Supported Cards
Supported cards organized by solver.
Abaqus
- *AMPLITUDE
- *ASSEMBLY
- *BASE MOTION
- *BEAM ADDED INERTIA
- *BEAM GENERAL SECTION
- *BEAM SECTION
- *BEAM SECTION OFFSET
- *BIAXIAL TEST DATA
- *BLOCKAGE
- *BOUNDARY
- *BRITTLE CRACKING
- *BRITTLE FAILURE
- *BRITTLE SHEAR
- *BUCKLE
- *BULK VISCOSITY
- *CECHARGE
- *CECURRENT
- *CFILM
- *CFLUX
- *CHANGE FRICTION
- *CLAY HARDENING
- *CLAY PLASTICITY
- *CLEARANCE
- *CLOAD
- *COHESIVE BEHAVIOR
- *COHESIVE SECTION
- *COMBINED TEST DATA
- *COMPLEX FREQUENCY
- *CONDUCTIVITY
- *CONNECTOR BEHAVIOR
- *CONNECTOR CONSTITUTIVE REFERENCE
- *CONNECTOR CONTACT FORCE
- *CONNECTOR DAMPING
- *CONNECTOR DERIVED COMPONENTS
- *CONNECTOR ELASTICITY
- *CONNECTOR FAILURE
- *CONNECTOR FRICTION
- *CONNECTOR HARDENING
- *CONNECTOR LOAD
- *CONNECTOR LOCK
- *CONNECTOR MOTION
- *CONNECTOR PLASTICITY
- *CONNECTOR POTENTIAL
- *CONNECTOR SECTION
- *CONNECTOR STOP
- *CONSTRAINT CONTROLS
- *CONTACT (General Contact)
- *CONTACT CLEARANCE
- *CONTACT CLEARANCE ASSIGNMENT
- *CONTACT CONTROLS
- *CONTACT CONTROLS ASSIGNMENT
- *CONTACT DAMPING (Explicit template)
- *CONTACT DAMPING (Standard templates)
- *CONTACT EXCLUSIONS
- *CONTACT FILE
- *CONTACT FORMULATION
- *CONTACT INCLUSIONS
- *CONTACT INITIALIZATION ASSIGNMENT
- *CONTACT INITIALIZATION DATA
- *CONTACT INTERFERENCE
- *CONTACT OUTPUT
- *CONTACT PAIR
- *CONTACT PRINT
- *CONTACT PROPERTY ASSIGNMENT
- *CONTACT PROPERTY ASSIGNMENT, PROPERTY=OFFSET FRACTION
- *CONTACT PROPERTY ASSIGNMENT, PROPERTY=THICKNESS
- *CONTROLS
- *COUPLED TEMP-DISPLACEMENT
- *COUPLING
- *CREEP
- *CRUSHABLE FOAM
- *CRUSHABLE FOAM HARDENING
- *DAMPING
- *DASHPOT
- *DEBOND
- *DECHARGE
- *DENSITY
- *DEPVAR
- *DFLUX
- *DIAGNOSTICS
- *DIELECTRIC
- *DISCRETE SECCTION
- *DISTRIBUTING
- *DISTRIBUTING COUPLING
- *DISTRIBUTION
- *DISTRIBUTION_ANGLE
- *DISTRIBUTION_DRAPE
- *DISTRIBUTION_OFFSET
- *DISTRIBUTION_ORIENTATION
- *DISTRIBUTION_THICKNESS
- *DLOAD
- *DSLOAD
- *DYNAMIC
- *DYNAMIC (Explicit)
- *EL FILE
- *EL PRINT
- *ELECTRIC CONDUCTIVITY
- *ELASTIC
- *ELEMENT
- *ELEMENT OUTPUT
- *ELEMENT PROPERTIES
- *ELGEN
- *ELSET
- *EMBEDDED ELEMENT
- *END ASSEMBLY
- * END INSTANCE
- *END PART
- *ENERGY FILE
- *ENERGY OUTPUT
- *ENERGY PRINT
- *EQUATION
- *EULERIAN SECTION
- *EXPANSION
- *FABRIC
- *FASTENER (SPOT WELD)
- *FASTENER PROPERTY
- *FILE FORMAT
- *FILM
- *FILTER
- *FIXED MASS SCALING
- *FLUID BEHAVIOR
- *FLUID BULK
- *FLUID DENSITY
- *FLUID EXPANSION
- *FLUID PROPERTY
- *FRACTURE CRITERION
- *FREQUENCY
- *FRICTION (Explicit template)
- *FRICTION (Standard templates)
- *GAP
- *GASKET BEHAVIOR
- *GASKET CONTACT AREA
- *GASKET ELASTICITY
- *GASKET SECTION
- *GASKET THICKNESS BEHAVIOR
- *GEOSTATIC
- *HEADING
- *HEAT TRANSFER
- *HYPERELASTIC
- *HYPERFOAM
- *INCREMENTATION OUTPUT
- *INERTIA RELIEF
- *INITIAL CONDITION (TYPE=STRESS)
- *INITIAL CONDITION (TYPE=PRESSURE)
- *INITIAL CONDITION (TYPE=TEMPERATURE)
- *INITIAL CONDITION (TYPE=VELOCITY)
- *INSTANCE
- *INTEGRATED OUTPUT
- *INTEGRATED OUTPUT SECTION
- *ITS
- *JOINT
- *KINEMATIC
- *KINEMATIC COUPLING
- *LOAD CASE
- *LOADING DATA
- *LOW DENSITY FOAM
- *M1
- *M2
- *MAGNETIC PERMEABILITY
- *MASS
- *MASS FLOW RATE
- *MATERIAL
- *MEMBRANE SECTION
- *MODAL_DAMPING
- *MODAL DYNAMIC
- *MODAL OUTPUT
- *MODEL CHANGE
- *MONITOR
- *MPC
- *MULLINS EFFECT
- *NODAL THICKNESS
- *NFILL
- *NGEN
- *NMAP
- *NODE
- *NODE FILE
- *NODE OUTPUT
- *NODE PRINT
- *NONSTRUCTURAL MASS
- *NSET
- *ORIENTATION
- *OUTPUT
- *PARAMETER
- *PART
- *PHYSICAL CONSTANT
- *PIEZOELECTRIC
- *PLANAR TEST DATA
- *PLASTIC
- *PREPRINT
- *PRE-TENSION SECTION
- *RADIATE
- *RADIATION VIEWFACTOR
- *RATE DEPENDENT
- *REBAR LAYER
- *RELEASE
- *RESPONSE SPECTRUM
- *RESTART
- *RESTART
- *RIGID BODY
- *ROTARY INERTIA
- *SECTION CONTROLS
- *SECTION PRINT
- *SFILM
- *SHEAR FAILURE
- *SHEAR TEST DATA
- *SHELL GENERAL SECTION
- *SHELL SECTION
- *SHELL TO SOLID COUPLING
- *SIMPLE SHEAR TEST DATA
- *SOLID SECTION
- *SPECIFIC HEAT
- *SPECTRUM
- *SPRING
- *STATIC
- *STEADY STATE DYNAMICS
- *STEP
- *SUPERELASTIC
- *SURFACE
- *SURFACE BEHAVIOR (Explicit template)
- *SURFACE BEHAVIOR (Standard templates)
- *SURFACE INTERACTION (Explicit template)
- *SURFACE INTERACTION (Standard templates)
- *SURFACE PROPERTY/*EMISSIVITY
- *SURFACE PROPERTY ASSIGNMENT (Explicit template)
- *SURFACE SECTION
- *SURFACE SMOOTHING
- *SYSTEM
- *TEMPERATURE
- *TIE
- *TRANSFORM
- *TRANSVERSE SHEAR
- *TRANSVERSE SHEAR STIFFNESS
- *UNIAXIAL
- *UNIAXIAL TEST DATA
- *UNLOADING DATA
- *USER MATERIAL
- *USER OUTPUT VARIABLES
- *VARIABLE MASS SCALING
- *VISCO
- *VISCOELASTIC
- *VOLUMETRIC TEST DATA
Actran
- ACCELERATION
- ADMITTANCE
- ANALYSIS
- AXISYMMETRY
- BC_MESH
- BOUNDARY_CONDITION
- COUPLING_SURFACE
- DIMENSION
- DISCRETE
- DISPLACEMENT
- DISTRIBUTED_LOAD
- DISTRIBUTED_PRESSURE
- ELEMENT
- FIELD_POINT_SURFACE
- FREQUENCY_DOMAIN
- IMPERVIOUS
- INCIDENT_SURFACE
- INFINITE ADMITTANCE
- INFINITE_DOMAIN
- INFINITE_ELEMENT
- INFINITE_FLUID
- INFINITE_MESH
- INTERFACE
- LIGHTHILL
- MATERIAL (FLUID)
- MATERIAL (SHELL)
- MATERIAL (SOLID)
- MATERIAL (POROUS_UP)
- MATERIAL (POROUS_RIGID)
- MATERIAL (VISCOTHERMAL)
- MESH
- MEAN_FLOW
- MODAL_BASIS
- MODAL_EXTRACTION
- MODAL_SURFACE
- NODE
- OUTPUT_FRF
- OUTPUT_MAP
- POINT_LOAD
- POROUS_UP
- PRESSURE
- RADIATING_SURFACE
- RAYLEIGH_SURFACE
- RIGID_POROUS
- SAVE
- SHELL
- SOLID
- SOLVER
- SOURCE
- STIFFENER
- SUPER_CONNECTOR
- SUPER_ELEMENT
- TEMPERATURE_PRESSURE
- TITLE
- VELOCITY
- VISCOTHERMAL
- VISCOTHERMAL_FLUID
ADVC
2D Element
3D Element
3D Gasket Element
Isotropic
Orthotropic
- $Density
- $DensityInTable
