When you have a team where one person works on modeling while another works on materials, the Import and Apply Materials
function can be used to import the materials and automatically apply them to the corresponding geometry in the model.
This gives the team the flexibility to work simultaneously, so that the model can continue to be modified while the
materials are being created and applied.
Export selected objects to a common folder used to exchange data with other Altair products. For example, you can export a die design from Inspire Studio to Inspire Form to perform a stamping simulation.
The software saves versions of your objects as you create them, enabling you to return to an earlier stage of an object,
and modify or reuse the object from that stage.
Capture an image of a model. The background is white by default, but you can make it colored or transparent. Arrows
on curves are automatically turned off.
Inspire Studio has four different tool belts to help you quickly access the tools you need for 3D modeling, sketching, creating
PolyNURBS, and rendering. You can use the tool belts with the default configuration of tools or you can customize
the tool belts by adding and removing tools as required.
Create polygonal surfaces that can easily be converted into NURBS surfaces. PolyNURBS combines the ease and simplicity
of polygonal modeling with the precision and flexibility of NURBS, allowing you to quickly create free-form solid
geometry that is smooth and continuous.
Measure dimensions, analyze curvature, check for continuity and watertightness, analyze the draft, detect undercuts,
assign tags to entities, edit and visualize streamlines as static images or animations, create design iterations on
the fly, and assign variables.
Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined
dimensions. You can also insert a general annotation to label the parts of your model.
Import a File
Open a previously saved scene and merge it with the current one.
When you have a team where one person works on modeling while another works on materials, the Import and Apply Materials function can be used to import the materials and automatically apply them to the corresponding geometry in the model. This gives the team the flexibility to work simultaneously, so that the model can continue to be modified while the materials are being created and applied.
Save or Export a File
Save a scene, a bundle, selected objects, a selected model, or a Studio set. You can change the autosave settings and turn on Safe save.
Export to Exchange
