/STATE/SHELL
In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature…) for shell element in state file (STA-File).
View new features for Radioss 2021.1.
Radioss format 2021 uses the 12x extension format.
Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, etc.) in state file (STA-File).
Engine Keyword Describes the internal variable state for beam.
In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature…) for solid element in state file (STA-File).
Engine Keyword Define time output frequency and parts to be written to the state file.
Engine Keyword Writes the state file for only non-deleted elements.
Engine Keyword Boundary conditions for Node. The boundary conditions applied to nodes be written to the state file.
Engine Keyword Describes the temperature for nodes.
Engine Keyword The velocity of a node is written to the state file.
Engine Keyword Describes the internal variable state for shell.
Engine Keyword Describes the Epsilon plastic state for shell.
Engine Keyword Describes the failure criteria state for shell.
Engine Keyword Describes the orthotropy direction for shell.
Engine Keyword Describes the strain state for shell.
Engine Keyword Describes the stress state for shell.
Engine Keyword Describes the internal variable state for spring elements.
Engine Keyword When writing the state file, /INISHE, /INISH3 and /INIBRI will be written in a separate file which can be asked for being compressed (using GZIP) or not. The state file will then resume to the nodes coordinates and element connectivity.
Engine Keyword Describes the internal variable state for truss.
Engine Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
This manual contains an alphabetical list of LS-DYNA input files available in Radioss.
This manual contains the description of the Keywords for the Radioss Multi-Domain.
This manual describes the interface between Altair Radioss and a user’s subroutines.
