Configure the Results Browser
Change the entity types, columns, options, and toolbars that are displayed in the Results Browser.
  1. Right-click in the Results Browser and select Configure Browser from the context menu.
  2. Use the Browser Configuration dialog to edit browser options, entities and toolbars.
  3. Click one of the command buttons to close the dialog.
    • Click Apply to append the new settings without closing the window.
    • Click OK to keep the new settings, including those that are not applied, and close the window.
    • Click Cancel to discard the changes that are not applied (keeping previous applied settings) and close the window.
  4. Change the columns/attributes that display in the Results Browser by right-clicking on a column heading and selecting check boxes in the microdialog.
