/DT/FVMBAG/Iflag
Engine Keyword Time step for control for Finite Volume Method airbag.
/DT/FVMBAG/Iflag
Iflag | Finite volumn merge flag.
Scale factor on time step. | ||
Minimum time step. |
- The and can be defined to insure stability and a minimum time step size by triggering additional finite volume merges when the FVMBAG entity penalizes the computation.