- $OrthotropicYoungModulus
- $OrthotropicYoungModulusInTable
- $OrthotropicPoissonRatio
- $OrthotropicPoissonRatioInTable
- $OrthotropicShearingModulus
- $OrthotropicShearingModulusInTable
- $OrthotropicThermalConducitivity
- $OrthotropicThermalConducitivityInTable
- $OrthotropicThermalExpansionCoefficient
- $OrthotropicThermalExpansionCoefficientInTable
- $SpecificHeat
- SpecificHeatInTable
- $OrthotropicElasticity
Anisotropic
- $Density
- $DensityInTable
- $SpecificHeat
- $SpecificHeatInTable
- $AnisotropicElasticity
Gasket
ElasticPlastic/Elastic Attributes
von Mises with Isotropic Hardening
ANSYS
- ACEL
- ALPHAD
- ANTYPE
- ARCLEN
- ARCTRM
- /ASSIGN
- AUTOTS
- /BATCH
- BEAM3
- BEAM4
- BEAM23
- BEAM24
- BEAM44
- BEAM54
- BEAM188
- BEAM189
- BETAD
- /BFUNIF
- BF
- BF_FLUE
- BF_HGEN
- BF_TEMP
- BFE_FLUE
- BFE_HGEN
- BFE_TEMP
- BUCOPT
- CE
- CERIG
- CGLOC
- CGOMGA
- CIRCU124
- CMACEL
- CMDOMEGA
- CMOMEGA
- CMGRP
- CNVTOL
- /COM
- COMBIN14
- COMBIN39
- COMBIN40
- CONTA171
- CONTA172
- CONTA173
- CONTA174
- CONTA175
- CONTA177
- CONTA178
- CONTAC12
- CONTAC48
- CONTAC49
- CONTAC52
- ConvBulkTe
- ConvFilmCo
- /COPY
- CP_ELEC
- CP_STRUC
- CRPLIM
- D_CONSTRNT
- D_TEMP
- D_VOLT
- DCGOMG
- /DELETE
- DELTIM
- DIM
- DMPRAT
- DOF
- DOMEGA
- EMUNIT
- EQSLV
- ERESX
- EORIENT
- ETABLE
- EXPASS
- F_FLOW
- F_HEAT
- FLOTRAN
- FLUID
- FLUID29
- FLUID30
- FLUID80
- FLUID116
- FORCE
- FORCE2
- HARFRQ
- HF118
- HF119
- HF120
- HFLUX
- HM_COMP
- HREXP
- HROPT
- HROUT
- HYPER58
- IC_CONSTRN
- IC_TEMP
- IC_VOLT
- INFIN9
- INFIN110
- INTER192
- INTER193
- INTER194
- INTER195
- IRLF
- KBC
- KUSE
- LINK1
- LINK8
- LINK10
- LINK31
- LINK32
- LINK33
- LINK34
- LINK68
- LINK180
- LNSRCH
- LOCAL
- LSSOLVE
- LVSCALE
- MASS21
- MASS71
- MAT
- MATRIX27
- MDAMP\
- MESH200
- MODE
- MODOPT
- MP
- MPDATA
- MPC184
- MPTEMP
- MXPAND
- N
- NBLOCK
- NCNV
- NEQIT
- NLGEOM
- NROPT
- NSUBST
- OMEGA
- OUTRES
- PIPE16
- PIPE18
- PIPE20
- PIPE60
- PLANE2
- PLANE13
- PLANE25
- PLANE35
- PLANE42
- PLANE53
- PLANE55
- PLANE67
- PLANE75
- PLANE77
- PLANE78
- PLANE82
- PLANE83
- PLANE121
- PLANE145
- PLANE146
- PLANE162
- PLANE182
- PLANE183
- PLANE223
- /POST1
- PRED
- PRESOL
- PRESSURE
- PRETS179
- PSTRES
- RBE3
- RSYS
- SECCONTROLS
- SECDATA
- SECOFFSET
- SECTYPE
- SFE
- SHELL28
- SHELL41
- SHELL43
- SHELL51
- SHELL57
- SHELL61
- SHELL63
- SHELL91
- SHELL93
- SHELL99
- SHELL131
- SHELL132
- SHELL143
- SHELL150
- SHELL157
- SHELL163
- SHELL181
- SHELL208
- SHELL209
- SHELL281
- SLOAD
- SOLID5
- SOLID45
- SOLID46
- SOLID62
- SOLID64
- SOLID69
- SOLID70
- SOLID72
- SOLID73
- SOLID87
- SOLID90
- SOLID92
- SOLID95
- SOLID96
- SOLID97
- SOLID98
- SOLID117
- SOLID147
- SOLID148
- SOLID164
- SOLID168
- SOLID185
- SOLID186
- SOLID187
- SOLID191
- SOLID226
- SOLID227
- SOLID236
- SOLSH190
- /SOLU
- SOLU
- SOLVE
- SSTIF
- /STITLE
- SUBOPT
- SURF151
- SURF152
- SURF153
- SURF154
- SURF156
- SURF251
- SURF252
- /SYS
- TARGE169
- TARGE170
- TB
- TBDATA
- TIME
- TIMINT
- TINTP
- /TITLE
- TOFFST
- TOTAL
- TREF
- TRNOPT
- TUNIF
- /UNITS
- VISCO88
- VISCO107
EXODUS
Feko
LS-DYNA
- *AIRBAG_ADIABATIC_GAS_MODEL
- *AIRBAG_ALE
- *AIRBAG_HYBRID
- *AIRBAG_HYBRID_CHEMKIN
- *AIRBAG_HYBRID_JETTING
- *AIRBAG_HYBRID_JETTING_CM
- *AIRBAG_INTERACTION
- *AIRBAG_LINEAR_FLUID
- *AIRBAG_LOAD_CURVE
- *AIRBAG_PARTICLE
- *AIRBAG_PARTICLE_DECOMPOSITION
- *AIRBAG_PARTICLE_DECOMPOSITION_MOLEFRACTION
- *AIRBAG_PARTICLE_MOLEFRACTION
- *AIRBAG_PARTICLE_MPP
- *AIRBAG_PARTICLE_MPP_DECOMPOSITION
- *AIRBAG_PARTICLE_MPP_MOLEFRACTION
- *AIRBAG_PARTICLE_MPP_DECOMPOSITION_MOLEFRACTION
- *AIRBAG_REFERENCE_GEOMETRY
- *AIRBAG_REFERENCE_GEOMETRY_BIRTH
- *AIRBAG_REFERENCE_GEOMETRY_BIRTH_RDT
- *AIRBAG_REFERENCE_GEOMETRY_RDT
- *AIRBAG_SHELL_REFERENCE_GEOMETRY
- *AIRBAG_SHELL_REFERENCE_GEOMETRY_RDT
- *AIRBAG_SIMPLE_AIRBAG_MODEL
- *AIRBAG_SIMPLE_PRESSURE_VOLUME
- *AIRBAG_WANG_NEFSKE
- *AIRBAG_WANG_NEFSKE_JETTING
- *AIRBAG_WANG_NEFSKE_JETTING_CM
- *AIRBAG_WANG_NEFSKE_JETTING_POP
- *AIRBAG_WANG_NEFSKE_JETTING_POP_CM
- *AIRBAG_WANG_NEFSKE_MULTIPLE_JETTING
- *AIRBAG_WANG_NEFSKE_MULTIPLE_JETTING_CM
- *AIRBAG_WANG_NEFSKE_MULTIPLE_JETTING_POP
- *AIRBAG_WANG_NEFSKE_MULTIPLE_JETTING_POP_CM
- *AIRBAG_WANG_NEFSKE_POP
- *ALE_FSI_PROJECTION
- *ALE_MULTI-MATERIAL_GROUP
- *ALE_REFERENCE_SYSTEM_CURVE
- *ALE_REFERENCE_SYSTEM_GROUP
- *ALE_REFERENCE_SYSTEM_NODE
- *ALE_REFERENCE_SYSTEM_SWITCH
- *ALE_SMOOTHING
- *ALE_TANK_TEST
- *BOUNDARY_AMBIENT_EOS
- *BOUNDARY_CONVECTION_SET
- *BOUNDARY_CYCLIC
- *BOUNDARY_FLUX_SET
- *BOUNDARY_NON_REFLECTING
- *BOUNDARY_NON_REFLECTING_2D
- *BOUNDARY_PRESCRIBED_ACCELEROMETER_RIGID
- *BOUNDARY_PRESCRIBED_MOTION_NODE(Accl)
- *BOUNDARY_PRESCRIBED_MOTION_NODE(Disp)
- *BOUNDARY_PRESCRIBED_MOTION_NODE(Vel)
- *BOUNDARY_PRESCRIBED_MOTION_RIGID(Accl)
- *BOUNDARY_PRESCRIBED_MOTION_RIGID(Disp)
- *BOUNDARY_PRESCRIBED_MOTION_RIGID(Vel)
- *BOUNDARY_PRESCRIBED_MOTION_RIGID_LOCAL
- *BOUNDARY_PRESCRIBED_MOTION_RIGID_LOCAL(Accl)
- *BOUNDARY_PRESCRIBED_MOTION_RIGID_LOCAL(Disp)
- *BOUNDARY_PRESCRIBED_MOTION_RIGID_LOCAL(Vel)
- *BOUNDARY_PRESCRIBED_MOTION_SET
- *BOUNDARY_PRESCRIBED_MOTION_SET(Accl)
- *BOUNDARY_PRESCRIBED_MOTION_SET(Disp)
- *BOUNDARY_PRESCRIBED_MOTION_SET(Vel)
- *BOUNDARY_RADIATION_SET
- *BOUNDARY_SPC_NODE
- *BOUNDARY_SPC_NODE_BIRTH_DEATH
- *BOUNDARY_SPC_SET
- *BOUNDARY_SPC_SET_BIRTH_DEATH
- *BOUNDARY_SPH_FLOW
- *BOUNDARY_TEMPERATURE_NODE
- *BOUNDARY_TEMPERATURE_SET
- *CONSTRAINED_BUTT_WELD
- *CONSTRAINED_EXTRA_NODES_NODE
- *CONSTRAINED_EXTRA_NODES_SET
- *CONSTRAINED_GENERALIZED_WELD_BUTT
- *CONSTRAINED_GENERALIZED_WELD_COMBINED
