/ALE/LINK/OFF
Engine Keyword An ALE link definition /ALE/LINK/VEL (Starter) can be deactivated.
/ALE/LINK/OFF
ID1, ..., IDn
IDi | Identifiers of ALE links (Starter) |
- This keyword can only deactivate ALE links which are defined in Starter /ALE/LINK/VEL.
- This keyword cannot deactivate ALE links which are defined in Engine /ALE/LINK/VEL. This ALE link (Engine) is active only during the current run.
