SB Card
This card specifies an external magnetostatic bias field applied to a 3D anisotropic medium (ferrite).
In the Home tab, in the Define group, click the  Media icon. From the drop-down list select the  Magnetic bias (SB) icon.
Figure 1. The SB - Specify a magnetostatic bias field to be applied to an anisotropic medium (3D) dialog.
Parameters:
Magnetostatic bias field name
The name of the magnetostatic bias field name to be defined.
Label of the anisotropic medium
Label of the anisotropic medium (ferrite) to which the magnetostatic bias field is applied.
DC bias field (Oersted)
The magnitude of the DB bias field in Oersted.
Field direction
The direction the magnetostatic bias field is applied to the anisotropic medium (3D).