- *CONSTRAINED_GENERALIZED_WELD_CROSS_FILLET
- *CONSTRAINED_GENERALIZED_WELD_FILLET
- *CONSTRAINED_GENERALIZED_WELD_SPOT
- *CONSTRAINED_GLOBAL
- *CONSTRAINED_INTERPOLATION
- *CONSTRAINED_INTERPOLATION_LOCAL
- *CONSTRAINED_JOINT_CONSTANT_VELOCITY_FAILURE
- *CONSTRAINED_JOINT_CONSTANT_VELOCITY_LOCAL_FAILURE
- *CONSTRAINED_JOINT_CYLINDRICAL
- *CONSTRAINED_JOINT_CYLINDRICAL_FAILURE
- *CONSTRAINED_JOINT_CYLINDRICAL_LOCAL_FAILURE
- *CONSTRAINED_JOINT_GEARS_FAILURE
- *CONSTRAINED_JOINT_GEARS_LOCAL_FAILURE
- *CONSTRAINED_JOINT_LOCKING_FAILURE
- *CONSTRAINED_JOINT_LOCKING_LOCAL_FAILURE
- *CONSTRAINED_JOINT_PLANAR
- *CONSTRAINED_JOINT_PLANAR_FAILURE
- *CONSTRAINED_JOINT_PLANAR_LOCAL_FAILURE
- *CONSTRAINED_JOINT_PULLEY_FAILURE
- *CONSTRAINED_JOINT_PULLEY_LOCAL_FAILURE
- *CONSTRAINED_JOINT_RACK_AND_PINION_FAILURE
- *CONSTRAINED_JOINT_RACK_AND_PINION_LOCAL_FAILURE
- *CONSTRAINED_JOINT_REVOLUTE
- *CONSTRAINED_JOINT_REVOLUTE_FAILURE
- *CONSTRAINED_JOINT_REVOLUTE_LOCAL_FAILURE
- *CONSTRAINED_JOINT_ROTATIONAL_MOTOR_FAILURE
- *CONSTRAINED_JOINT_ROTATIONAL_MOTOR_LOCAL_FAILURE
- *CONSTRAINED_JOINT_SCREW_FAILURE
- *CONSTRAINED_JOINT_SCREW_LOCAL_FAILURE
- *CONSTRAINED_JOINT_SPHERICAL
- *CONSTRAINED_JOINT_SPHERICAL_FAILURE
- *CONSTRAINED_JOINT_SPHERICAL_LOCAL_FAILURE
- *CONSTRAINED_JOINT_STIFFNESS_FLEXION-TORSION
- *CONSTRAINED_JOINT_STIFFNESS_GENERALIZED
- *CONSTRAINED_JOINT_STIFFNESS_TRANSLATIONAL
- *CONSTRAINED_JOINT_TRANSLATIONAL
- *CONSTRAINED_JOINT_TRANSLATIONAL_FAILURE
- *CONSTRAINED_JOINT_TRANSLATIONAL_LOCAL_FAILURE
- *CONSTRAINED_JOINT_TRANSLATIONAL_MOTOR_FAILURE
- *CONSTRAINED_JOINT_TRANSLATIONAL_MOTOR_LOCAL_FAILURE
- *CONSTRAINED_JOINT_UNIVERSAL
- *CONSTRAINED_JOINT_UNIVERSAL_FAILURE
- *CONSTRAINED_JOINT_UNIVERSAL_LOCAL_FAILURE
- *CONSTRAINED_LAGRANGE_IN_SOLID
- *CONSTRAINED_LAGRANGE_IN_SOLID_EDGE
- *CONSTRAINED_NODAL_RIGID_BODY
- *CONSTRAINED_NODAL_RIGID_BODY_INERTIA
- *CONSTRAINED_NODAL_RIGID_BODY_SPC
- *CONSTRAINED_NODAL_RIGID_BODY_SPC_INERTIA
- *CONSTRAINED_NODE_SET
- *CONSTRAINED_RIGID_BODIES
- *CONSTRAINED_RIGID_BODY_STOPPERS
- *CONSTRAINED_RIVET
- *CONSTRAINED_SHELL_TO_SOLID
- *CONSTRAINED_SPOTWELD
- *CONSTRAINED_SPOTWELD_FILTERED_FORCE
- *CONSTRAINED_TIE-BREAK
- *CONSTRAINED_TIED_NODES_FAILURE
- *CONTACT_2D_AUTOMATIC_SURFACE_TO_SURFACE
- *CONTACT_2D_AUTOMATIC_SURFACE_TO_SURFACE_THERMAL
- *CONTACT_2D_AUTOMATIC_TIED
- *CONTACT_AIRBAG_SINGLE_SURFACE
- *CONTACT_AIRBAG_SINGLE_SURFACE_MPP
- *CONTACT_AUTO_MOVE
- *CONTACT_AUTOMATIC_BEAMS_TO_SURFACE
- *CONTACT_AUTOMATIC_BEAMS_TO_SURFACE_MPP
- *CONTACT_AUTOMATIC_GENERAL_EDGEONLY
- *CONTACT_AUTOMATIC_GENERAL_EDGEONLY_MPP
- *CONTACT_AUTOMATIC_GENERAL_INTERIOR
- *CONTACT_AUTOMATIC_GENERAL_INTERIOR_MPP
- *CONTACT_AUTOMATIC_GENERAL_MPP
- *CONTACT_AUTOMATIC_NODES_TO_SURFACE
- *CONTACT_AUTOMATIC_NODES_TO_SURFACE_MPP
- *CONTACT_AUTOMATIC_NODES_TO_SURFACE_SMOOTH
- *CONTACT_AUTOMATIC_NODES_TO_SURFACE_SMOOTH_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_THERMAL_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_THERMAL_MPP
- *CONTACT_AUTOMATIC_SINGLE_SURFACE
- *CONTACT_AUTOMATIC_SINGLE_SURFACE_MORTAR
- *CONTACT_AUTOMATIC_SINGLE_SURFACE_MORTAR_MPP
- *CONTACT_AUTOMATIC_SINGLE_SURFACE_MPP
- *CONTACT_AUTOMATIC_SINGLE_SURFACE_SMOOTH
- *CONTACT_AUTOMATIC_SINGLE_SURFACE_SMOOTH_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_COMPOSITE
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_COMPOSITE_THERMAL
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_COMPOSITE_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_THERMAL_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_THERMAL_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_WELD
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_WELD_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_WELD_THERMAL
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_WELD_THERMAL_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_WELD_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED_WELD_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_SMOOTH
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_SMOOTH_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_SMOOTH_THERMAL_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_DAMPING
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_DAMPING_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_DAMPING_MPP_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_DAMPING_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_MORTAR
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_MORTAR_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_MORTAR_MPP_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_MORTAR_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_DAMPING
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_DAMPING_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_DAMPING_THERMAL
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_DAMPING_THERMAL_MPP
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_DAMPING_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK_DAMPING_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_THERMAL_FRICTION
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_THERMAL_FRICTION_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_THERMAL_MPP
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIED_WELD
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIED_WELD_THERMAL
- *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIED_WELD_THERMAL_FRICTION
- *CONTACT_CONSTRAINT_NODES_TO_SURFACE
- *CONTACT_CONSTRAINT_NODES_TO_SURFACE_MPP
