/ANIM/NODA
Engine Keyword Generates animation files containing nodal scalar data.
/ANIM/NODA/Restype
Restype | Nodal data type:
with
.Where,
- Nodal mass at the beginning of the restart
- Current mass
is re-set to 0 at the beginning of each restart
file.
(1) Where,- Nodal inertia at the beginning of the current run
- Current inertia
- In case
/DT/AMS is used, a non-diagonal mass matrix is used, which
allows to increase the time step on each line of the mass matrix, the lumped mass
M
is increased with some value
which is compensated with non-diagonal terms, in
order for the total mass to remain constant. Then:
(2) - DAMA2 damage percentages for /INTER/TYPE2 with rupture (Spotflag = 20,
21, or 22):
(3) (4) - /ANIM/NODA/TEMP is used generally to output nodal temperature for finite element formulation of thermal exchange.
- These options are also available for 3D ALE and FVM airbag problems. The material density, pressure, and temperature is extrapolated to the element nodes, in this case. For FVM airbags the values are extrapolated only to nodes of external and internal airbag surfaces.
