/IMPL/LSEARCH/n
Engine Keyword Line search methods for nonlinear analysis.
/IMPL/LSEARCH/N
MAX_ls TOL_ls
N |
MAX_ls | Maximum line search
iteration number. Default = 20 |
TOL_ls | Tolerance for line search
iteration. Default =1.0e-3 |
- The method N=1 is suitable with material nonlinear analyses (from version 10-SA1-202). The old method N=3 is suitable with general nonlinear analyses with contact.