- *CONTACT_CONSTRAINT_SURFACE_TO_SURFACE
- *CONTACT_CONSTRAINT_SURFACE_TO_SURFACE_MPP
- *CONTACT_CONSTRAINT_SURFACE_TO_SURFACE_THERMAL_FRICTION
- *CONTACT_CONSTRAINT_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_CONSTRAINT_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_DRAWBEAD
- *CONTACT_DRAWBEAD_MPP
- *CONTACT_ENTITY
- *CONTACT_ERODING_NODES_TO_SURFACE
- *CONTACT_ERODING_NODES_TO_SURFACE_MPP
- *CONTACT_ERODING_SINGLE_SURFACE
- *CONTACT_ERODING_SINGLE_SURFACE_MPP
- *CONTACT_ERODING_SURFACE_TO_SURFACE
- *CONTACT_ERODING_SURFACE_TO_SURFACE_MPP
- *CONTACT_ERODING_SURFACE_TO_SURFACE_THERMAL_FRICTION
- *CONTACT_ERODING_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_ERODING_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_FORCE_TRANSDUCER_CONSTRAINT
- *CONTACT_FORCE_TRANSDUCER_CONSTRAINT_MPP
- *CONTACT_FORCE_TRANSDUCER_PENALTY
- *CONTACT_FORCE_TRANSDUCER_PENALTY_MPP
- *CONTACT_FORMING_NODES_TO_SURFACE
- *CONTACT_FORMING_NODES_TO_SURFACE_MPP
- *CONTACT_FORMING_NODES_TO_SURFACE_SMOOTH
- *CONTACT_FORMING_NODES_TO_SURFACE_SMOOTH_MPP
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE_MPP
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_MPP
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION_MPP
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_THERMAL_MPP
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE_THERMAL_FRICTION
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_FORMING_ONE_WAY_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_FORMING_SURFACE_TO_SURFACE
- *CONTACT_FORMING_SURFACE_TO_SURFACE_MORTAR
- *CONTACT_FORMING_SURFACE_TO_SURFACE_MORTAR_MPP
- *CONTACT_FORMING_SURFACE_TO_SURFACE_MORTAR_THERMAL_FRICTION
- *CONTACT_FORMING_SURFACE_TO_SURFACE_MORTAR_THERMAL_FRICTION_MPP
- *CONTACT_FORMING_SURFACE_TO_SURFACE_MORTAR_THERMAL_MPP
- *CONTACT_FORMING_SURFACE_TO_SURFACE_MPP
- *CONTACT_FORMING_SURFACE_TO_SURFACE_SMOOTH
- *CONTACT_FORMING_SURFACE_TO_SURFACE_SMOOTH_MPP
- *CONTACT_FORMING_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION
- *CONTACT_FORMING_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION_MPP
- *CONTACT_FORMING_SURFACE_TO_SURFACE_SMOOTH_THERMAL_MPP
- *CONTACT_FORMING_SURFACE_TO_SURFACE_THERMAL_FRICTION
- *CONTACT_FORMING_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_FORMING_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_GUIDED_CABLE
- *CONTACT_INTERIOR
- *CONTACT_NODES_TO_SURFACE
- *CONTACT_NODES_TO_SURFACE_INTERFERENCE
- *CONTACT_NODES_TO_SURFACE_INTERFERENCE_MPP
- *CONTACT_NODES_TO_SURFACE_MPP
- *CONTACT_NODES_TO_SURFACE_SMOOTH
- *CONTACT_NODES_TO_SURFACE_SMOOTH_MPP
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_INTERFERENCE
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_INTERFERENCE_MPP
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_INTERFERENCE_THERMAL_FRICTION
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_INTERFERENCE_THERMAL_FRICTION_MPP
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_INTERFERENCE_THERMAL_MPP
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_MPP
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_MPP
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION_MPP
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_THERMAL_MPP
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_THERMAL_FRICTION
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_ONE_WAY_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_RIGID_BODY_ONE_WAY_TO_RIGID_BODY
- *CONTACT_RIGID_BODY_ONE_WAY_TO_RIGID_BODY_MPP
- *CONTACT_RIGID_BODY_TWO_WAY_TO_RIGID_BODY
- *CONTACT_RIGID_BODY_TWO_WAY_TO_RIGID_BODY_MPP
- *CONTACT_RIGID_NODES_TO_RIGID_BODY
- *CONTACT_RIGID_NODES_TO_RIGID_BODY_MPP
- *CONTACT_RIGID_SURFACE
- *CONTACT_SINGLE_EDGE
- *CONTACT_SINGLE_EDGE_MPP
- *CONTACT_SINGLE_SURFACE
- *CONTACT_SINGLE_SURFACE_MPP
- *CONTACT_SLIDING_ONLY
- *CONTACT_SLIDING_ONLY_MPP
- *CONTACT_SLIDING_ONLY_PENALTY
- *CONTACT_SLIDING_ONLY_PENALTY_MPP
- *CONTACT_SPOTWELD_BEAM_OFFSET
- *CONTACT_SPOTWELD_BEAM_OFFSET_MPP
- *CONTACT_SPOTWELD_CONSTRAINED_OFFSET
- *CONTACT_SPOTWELD_CONSTRAINED_OFFSET_MPP
- *CONTACT_SPOTWELD
- *CONTACT_SPOTWELD_MPP
- *CONTACT_SPOTWELD_WITH_TORSION
- *CONTACT_SPOTWELD_WITH_TORSION_MPP
- *CONTACT_SURFACE_TO_SURFACE_CONTRACTION_JOINT
- *CONTACT_SURFACE_TO_SURFACE_CONTRACTION_JOINT_MPP
- *CONTACT_SURFACE_TO_SURFACE_CONTRACTION_JOINT_THERMAL_FRICTION
- *CONTACT_SURFACE_TO_SURFACE_CONTRACTION_JOINT_THERMAL_FRICTION_MPP
- *CONTACT_SURFACE_TO_SURFACE_CONTRACTION_JOINT_THERMAL_MPP
- *CONTACT_SURFACE_TO_SURFACE_INTERFERENCE
- *CONTACT_SURFACE_TO_SURFACE_INTERFERENCE_MPP
- *CONTACT_SURFACE_TO_SURFACE_INTERFERENCE_THERMAL_FRICTION
- *CONTACT_SURFACE_TO_SURFACE_INTERFERENCE_THERMAL_FRICTION_MPP
- *CONTACT_SURFACE_TO_SURFACE_INTERFERENCE_THERMAL_MPP
- *CONTACT_SURFACE_TO_SURFACE_MPP
- *CONTACT_SURFACE_TO_SURFACE_SMOOTH
- *CONTACT_SURFACE_TO_SURFACE_SMOOTH_MPP
- *CONTACT_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION
- *CONTACT_SURFACE_TO_SURFACE_SMOOTH_THERMAL_FRICTION_MPP
- *CONTACT_SURFACE_TO_SURFACE_SMOOTH_THERMAL_MPP
- *CONTACT_SURFACE_TO_SURFACE_THERMAL_FRICTION
- *CONTACT_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_TIEBREAK_NODES_TO_SURFACE
- *CONTACT_TIEBREAK_NODES_TO_SURFACE_MPP
- *CONTACT_TIEBREAK_SURFACE_TO_SURFACE
- *CONTACT_TIEBREAK_SURFACE_TO_SURFACE_MPP
- *CONTACT_TIEBREAK_SURFACE_TO_SURFACE_THERMAL_FRICTION
- *CONTACT_TIEBREAK_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_TIEBREAK_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_TIED_NODES_TO_SURFACE_CONSTRAINED_OFFSET
