handling tire property file. The .fxt file should also contain the material properties for the tire. The handling tire is used for the initial static solution in MotionSolve and driving the vehicle over a road on a stretch that is not covered by EDEM particles.
PM_FlexTire uses a set of files (*.bdf, *.off) that provide information regarding the carcass, belt, and boundary conditions. The AutoTire panel helps in creating these files using the CAD geometry file as given in the .fxt file.
To support this tire functionality, the AutoTire has the following new enhancements and features:
  • The panel can load a PM-FlexTire file (.fxt). Information in the panel related to tire is automatically updated.
  • A rim graphic with dimension as provided in the .fxt file is available.
  • Reference to a handling tire file.
  • A new Flex Tire tab is available to assist you in creating the necessary mesh files needed by PM-Flextire (Windows only).
The EDEM System panel has been updated to support the transfer of AutoTire of the type PM-FlexTire and its coupling to EDEM during co-simulation with MotionSolve.
Figure 3.
The transfer process handles:
  • Creating of a *.FlexTire file that is used in EDEM.
  • Sets the component as FlexTire and resolves the file path to the .FlexTire file.
  • Includes the Rim graphic as a child of the tire component.
Known Issues
  • Creation of the mesh files is not available on Linux (PM-FlexTire is not available on Linux).
  • The AutoTire collector on the EDEM System panel does not pick the Autotire when clicked on Tire graphics.
For additional information regarding AutoTire and the EDEM System, refer to the AutoTire - Auto Entity and Bulk Material Interaction topics.
MotionAuto adds an option to choose Electric Powertrain (FMU) for the Car/Small truck and Two-wheeler libraries. To use this option, select the Electric Powertrain (FMU) option in the Powertrain option menu of the Assembly Wizard.
Figure 4.
The powertrain is a 1D model created in Altair Activate and exported as FMU. The Altair Activate models (.scm files) are included so you can view and edit the models to produce new FMUs as needed.
The powertrain takes input shaft speed, vehicle longitudinal velocity, and driver throttle demand as input and produces the torque as output. The schematic below illustrates the flow of control between the Vehicle model in MotionSolve and the FMU:
Figure 5. Interaction between Electric Powertrain (FMU) and the MotionSolve Vehicle Model
The MDL system wrapping the FMU 1D motor, inverter, and battery models includes the motor’s stationary and rotating mass and inertia, and also the battery mass and inertia which is a significant portion BEVs total mass and inertia. Finally, the electric motors’ torque-speed characteristic is read from an external file for use in Altair Driver’s feedforward speed and acceleration control.
MotionAuto adds a new 1D Traction Controller (TC) model for the Car/Small truck library. TC senses excessive wheel slip under acceleration and modulates the throttle input to the powertrain to limit the slip. To use this option, select the Traction Controller (TC) option in the Traction Controller option menu of the Assembly Wizard.
Figure 6.
The 1D TC is created in Altair Activate and exported as an FMU. The inputs to this FMU are wheel speeds, vehicle longitudinal acceleration, and Driver output throttle. The control block employs the wheel speeds and the vehicle longitudinal acceleration to estimate the tire longitudinal slips and returns (output from the FMU) the modulated throttle which is in turn used as input to the powertrain.
The schematic below illustrates the interaction of the TC system with the vehicle model:
Figure 7. Interaction between Traction Controller (TC) and the MotionSolve Vehicle Model
Other Enhancements
Data Summary
The Data Summary tool features a new “Evaluate on Apply” option. Through this option, model evaluation can be suspended during editing data. Evaluation is done only once when either the Apply button is clicked or the entity tab is changed. This feature would be useful for editing multiple data for very large models that take significant time for model evaluation. By default, model is evaluated for every data edit.
Spring Damper Graphic
When a Coil Spring Damper is created, a helical shape representing the spring and two tapered cylinders representing the damper is now displayed. This new graphical representation replaces both the 'implicit graphic' as well as the explicit 'SpringGraphic' options used in prior releases. The attributes of the Spring Damper (Number of Coils, Radius) can be set in the Spring panel. Currently the damper's inner and outer cylinders are sized as 1/3 and 2/3 of the spring radius, respectively. Future releases will allow more control over damper size with additional attributes.
Known Issues
  • Spring dimensions (Radius, Number of coils) of explicit SpringGraphics in legacy models are not transferred to the new Graphic tab on the Spring panel in MotionView.
  • You may observe the appearance of two springs in the .h3d file (for example AutoSprings) when only one spring is expected. For instance, if your model contains an explicit SpringGraphic it will be seen along with the new Coil Spring graphic. The alternative solution for this is to either delete (or deactivate) the explicit SpringGraphic in MotionView, or you can hide it from the browser in HyperView.
  • AutoSprings use the legacy explicit SpringGraphic entity for displaying the spring in MotionView. In the current release, this graphic is not rendered in the user interface. Therefore, editing the graphic display attributes "Coils" and "Coil Radius" will not show visible changes in the user interface. However, these change will be reflected in the simulation results loaded in HyperView.
