/EXTERN/LINK
Multi-Domain Keyword Defines the interfaces between the current model and other domains.
| /EXTERN/LINK/link_ID | |||||||||
| title | |||||||||
| gr_ID | |||||||||
| link_ID | Link
| title | Title (Character, maximum 100 characters) |
| gr_ID | Nodal group identifier
defining frontier nodes with other domain (Character, maximum 100 characters) |
- The number of external links in Radioss model is not limited. The only restriction is that different links should not contain common nodes. Each link defines a distinct interface between current model and external world.
- The links do not specify the corresponding domains. Each model is independent and may be replaced by another one having the same frontier nodes. This approach allows a modular approach to modeling, for example testing runs with equivalent domains with different mesh size (multi-grid approach).