- *CONTACT_TIED_NODES_TO_SURFACE_CONSTRAINED_OFFSET_MPP
- *CONTACT_TIED_NODES_TO_SURFACE_MPP
- *CONTACT_TIED_NODES_TO_SURFACE_OFFSET
- *CONTACT_TIED_NODES_TO_SURFACE_OFFSET_MPP
- *CONTACT_TIED_SHELL_EDGE_TO_SURFACE_BEAM_OFFSET
- *CONTACT_TIED_SHELL_EDGE_TO_SURFACE_BEAM_OFFSET_MPP
- *CONTACT_TIED_SHELL_EDGE_TO_SURFACE_CONSTRAINED_OFFSET
- *CONTACT_TIED_SHELL_EDGE_TO_SURFACE_CONSTRAINED_OFFSET_MPP
- *CONTACT_TIED_SHELL_EDGE_TO_SURFACE_MPP
- *CONTACT_TIED_SHELL_EDGE_TO_SURFACE_OFFSET
- *CONTACT_TIED_SHELL_EDGE_TO_SURFACE_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_CONSTRAINED_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_CONSTRAINED_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_CONSTRAINED_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_CONSTRAINED_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_FRICTION_CONSTRAINED_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_FRICTION_CONSTRAINED_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_FRICTION_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_FRICTION_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_FRICTION_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_FAILURE_THERMAL_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_CONSTRAINED_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_CONSTRAINED_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_FRICTION_CONSTRAINED_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_FRICTION_CONSTRAINED_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_FRICTION_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_FRICTION_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_FRICTION_OFFSET_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_MPP
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_OFFSET
- *CONTACT_TIED_SURFACE_TO_SURFACE_THERMAL_OFFSET_MPP
- *CONTROL_ACCURACY
- *CONTROL_ACOUSTIC
- *CONTROL_ADAPSTEP
- *CONTROL_ADAPTIVE
- *CONTROL_ADAPTIVE_CURVE
- *CONTROL_ALE
- *CONTROL_BULK_VISCOSITY
- *CONTROL_CHECK
- *CONTROL_CHECK_SHELL
- *CONTROL_COARSEN
- *CONTROL_CONTACT
- *CONTROL_COUPLING
- *CONTROL_CPM
- *CONTROL_CPU
- *CONTROL_DEBUG
- *CONTROL_DYNAMIC_RELAXATION
- *CONTROL_EFG
- *CONTROL_ENERGY
- *CONTROL_EXPLOSIVE_SHADOW
- *CONTROL_FORMING_AUTOCHECK
- *CONTROL_FORMING_AUTOPOSITION_PARAMETER
- *CONTROL_FORMING_AUTOPOSITION_PARAMETER_SET
- *CONTROL_FORMING_BESTFIT
- *CONTROL_FORMING_BESTFIT_VECTOR
- *CONTROL_HOURGLASS
- *CONTROL_IMPLICIT_AUTO
- *CONTROL_IMPLICIT_AUTO_DYN
- *CONTROL_IMPLICIT_BUCKLE
- *CONTROL_IMPLICIT_CONSISTENT_MASS
- *CONTROL_IMPLICIT_DYNAMICS
- *CONTROL_IMPLICIT_EIGENVALUE
- *CONTROL_IMPLICIT_FORMING
- *CONTROL_IMPLICIT_FORMING_DYN
- *CONTROL_IMPLICIT_FORMING_SPR
- *CONTROL_IMPLICIT_GENERAL
- *CONTROL_IMPLICIT_GENERAL_DYN
- *CONTROL_IMPLICIT_GENERAL_SPR
- *CONTROL_IMPLICIT_INERTIA_RELIEF
- *CONTROL_IMPLICIT_JOINTS
- *CONTROL_IMPLICIT_MODAL_DYNAMIC
- *CONTROL_IMPLICIT_MODAL_DYNAMIC_DAMPING
- *CONTROL_IMPLICIT_MODAL_DYNAMIC_DAMPING_FREQUENCY_RANGE
- *CONTROL_IMPLICIT_MODAL_DYNAMIC_DAMPING_SPECIFIC
- *CONTROL_IMPLICIT_MODAL_DYNAMIC_MODE_GENERATE
- *CONTROL_IMPLICIT_MODAL_DYNAMIC_MODE_LIST
- *CONTROL_IMPLICIT_MODES
- *CONTROL_IMPLICIT_MODES_BINARY
- *CONTROL_IMPLICIT_ORDERING
- *CONTROL_IMPLICIT_SOLUTION
- *CONTROL_IMPLICIT_SOLVER
- *CONTROL_IMPLICIT_STABILIZATION
- *CONTROL_IMPLICIT_TERMINATION
- *CONTROL_IMPLICIT_ROTATIONAL_DYNAMICS
- *CONTROL_IMPLICIT_SOLUTION_DYN
- *CONTROL_IMPLICIT_SOLUTION_SPR
- *CONTROL_IMPLICIT_SOLVER_DYN
- *CONTROL_IMPLICIT_SOLVER_SPR
- *CONTROL_IMPLICIT_STABILIZATION_DYN
- *CONTROL_IMPLICIT_STABILIZATION_SPR
- *CONTROL_IMPLICIT_STATIC_CONDENSATION
- *CONTROL_IMPLICIT_STATIC_CONDENSATION_BINARY
- *CONTROL_MAT
- *CONTROL_UNITS
- *CONTROL_MPP_CONTACT_GROUPABLE
- *CONTROL_MPP_DECOMPOSITION_ARRANGE_PARTS
- *CONTROL_MPP_DECOMPOSITION_ARRANGE_PARTS_LOCAL
- *CONTROL_MPP_DECOMPOSITION_AUTOMATIC
- *CONTROL_MPP_DECOMPOSITION_BAGREF
- *CONTROL_MPP_DECOMPOSITION_CHECK_SPEED
- *CONTROL_MPP_DECOMPOSITION_CONTACT_DISTRIBUTE
- *CONTROL_MPP_DECOMPOSITION_CONTACT_DISTRIBUTE_LOCAL
- *CONTROL_MPP_DECOMPOSITION_CONTACT_ISOLATE
- *CONTROL_MPP_DECOMPOSITION_DISABLE_UNREF_CURVES
- *CONTROL_MPP_DECOMPOSITION_DISTRIBUTE_ALE_ELEMENTS
- *CONTROL_MPP_DECOMPOSITION_DISTRIBUTE_SPH_ELEMENTS
- *CONTROL_MPP_DECOMPOSITION_ELCOST
- *CONTROL_MPP_DECOMPOSITION_FILE
- *CONTROL_MPP_DECOMPOSITION_METHOD
- *CONTROL_MPP_DECOMPOSITION_NUMPROC
- *CONTROL_MPP_DECOMPOSITION_OUTDECOMP
- *CONTROL_MPP_DECOMPOSITION_PARTS_DISTRIBUTE
- *CONTROL_MPP_DECOMPOSITION_PARTS_DISTRIBUTE_LOCAL
- *CONTROL_MPP_DECOMPOSITION_PARTSET_DISTRIBUTE
- *CONTROL_MPP_DECOMPOSITION_PARTSET_DISTRIBUTE_LOCAL
- *CONTROL_MPP_DECOMPOSITION_RCBLOG
- *CONTROL_MPP_DECOMPOSITION_SCALE_CONTACT_COST
- *CONTROL_MPP_DECOMPOSITION_SCALE_FACTOR_SPH
- *CONTROL_MPP_DECOMPOSITION_SHOW
- *CONTROL_MPP_DECOMPOSITION_TRANSFORMATION
- *CONTROL_MPP_IO_LSTC_REDUCE
- *CONTROL_MPP_IO_NOBEAMOUT
- *CONTROL_MPP_IO_NOD3DUMP
- *CONTROL_MPP_IO_NODUMP
- *CONTROL_MPP_IO_NOFULL
- *CONTROL_MPP_IO_SWAPBYTES
- *CONTROL_OUTPUT
- *CONTROL_PARALLEL
- *CONTROL_REMESHING
- *CONTROL_REMESHING_EFG
- *CONTROL_REQUIRE_REVISION
- *CONTROL_RIGID
- *CONTROL_SHELL
- *CONTROL_SOLID
- *CONTROL_SOLUTION
- *CONTROL_SPH
- *CONTROL_SPOTWELD_BEAM
- *CONTROL_STAGED_CONSTRUCTION
- *CONTROL_STRUCTURED
- *CONTROL_STRUCTURED_TERM
- *CONTROL_SUBCYCLE
- *CONTROL_SUBCYCLE_MASS_SCALED_PART
- *CONTROL_SUBCYCLE_MASS_SCALED_PART_SET
- *CONTROL_TERMINATION
- *CONTROL_THERMAL_NONLINEAR
- *CONTROL_THERMAL_SOLVER
- *CONTROL_THERMAL_TIMESTEP
- *CONTROL_TIMESTEP
- *DAMPING_FREQUENCY_RANGE
