CAD Interface 2021.1 Release Notes
CAD Interface
Enhancements
Updated Version Support
  • NX 1953 (native reader)
  • Inspire 2021.1 (Import and export)
Resolved Issues
  • Fixed missing cad surface issues for Catia V5 Hybrid Body and Catia composite parts.
  • Fixed scaling issues on part with JT assembly import as BOM.
  • SI Unit conversion issue fixed when geometry imported as “single part only” & “split component as layers”.
  • Fixed duplication of Parts in STEP file export for Part Assembly instances.
  • Fixed crash issues with OCX file import.
  • Infinite plane is turned off for Catia import. It can be turned on by setting the option "ImportInfinitePlane" to on in the ctreader.ini file.
