Supported File Formats
View a list of supported file formats for import and export.
By default, models created in Inspire Studio are saved in the native format with the file extension .istudio.
Note: Earlier versions of the product used an .evo or .st file extension for native files. If you need to view a model from an earlier version of the product, change the file name extension to .evo or .st manually, rather than using the Save As function.
The installation program allows you to select import/export plug-ins to be installed.
Tip: When opening/importing and saving/exporting IGES or STEP files, if the default import option CT doesn't work properly, try changing it to PS.
Import
  • Inspire Studio models (.iStudio, .evo, .st, .stm)
  • Thea Studio (.thea)
  • Altair Inspire (.stmod)
  • VRML (.vrml, .wrl)
  • Point cloud (.cld, .txt)
  • IGES (.iges, .igs)
  • STEP (.stp, .step)
  • Parasolid (.x_t, .xmt_txt, .x_b, xmt_bin)
  • ACIS (.sat)
  • CATIA V4 (.model, .dlv, .exp, .session)
  • CATIA V5 (.CATPart, .CATProduct, .cgr)
  • CATIA V6 (.3Dxml)
  • SolidWorks (.sldprt, .sldasm)
  • Pro/ENGINEER and Creo (.prt, .asm, .neu)
  • Unigraphics/NX (.prt)
  • Inventor (.ipt, .aim)
  • JT (.jt)
  • I-DEAS (.arc, .unv)
  • VDA (.vda)
  • H3D (.h3d)
  • STL (.stl)
  • 3DStudio (.3ds)
  • OBJ (.obj)
  • Rhino (.3dm)
  • Scalable vector graphics (.svg)
  • AutoCAD Drawing (.dwg, .dxf)
Export
  • Inspire Studio models and bundles (.iStudio, .evo)
  • AltairInspire (.stmod)
  • VRML (.wrl)
  • IGES (.igs)
  • STEP (.stp)
  • Parasolid (.x_t)
  • Parasolid binary (.x_b)
  • ACIS (.sat)
  • VDA (.vda)
  • STL (.stl)
  • 3DStudio (.3ds)
  • OBJ (.obj)
  • Rhino (.3dm)
  • AutoCAD Drawing Exchange (.dxf)
  • AutoCAD Drawing (.dwg)
  • PDF (.pdf)
What type of data is imported/exported?
File Format Import Export
3D STUDIO (.3ds)
  • Object
  • Camera
  • Colors and textures
  • NURBS surfaces
  • Polygonal surfaces
  • NURBS curves are not exported. Objects with more than 65,535 faces or vertices can't be exported, as requested by the 3D Studio format.
ACIS (.sat)
  • NURBS curves
  • NURBS surfaces
  • Solids
Where available, assembly structure is imported as hierarchical groups.
ARCH BILL (.txt)   Architecture objects
Creates a text file listing information (area, volume, quantity, etc.) about the objects created by the Architecture modeling tools.
AUTOCAD (.dwg)
  • Lines (2D/3D)
  • Ellipses
  • Arcs
  • Polylines
  • Splines
  • Polylines (3D)
  • Polyface meshes
  • 3Dfaces
  • Solids
  • Traces
  • Insert/Blocks
  • Dimensions
  • Layers with colors are supported. Only dwg files up to version 2000/2002 are supported.
AUTOCAD ASCII (.dxf)
  • Lines (2D/3D)
  • Ellipses
  • Arcs
  • Polylines
  • Splines
  • Polylines (3D)
  • Polyface meshes
  • 3Dfaces
  • Solids
  • Traces
  • Insert/Blocks
  • Dimensions
  • 3DSolid/Body/Region
  • ASCII and binary formats are supported.
  • NURBS curve as Spline, Polyline, or Line sequence
  • NURBS surface as polyface mesh entity
  • Polygonal surface as polyface mesh entity
  • Dimensions
  • Layers with colors are not supported.
CATIA
  • NURBS curves
  • NURBS surfaces
  • Solids
  • Where available, assembly structure is imported as hierarchical groups.
I-DEAS (.arc, .unv)
  • NURBS curves
  • NURBS surfaces
  • Solids
IGES - Initial Graphics Exchange Specification (.igs, .iges) All the main curve/surface/solid IGES entity types are supported.
  • NURBS curves
  • NURBS surfaces
  • Solids
INVENTOR (.ipt, .iam)
  • NURBS curves
  • NURBS surfaces
  • Solids
JT (.jt)
  • NURBS curves
  • NURBS surfaces
  • Solids
OBJ (.obj)
  • Objects
  • NURBS surfaces
PARASOLID (.x_t, .x_b)
  • Text, ASCII, and binary formats are supported
  • Open and save are supported, so you can import and export the file format.
PDF (.pdf)
  • NURBS curve:
    • Curve with degree=1 and number of points=2: exported as lines.
    • Curve with degree=1 and number of points>2: exported as polylines.
    • Other curves exported as spline.
  • NURBS surface:
    • Exported as polyface mesh using the view tessellation.
  • Polymesh:
    • User can choose the paper dimension and orientation.
  • Color policy:
    • As Is: (default) Entities are exported using their own color
    • Monochrome: Entities are exported with black color (background is white)
    • Grayscale: Entities are exported using the gray scale
POINT CLOUD (.cld, .txt) Point clouds stored as X, Y, and Z coordinates in the file.
Pro/ENGINEER and CREO (.prt, .asm, .neu)
  • NURBS curves
  • NURBS surfaces
  • Solids
RHINO (.3dm)
Import (v.1 to v.5)
  • NURBS curves
  • NURBS surfaces
  • Point clouds
  • Layers and colors
  • NURBS curves
  • NURBS surfaces
  • Point clouds
  • Layers and colors
SOLIDWORKS (.sldprt, .sldasm)
  • NURBS curves
  • NURBS surfaces
  • Solids
STEP - Standard for the Exchange of Product Model Data (.stp, .step)
  • NURBS curves
  • NURBS surfaces
  • Solids
  • NURBS curves
  • NURBS surfaces
  • Solids
STL - Standard Tessellation Language (.stl) Objects
ASCII and binary format are supported.
  • NURBS surfaces
  • ASCII and binary format are supported.
UNIGRAPHICS/NX (.prt)
  • NURBS curves
  • NURBS surfaces
  • Solids
VDAFS - Verband der Automobilindustrie - Flächenschnittstelle (.vda)
  • NURBS curves
  • NURBS surfaces
  • Solids
  • NURBS curves
  • NURBS surfaces
  • Solids