- *DAMPING_FREQUENCY_RANGE_DEFORM
- *DAMPING_GLOBAL
- *DAMPING_PART_MASS
- *DAMPING_PART_MASS_SET
- *DAMPING_PART_STIFFNESS
- *DAMPING_PART_STIFFNESS_SET
- *DAMPING_RELATIVE
- *DATABASE_ABSTAT
- *DATABASE_ABSTAT_CPM
- *DATABASE_ATDOUT
- *DATABASE_AVSFLT
- *DATABASE_BINARY_BLSTFOR
- *DATABASE_BINARY_CPMFOR
- *DATABASE_BINARY_D3CRACK
- *DATABASE_BINARY_D3DRLF
- *DATABASE_BINARY_D3DUMP
- *DATABASE_BINARY_D3PART
- *DATABASE_BINARY_D3PLOT
- *DATABASE_BINARY_D3PROP
- *DATABASE_BINARY_D3THDT
- *DATABASE_BINARY_DEMFOR
- *DATABASE_BINARY_FSIFOR
- *DATABASE_BINARY_INTFOR
- *DATABASE_BINARY_RUNRSF
- *DATABASE_BINARY_XTFILE
- *DATABASE_BNDOUT
- *DATABASE_CPM_SENSOR
- *DATABASE_CROSS_SECTION_PLANE
- *DATABASE_CROSS_SECTION_SET
- *DATABASE_CURVOUT
- *DATABASE_DCFAIL
- *DATABASE_DEFGEO
- *DATABASE_DEFORC
- *DATABASE_DISBOUT
- *DATABASE_ELOUT
- *DATABASE_EXTENT_AVS
- *DATABASE_EXTENT_BINARY
- *DATABASE_EXTENT_BINARY_COMP
- *DATABASE_EXTENT_D3PART
- *DATABASE_EXTENT_INTFOR
- *DATABASE_EXTENT_MOVIE
- *DATABASE_EXTENT_MPGS
- *DATABASE_EXTENT_SSSTAT
- *DATABASE_EXTENT_SSSTAT_ID
- *DATABASE_FORMAT
- *DATABASE_FREQUENCY_ASCII_ELOUT_PSD
- *DATABASE_FREQUENCY_ASCII_ELOUT_SSD
- *DATABASE_FREQUENCY_ASCII_ELOUT_SSD_MODAL_CONTRIBUTION
- *DATABASE_FREQUENCY_ASCII_NODOUT_PSD
- *DATABASE_FREQUENCY_ASCII_NODOUT_SSD
- *DATABASE_FREQUENCY_ASCII_NODOUT_SSD_MODAL_CONTRIBUTION
- *DATABASE_FREQUENCY_BINARY_D3ACC
- *DATABASE_FREQUENCY_BINARY_D3ACS
- *DATABASE_FREQUENCY_BINARY_D3ATV
- *DATABASE_FREQUENCY_BINARY_D3FTG
- *DATABASE_FREQUENCY_BINARY_D3PSD
- *DATABASE_FREQUENCY_BINARY_D3RMS
- *DATABASE_FREQUENCY_BINARY_D3SPCM
- *DATABASE_FREQUENCY_BINARY_D3SSD
- *DATABASE_FREQUENCY_BINARY_D3ZCF
- *DATABASE_FSI
- *DATABASE_FSI_SENSOR
- *DATABASE_GCEOUT
- *DATABASE_GLSTAT
- *DATABASE_GLSTAT_MASS_PROPERTIES
- *DATABASE_H3OUT
- *DATABASE_HISTORY_BEAM
- *DATABASE_HISTORY_BEAM_SET
- *DATABASE_HISTORY_DISCRETE
- *DATABASE_HISTORY_DISCRETE_SET
- *DATABASE_HISTORY_NODE
- *DATABASE_HISTORY_NODE_LOCAL
- *DATABASE_HISTORY_NODE_SET
- *DATABASE_HISTORY_NODE_SET_LOCAL
- *DATABASE_HISTORY_SEATBELT
- *DATABASE_HISTORY_SHELL
- *DATABASE_HISTORY_SHELL_SET
- *DATABASE_HISTORY_SOLID
- *DATABASE_HISTORY_SOLID_SET
- *DATABASE_HISTORY_SPH
- *DATABASE_HISTORY_SPH_SET
- *DATABASE_HISTORY_TSHELL
- *DATABASE_HISTORY_TSHELL_SET
- *DATABASE_JNTFORC
- *DATABASE_MASSOUT
- *DATABASE_MATSUM
- *DATABASE_MOVIE
- *DATABASE_MPGS
- *DATABASE_NCFORC
- *DATABASE_NCFORC_FILTER
- *DATABASE_NODAL_FORCE_GROUP
- *DATABASE_NODFOR
- *DATABASE_NODOUT
- *DATABASE_RBDOUT
- *DATABASE_RCFORC
- *DATABASE_RWFORC
- *DATABASE_SBTOUT
- *DATABASE_SECFORC
- *DATABASE_SLEOUT
- *DATABASE_SPCFORC
- *DATABASE_SPHOUT
- *DATABASE_SPRING_FORWARD
- *DATABASE_SSSTAT
- *DATABASE_SSSTAT_MASS_PROPERTIES
- *DATABASE_SUPERPLASTIC_FORMING
- *DATABASE_SWFORC
- *DATABASE_TPRINT
- *DATABASE_TRACER
- *DATABASE_TRHIST
- *DEFINE_ALEBAG_BAG
- *DEFINE_ALEBAG_HOLE
- *DEFINE_ALEBAG_INFLATOR
- *DEFINE_BOX
- *DEFINE_BOX_ADAPTIVE
- *DEFINE_BOX_ADAPTIVE_LOCAL
- *DEFINE_BOX_COARSEN
- *DEFINE_BOX_COARSEN_LOCAL
- *DEFINE_BOX_DRAWBEAD
- *DEFINE_BOX_LOCAL
- *DEFINE_BOX_SPH
- *DEFINE_BOX_SPH_LOCAL
- *DEFINE_CONNECTION_PROPERTIES
- *DEFINE_CONNECTION_PROPERTIES_ADD
- *DEFINE_COORDINATE_NODES
- *DEFINE_COORDINATE_SYSTEM
- *DEFINE_COORDINATE_VECTOR
- *DEFINE_CPM_BAG_INTERACTION
- *DEFINE_CPM_CHAMBER
- *DEFINE_CPM_GAS_PROPERTIES
- *DEFINE_CPM_VENT
- *DEFINE_CURVE
- *DEFINE_CURVE_FEEDBACK
- *DEFINE_CURVE_FUNCTION
- *DEFINE_CURVE_SMOOTH
- *DEFINE_CURVE_TRIM
- *DEFINE_CURVE_TRIM_3D
- *DEFINE_FRICTION
- *DEFINE_FRICTION_ORIENTATION
- *DEFINE_FUNCTION
- *DEFINE_HEX_SPOTWELD_ASSEMBLY
- *DEFINE_SD_ORIENTATION
- *DEFINE_STOCHASTIC_VARIATION
- *DEFINE_TABLE
- *DEFINE_TABLE_2D
- *DEFINE_TABLE_3D
- *DEFINE_TRANSFORMATION
- *DEFINE_VECTOR
- *DEFINE_VECTOR_NODES
- *DEFORMABLE_TO_RIGID
- *DEFORMABLE_TO_RIGID_AUTOMATIC
- *DEFORMABLE_TO_RIGID_INERTIA
- *ELEMENT_BEAM
- *ELEMENT_BEAM_ORIENTATION
- *ELEMENT_BEAM_PID
- *ELEMENT_BEAM_PID_ORIENTATION
- *ELEMENT_BEAM_PID_SCALAR
- *ELEMENT_BEAM_PID_SCALR
- *ELEMENT_BEAM_SCALAR
- *ELEMENT_BEAM_SCALAR_ORIENTATION
- *ELEMENT_BEAM_SCALR
- *ELEMENT_BEAM_SCALR_ORIENTATION
- *ELEMENT_BEAM_SECTION
- *ELEMENT_BEAM_SECTION_ORIENTATION
- *ELEMENT_BEAM_SECTION_PID
- *ELEMENT_BEAM_THICKNESS
- *ELEMENT_BEAM_THICKNESS_ORIENTATION
- *ELEMENT_BEAM_THICKNESS_PID
- *ELEMENT_BEAM_THICKNESS_SCALAR
- *ELEMENT_DISCRETE
- *ELEMENT_DISCRETE_LCO
- *ELEMENT_INERTIA
- *ELEMENT_INERTIA_OFFSET
- *ELEMENT_MASS
- *ELEMENT_MASS_NODE_SET
- *ELEMENT_MASS_PART
- *ELEMENT_MASS_PART_SET
- *ELEMENT_PLOTEL
- *ELEMENT_SEATBELT
- *ELEMENT_SEATBELT_ACCELEROMETER
- *ELEMENT_SEATBELT_PRETENSIONER
- *ELEMENT_SEATBELT_RETRACTOR
- *ELEMENT_SEATBELT_SENSOR
- *ELEMENT_SEATBELT_SLIPRING
- *ELEMENT_SHELL
- *ELEMENT_SHELL_BETA
- *ELEMENT_SHELL_BETA_OFFSET
- *ELEMENT_SHELL_BETA_COMPOSITE_LONG
- *ELEMENT_SHELL_COMPOSITE
- *ELEMENT_SHELL_COMPOSITE_LONG
- *ELEMENT_SHELL_MCID
- *ELEMENT_SHELL_MCID_COMPOSITE_LONG
- *ELEMENT_SHELL_MICD_OFFSET
- *ELEMENT_SHELL_OFFSET
- *ELEMENT_SHELL_SHL4_TO_SHL8
- *ELEMENT_SHELL_THICKNESS
- *ELEMENT_SHELL_THICKNESS_BETA
- *ELEMENT_SHELL_THICKNESS_BETA_OFFSET
- *ELEMENT_SHELL_THICKNESS_MCID
- *ELEMENT_SHELL_THICKNESS_MCID_OFFSET
- *ELEMENT_SOLID
- *ELEMENT_SOLID_ORTHO
- *ELEMENT_SOLID_TET4TOTET10
- *ELEMENT_SOLID_H20
- *ELEMENT_SOLID_H8TOH20
- *ELEMENT_SPH
- *ELEMENT_TSHELL
- *ELEMENT_TSHELL 6N
- *ELEMENT_TSHELL 8N
- *END
- *EOS_GRUNEISEN
- *EOS_IDEAL_GAS
- *EOS_IGNITION_AND_GROWTH_OF_REACTION_IN_HE
- *EOS_JWL
- *EOS_LINEAR_POLYNOMIAL
- *EOS_LINEAR_POLYNOMIAL_WITH_ENERGY_LEAK
