Ribbon Cable
This option defines a ribbon cable (with round cores only).
Figure 1. The CD - Cable cross section definition dialog.
Parameters:
Cross section label
The label of the cross section.
Core
PEC
Select this option to set the core of the cable to PEC.
Material label
The label of the metallic medium (as defined in the DI card) to be used for the core.
Core radius
The radius of the core.
Number of cores
The number of cables which constitute the ribbon cable.
Core spacing
The spacing between the adjacent cores.
Insulation
Material label
The label of the material (as defined in the DI card) to be used for the insulation layer.
Thickness
The thickness of the insulation layer (optional).
Cable per-unit-length parameters accuracy
The Cable per-unit-length parameters accuracy can be increased from Normal (default) to High or Very high.