    Figure 8.
MotionSolve and EDEM Co-simulation
MotionSolve has the ability to interface with Altair EDEM, a state-of-the-art bulk material simulation tool. In previous versions, the integration step size in EDEM had to be an exact multiple of the communication step size between MotionSolve and EDEM. This restriction has been removed in this release. You can now select any integration step size in EDEM, providing a better user experience and potentially faster co-simulation.
Track Model
In release v2021, Altair’s Multibody Dynamics products (MotionView and MotionSolve) introduced a new continuous track plug-in for tracked vehicles, such as bulldozers, excavators, robots, snowmobiles, and military vehicles. The track plug-in automatically assembles a continuous band of treads or track plates driven and suspended by two or more wheels, that can interact with soft-soil surface. In this release, the soft-soil of the track plug-in has been enhanced two-fold. First, the soft-soil can now be visualized in MotionView and HyperView for better a user experience. Second, you can choose to rigidify the soft-soil just by selecting a flag. Many track designs are being investigated on rigid grounds, such as paved road, before they are tested on soft-soil, which made this enhancement necessary.
Support OML-based User Subroutines
Since release v2020.1, MotionSolve supports subroutines that are scripted in the OpenMatrix Language (OML). Initially, only an embedded OML interpreter that supports the basic OML syntax was available but does not include/support any of the additional toolboxes and libraries. In release v2021, MotionSolve was enhanced to connect with the installation of Altair Compose to interpret OML-based subroutines. This enhancement provided access to hundreds of powerful math operations and built-in function that are entailed in Altair Compose. Both features, embedded interpreter, and connection to Compose, were available only on the Windows operating system. With this release, support of OML-based user subroutines has been extended to the Linux operating system as well.
Reload Curves
A “Reload All Curves” option is available on the Curve folder, as well as System in the Model Browser, to re-read data files for all curves.
Graphic Scaling
The default scaling of CAD and File graphics in the Y and Z direction is now parametrized with the X direction as default. This change enhances the MotionView response while changing the scale of graphics.
mdl_batch
A Help option is now available on the mdl_batch command: Use mdl_batch -help to bring up the help content.
Upgraded Intel® MKL
MotionSolve relies on the industry-wide accepted Intel® Math Kernel Library (MKL) for its math routines. These routines are highly optimized and threaded for maximum performance. With this release, MotionSolve upgraded the version of the MKL from 2017 to 2019.5. In rare instances, this upgrade can affect MotionSolve simulation results for highly sensitive models. In other words, models that entail sources of indeterminism.
Resolved Issues
  • Changing scale on CAD Graphics was slow in updating. The y and z scaling has been linked to x scaling as default for newly created graphics to speed up the process.
  • mdl_batch on Linux failed when the path to xml contained spaces.
  • mdl_batch process hangs when exporting to msolve py.
  • Free point in component in contact causes failure to generate tria mesh in XML via HyperMesh.
  • A Form that refers to DataSet in another System results in Errors/App Error.
  • FLX referring to CMD and OBJ positioned components incorrectly when opened in HyperView.
  • Update link geometry and Soil system are not displayed correctly on UHD screens.
  • mview.writeFile() function does not write a solver deck for ADAMS and ABAQUS solvers.
  • Entities in imported system are not accessible for picking from AltairDriver attachments.
  • Images related Update Link geometry and Soil System under the Track Builder dialogs does not appear correct on an UHD screen.
  • Incorrect scaling of flex bodies transferred to EDEM when using SI units.
  • Negative values cannot be assigned to products of inertia through Python API.
  • DeformableCurve of the type Markers does not resolve the markers reference list in the Python API when the referenced objects are implicit markers.
  • Spring damper diameter value is exported to MotionSolve Python deck incorrectly when the spring damper radius is an expression.
  • Free point in CAD component used in contact leads to solver failure.
  • Adding a report with incorrect number of arguments using View Reports results in crash of the HyperWorks application.
  • Export of FMU parameters to MotionSolve contains an extra semicolon at the end.
  • Application error when using a Python window with non-MotionView clients.
  • Python API – writeFile() method does not write an ADAMS and Abaqus solver deck.
  • Python API – MotionView crash when adding a shared system.
  • Python API – U array data member of FMU entity returns None.
  • Python Export – Independent variable in Response variable – RMS Deviation is incorrectly written.
  • Application error while editing FMU parameters.
  • CSV file with headers having square braces are not read into a Curve entity.
  • Connection to EDEM: Incorrect scaling of components when transferring flexible bodies from MotionView with SI units.
  • CAD picking for entity creation is hard in some models.
  • Curve-Surface Advanced Joints is not written to MotionSolve XML.
  • Precision difference in Flexbody node and corresponding markers with MKS units causes the solver to fail.
  • flexprep in batch does not work until -ospath is provided.
  • NLFE preload script failed to update the NLFE body with the preload data.
  • Inactive non-linear data for Force/Motion/Bushing etc. are checked that can lead to error and subsequent prevention of solver export.