- *EOS_PROPELLANT_DEFLAGRATION
- *EOS_RATIO_OF_POLYNOMIALS
- *EOS_SACK_TUESDAY
- *EOS_TABULATED
- *EOS_TABULATED_COMPACTION
- *EOS_TENSOR_PORE_COLLAPSE
- *HOURGLASS
- *INCLUDE
- *INCLUDE_PATH
- *INCLUDE_TRANSFORM
- *INCLUDE_STAMPED_PART
- *INCLUDE_STAMPED_PART_SET
- *INCLUDE_COMPENSATION_BLANK_BEFORE_SPRINGBACK
- *INCLUDE_COMPENSATION_BLANK_AFTER_SPRINGBACK
- *INCLUDE_COMPENSATION_DESIRED_BLANK_SHAPE
- *INCLUDE_COMPENSATION_COMPENSATED_SHAPE
- *INCLUDE_COMPENSATION_CURRENT_TOOLS
- *INITIAL_ALE_MAPPING
- *INITIAL_AXIAL_FORCE_BEAM
- *INITIAL_CONTACT_WEAR
- *INITIAL_CRASHFRONT
- *INITIAL_DETONATION
- *INITIAL_FOAM_REFERENCE_GEOMETRY
- *INITIAL_FOAM_REFERENCE_GEOMETRY_RAMP
- *INITIAL_GAS_MIXTURE
- *INITIAL_STRAIN_SHELL
- *INITIAL_STRAIN_SOLID
- *INITIAL_STRESS_BEAM
- *INITIAL_STRESS_SECTION
- *INITIAL_STRESS_SHELL
- *INITIAL_STRESS_SOLID
- *INITIAL_TEMPERATURE_NODE
- *INITIAL_TEMPERATURE_SET
- *INITIAL_VEHICLE_KINEMATICS
- *INITIAL_VELOCITY
- *INITIAL_VELOCITY_GENERATION
- *INITIAL_VELOCITY_GENERATION_START_TIME
- *INITIAL_VELOCITY_NODE
- *INITIAL_VELOCITY_RIGID_BODY
- *INITIAL_VOID_PART
- *INITIAL_VOID_SET
- *INITIAL_VOLUME_FRACTION
- *INITIAL_VOLUME_FRACTION_GEOMETRY
- *INITIAL_VOLUME_FRACTION_NALEGP
- *INTEGRATION_BEAM
- *INTEGRATION_SHELL
- *INTERFACE_COMPENSATION_NEW
- *INTERFACE_COMPENSATION_NEW_ACCELERATOR
- *INTERFACE_COMPENSATION_NEW_LOCAL_SMOOTH
- *INTERFACE_COMPENSATION_NEW_MULTI_STEPS
- *INTERFACE_COMPENSATION_NEW_PART_CHANGE
- *INTERFACE_COMPENSATION_NEW_REFINE_RIGID
- *INTERFACE_COMPONENT_FILE
- *INTERFACE_COMPONENT_NODE
- *INTERFACE_COMPONENT_SEGMENT
- *INTERFACE_LINKING_DISCRETE_NODE_NODE
- *INTERFACE_LINKING_DISCRETE_NODE_SET
- *INTERFACE_LINKING_EDGE
- *INTERFACE_LINKING_FILE
- *INTERFACE_LINKING_NODE_NODE
- *INTERFACE_LINKING_NODE_SET
- *INTERFACE_LINKING_NODE_LOCAL
- *INTERFACE_LINKING_NODE_SET_LOCAL
- *INTERFACE_LINKING_SEGMENT
- *INTERFACE_SPRINGBACK_LSDYNA
- *INTERFACE_SPRINGBACK_LSDYNA_NOTHICKNESS
- *INTERFACE_SPRINGBACK_LSDYNA_THICKNESS
- *INTERFACE_SPRINGBACK_NASTRAN
- *INTERFACE_SPRINGBACK_NASTRAN_NOTHICKNESS
- *INTERFACE_SPRINGBACK_NASTRAN_THICKNESS
- *INTERFACE_SPRINGBACK_SEAMLESS
- *INTERFACE_SPRINGBACK_SEAMLESS_NOTHICKNESS
- *INTERFACE_SPRINGBACK_SEAMLESS_THICKNESS
- *KEYWORD
- *KEYWORD_ID
- *LOAD_BEAM_ELEMENT
- *LOAD_BEAM_SET
- *LOAD_BLAST
- *LOAD_BODY_GENERALIZED
- *LOAD_BODY_GENERALIZED_SET_NODE
- *LOAD_BODY_GENERALIZED_SET_PART
- *LOAD_BODY_PARTS
- *LOAD_BODY_RX
- *LOAD_BODY_RY
- *LOAD_BODY_RZ
- *LOAD_BODY_VECTOR
- *LOAD_BODY_X
- *LOAD_BODY_Y
- *LOAD_BODY_Z
- *LOAD_BRODE
- *LOAD_GRAVITY_PART
- *LOAD_GRAVITY_PART_SET
- *LOAD_MASK
- *LOAD_NODE_POINT
- *LOAD_NODE_SET
- *LOAD_RIGID_BODY
- *LOAD_SEGMENT
- *LOAD_SEGMENT_SET
- *LOAD_SHELL_ELEMENT
- *LOAD_SHELL_SET
- *LOAD_SUPERPLASTIC_FORMING
- *LOAD_THERMAL_CONSTANT
- *LOAD_THERMAL_CONSTANT_NODE
- *LOAD_THERMAL_LOAD_CURVE
- *LOAD_THERMAL_VARIABLE
- *LOAD_THERMAL_VARIABLE_NODE
- *NODE
- *NODE_RIGID_SURFACE
- *NODE_TRANSFORM
- *PARAMETER
- *PARAMETER_LOCAL
- *PARAMETER_EXPRESSION
- *PARAMETER_EXPRESSION_LOCAL
- *PART
- *PART_COMPOSITE
- *PART_COMPOSITE_CONTACT
- *PART_COMPOSITE_LONG
- *PART_COMPOSITE_TSHELL
- *PART_CONTACT
- *PART_CONTACT_PRINT
- *PART_INERTIA
- *PART_INERTIA_PRINT
- *PART_INERTIA_CONTACT
- *PART_INERTIA_CONTACT_PRINT
- *PART_MOVE
- *PART_PRINT
- *PART_REPOSITION
- *PART_REPOSITION_PRINT
- *PART_REPOSITION_CONTACT
- *PART_REPOSITION_CONTACT_PRINT
- *PART_SENSOR
- *RIGIDWALL_GEOMETRIC_CYLINDER_DISPLAY
- *RIGIDWALL_GEOMETRIC_CYLINDER_MOTION_DISPLAY
- *RIGIDWALL_GEOMETRIC_FLAT(FINITE)
- *RIGIDWALL_GEOMETRIC_FLAT_DISPLAY(FINITE)
- *RIGIDWALL_GEOMETRIC_FLAT_MOTION(FINITE)
- *RIGIDWALL_GEOMETRIC_FLAT_MOTION_DISPLAY(FINITE)
- *RIGIDWALL_GEOMETRIC_PRISM(FINITE)
- *RIGIDWALL_GEOMETRIC_PRISM_DISPLAY(FINITE)
- *RIGIDWALL_GEOMETRIC_PRISM_MOTION(FINITE)
- *RIGIDWALL_GEOMETRIC_PRISM_MOTION_DISPLAY(FINITE)
- *RIGIDWALL_GEOMETRIC_SPHERE_DISPLAY
- *RIGIDWALL_GEOMETRIC_SPHERE_MOTION_DISPLAY
- *RIGIDWALL_PLANAR_FINITE_FORCES
- *RIGIDWALL_PLANAR_FINITE_MOVING_DISPLAY
- *RIGIDWALL_PLANAR_FINITE_MOVING_FORCES_DISPLAY
- *RIGIDWALL_PLANAR_FORCES
- *RIGIDWALL_PLANAR
- *RIGIDWALL_PLANAR_MOVING_DISPLAY
- *RIGIDWALL_PLANAR_MOVING_FORCES_DISPLAY
- *RIGIDWALL_PLANAR_ORTHO_FINITE_FORCES
- *RIGIDWALL_PLANAR_ORTHO_FORCES
- *SECTION_ALE1D
- *SECTION_ALE2D
- *SECTION_BEAM
- *SECTION_BEAM_AISC
- *SECTION_DISCRETE
- *SECTION_POINT_SOURCE
- *SECTION_POINT_SOURCE_MIXTURE
- *SECTION_SEATBELT
- *SECTION_SHELL
- *SECTION_SHELL_EFG
- *SECTION_SHELL_THERMAL
- *SECTION_SHELL_XFEM
- *SECTION_SOLID
- *SECTION_SOLID_EFG
- *SECTION_SPH
- *SECTION_SPH_USER
- *SECTION_TSHELL
- *SENSOR_CONTROL
- *SENSOR_DEFINE_CALC-MATH
- *SENSOR_DEFINE_ELEMENT
- *SENSOR_DEFINE_ELEMENT_SET
- *SENSOR_DEFINE_FORCE
- *SENSOR_DEFINE_NODE
- *SENSOR_DEFINE_NODE_SET
- *SENSOR_SWITCH
- *SENSOR_SWITCH_CALC-LOGIC
- *SET_BEAM
- *SET_BEAM_ADD
- *SET_BEAM_COLLECT
- *SET_BEAM_COLLECT(MASTER)
- *SET_BEAM_GENERAL
- *SET_BEAM_GENERAL_COLLECT
- *SET_BEAM_GENERATE
- *SET_BEAM_GENERATE_COLLECT
- *SET_DISCRETE
- *SET_DISCRETE_ADD
- *SET_DISCRETE_GENERAL
- *SET_DISCRETE_GENERATE
- *SET_MULTI-MATERIAL_GROUP_LIST
- *SET_NODE_ADD
- *SET_NODE_ADD_ADVANCED
- *SET_NODE_COLLECT(MASTER)
- *SET_NODE_COLUMN
- *SET_NODE_COLUMN_COLLECT
- *SET_NODE_GENERAL
- *SET_NODE_GENERAL_COLLECT
- *SET_NODE_LIST
- *SET_NODE_LIST_COLLECT
- *SET_NODE_LIST_GENERATE
- *SET_NODE_LIST_GENERATE_COLLECT
- *SET_PART_ADD
- *SET_PART_COLUMN
- *SET_PART_COLUMN_COLLECT
- *SET_PART_LIST
- *SET_PART_LIST_COLLECT
- *SET_PART_LIST_GENERATE
- *SET_PART_LIST_GENERATE_COLLECT
- *SET_PART_COLLECT(MASTER)
- *SET_SEGMENT
- *SET_SEGMENT_ADD
- *SET_SEGMENT_COLLECT
- *SET_SEGMENT_INTERSECT
- *SET_SEGMENT_GENERAL
- *SET_SHELL_LIST
- *SET_SHELL_LIST_COLLECT
- *SET_SHELL_ADD
- *SET_SHELL_COLUMN
- *SET_SHELL_GENERAL
- *SET_SHELL_LIST_GENERATE
- *SET_SOLID
- *SET_SOLID_ADD
- *SET_SOLID_GENERAL
- *SET_SOLID_GENERATE
- *SET_TSHELL
- *SET_TSHELL_GENERAL
- *SET_TSHELL_GENERATE
- *SET_TSHELL_ADD
- *STRESS_INITIALIZATION
- *STRESS_INITIALIZATION_DISCRETE
- *STRESS_INITIALIZATION_SEATBELT
- *TERMINATION_BODY
- *TERMINATION_CONTACT
- *TERMINATION_CURVE
- *TERMINATION_DELETED_SHELLS
- *TERMINATION_DELETED_SHELLS_SET
- *TERMINATION_DELETED_SOLIDS
- *TERMINATION_DELETED_SOLIDS_SET
- *TERMINATION_NODE
- *TERMINATION_SENSOR
- *TITLE
- *MAT_ADD_AIRBAG_POROSITY_LEAKAGE
- *MAT_ADD_COHESIVE
- *MAT_ADD_EROSION
- *MAT_ADD_FATIGUE
- *MAT_ADD_GENERALIZED_DAMAGE
- *MAT_ADD_PERMEABILITY
- *MAT_ADD_PORE_AIR
- *MAT_ADD_THERMAL_EXPANSION
- 001 - *MAT_ELASTIC
- 001 - *MAT_ELASTIC_FLUID
- 002_ANIS - *MAT_ANISOTROPIC_ELASTIC (*MAT_002_ANIS)
- 002 - *MAT_ORTHOTROPIC_ELASTIC (*MAT_002)
- 003 - *MAT_PLASTIC_KINEMATIC
- 004 - *MAT_ELASTIC_PLASTIC_THERMAL
- 005 - *MAT_SOIL_AND_FOAM
- 006 - *MAT_VISCOELASTIC
- 007 - *MAT_BLATZ-KO_RUBBER
- 008 - *MAT_HIGH_EXPLOSIVE_BURN
- 009 - *MAT_NULL
- 010 - *MAT_ELASTIC_PLASTIC_HYDRO
- 010 - *MAT_ELASTIC_PLASTIC_HYDRO_SPALL
- 011 - *MAT_STEINBERG
- 011 - *MAT_STEINBERG_LUND
- 012 - *MAT_ISOTROPIC_ELASTIC_PLASTIC
- 013 - *MAT_ISOTROPIC_ELASTIC_FAILURE
- 014 - *MAT_SOIL_AND_FOAM_FAILURE
- 015 - *MAT_JOHNSON_COOK
- 015 - *MAT_JOHNSON_COOK_STOCHASTIC
- 016 - *MAT_PSEUDO_TENSOR
- 017 - *MAT_ORIENTED_CRACK
- 018 - *MAT_POWER_LAW_PLASTICITY
- 019 - *MAT_STRAIN_RATE_DEPENDENT_PLASTICITY
- 020 - *MAT_RIGID
- 021 - *MAT_ORTHOTROPIC_THERMAL
- 021 - *MAT_ORTHOTROPIC_THERMAL_CURING
- 021 - *MAT_ORTHOTROPIC_THERMAL_FAILURE
- 022 - *MAT_COMPOSITE_DAMAGE
- 023 - *MAT_TEMPERATURE_DEPENDENT_ORTHOTROPIC
- 024 - *MAT_PIECEWISE_LINEAR_PLASTICITY
- 024 - *MAT_PIECEWISE_LINEAR_PLASTICITY_HAZ
- 024 - *MAT_PIECEWISE_LINEAR_PLASTICITY_LOG_INTERPOLATION
- 024 - *MAT_PIECEWISE_LINEAR_PLASTICITY_MIDFAIL
- 024 - *MAT_PIECEWISE_LINEAR_PLASTICITY_STOCHASTIC
- 024 - *MAT_PIECEWISE_LINEAR_PLASTICITY_2D
- 025 - *MAT_GEOLOGIC_CAP_MODEL
- 026 - *MAT_HONEYCOMB
- 027 - *MAT_MOONEY-RIVLIN_RUBBER
- 028 - *MAT_RESULTANT_PLASTICITY
- 029 - *MAT_FORCE_LIMITED
- 030 - *MAT_SHAPE_MEMORY
- 031 - *MAT_FRAZER_NASH_RUBBER_MODEL
- 032 - *MAT_LAMINATED_GLASS
- 033 - *MAT_BARLAT_ANISOTROPIC_PLASTICITY
- 033_96 - *MAT_BARLAT_YLD96
- 034 - *MAT_FABRIC
- 034M - *MAT_FABRIC_MAP
- 036 - *MAT_3-PARAMETER_BARLAT
- 036 - *MAT_3-PARAMETER_BARLAT_NLP
- 036E - *MAT_EXTENDED_3-PARAMETER_BARLAT
- 037 - *MAT_TRANSVERSELY_ANISOTROPIC_ELASTIC_PLASTIC
- 037 - *MAT_TRANSVERSELY_ANISOTROPIC_ELASTIC_PLASTIC_ECHANGE
- 037 - *MAT_TRANSVERSELY_ANISOTROPIC_ELASTIC_PLASTIC_NLP_FAILURE
- 037 - *MAT_TRANSVERSELY_ANISOTROPIC_ELASTIC_PLASTIC_NLP2
- 038 - *MAT_BLATZ-KO_FOAM
- 039 - *MAT_FLD_TRANSVERSELY_ANISOTROPIC
- 040 - *MAT_NONLINEAR_ORTHOTROPIC
- 041-050- *MAT_USER_DEFINED_MATERIAL_MODELS
- 051 - *MAT_BAMMAN
- 052 - *MAT_BAMMAN_DAMAGE
- 053 - *MAT_CLOSED_CELL_FOAM
- 054-055 - *MAT_ENHANCED_COMPOSITE_DAMAGE
- 057 - *MAT_LOW_DENSITY_FOAM
- 058 - *MAT_LAMINATED_COMPOSITE_FABRIC
- 059 - *MAT_COMPOSITE_FAILURE_SHELL_MODEL
- 059 - *MAT_COMPOSITE_FAILURE_SOLID_MODEL
- 059 - *MAT_COMPOSITE_FAILURE_SPH_MODEL
- 060 - *MAT_ELASTIC_WITH_VISCOCITY
- 060C- *MAT_ELASTIC_WITH_VISCOSITY_CURVE
- 061 - *MAT_KELVIN-MAXWELL_VISCOELASTIC
- 062 - *MAT_VISCOUS_FOAM
- 063 - *MAT_CRUSHABLE_FOAM
- 064 - *MAT_RATE_SENSITIVE_POWERLAW_PLASTICITY
- 065 - *MAT_MODIFIED_ZERILLI_ARMSTRONG
- 066 - *MAT_LINEAR_ELASTIC_DISCRETE_BEAM
- 067 - *MAT_NONLINEAR_ELASTIC_DISCRETE_BEAM
- 068 - *MAT_NONLINEAR_PLASTIC_DISCRETE_BEAM
- 069 - *MAT_SID_DAMPER_DISCRETE_BEAM
- 070 - *MAT_HYDRAULIC_GAS_DAMPER_DISCRETE
- 071 - *MAT_CABLE_DISCRETE_BEAM
- 072 - *MAT_CONCRETE_DAMAGE
- 072R3 - *MAT_CONCRETE_DAMAGE_REL3
- 073 - *MAT_LOW_DENSITY_VISCOUS_FOAM
- 074 - *MAT_ELASTIC_SPRING_DISCRETE_BEAM
- 075 - *MAT_BILKU-DUBOIS_FOAM
- 076 - *MAT_GENERAL_VISCOELASTIC
- 076 - *MAT_GENERAL_VISCOELASTIC_MOISTURE
- 077_H - *MAT_HYPERELASTIC_RUBBER
- 077_O - *MAT_OGDEN_RUBBER
- 078 - *MAT_SOIL_CONCRETE
- 079 - *MAT_HYSTERETIC_SOIL
- 080 - *MAT_RAMBERG-OSGOOD
- 081,082 - *MAT_PLASTICITY_WITH_DAMAGE
- 081,082 - *MAT_PLASTICITY_WITH_DAMAGE_ORTHO
- 081,082 - *MAT_PLASTICITY_WITH_DAMAGE_ORTHO_RCDC
- 081,082 - *MAT_PLASTICITY_WITH_DAMAGE_STOCHASTIC
- 083 - *MAT_FU_CHANG_FOAM
- 083 - *MAT_FU_CHANG_FOAM_DAMAGE_DECAY
- 083 - *MAT_FU_CHANG_FOAM_LOG_LOG_INTERPOLATION
- 084_085 - *MAT_WINFRITH_CONCRETE
- 086 - *MAT_ORTHOTROPIC_VISCOELASTIC
- 087 - *MAT_CELLULAR_RUBBER
- 088 - *MAT_MTS
- 089 - *MAT_PLASTICITY_POLYMER
- 090- *MAT_ACOUSTIC
- 093 - *MAT_ELASTIC_6DOF_SPRING_DISCRETE_BEAM
- 094 - *MAT_INELASTIC_SPRING_DISCRETE_BEAM
- 095 - *MAT_INELASTIC_6DOF_SPRING_DISCRETE_BEAM
- 096 - *MAT_BRITTLE_DAMAGE
- 097 - *MAT_GENERAL_JOINT_DISCRETE_BEAM
- 098 - *MAT_SIMPLIFIED_JOHNSON_COOK
- 098 - *MAT_SIMPLIFIED_JOHNSON_COOK_STOCHASTIC
- 099 - *MAT_SIMPLIFIED_JOHNSON_COOK_ORTHOTROPIC_DAMAGE
- 100 - *MAT_SPOTWELD
- 100 - *MAT_SPOTWELD_DAMAGE-FAILURE
- 100_DA - *MAT_SPOTWELD_DAIMLERCHRYSLER
- 101 - *MAT_GEPLASTIC_SRATE_2000a
- 102 - *MAT_INV_HYPERBOLIC_SIN
- 103 - *MAT_ANISOTROPIC_VISCOPLASTIC
- 103P - *MAT_ANISOTROPIC_PLASTIC
- 104 - *MAT_DAMAGE_1
- 105 - *MAT_DAMAGE_2
- 106 - *MAT_ELASTIC_VISCOPLASTIC_THERMAL
- 110 - *MAT_JOHNSON_HOLMQUIST_CERAMICS
- 111 - *MAT_JOHNSON_HOLMQUIST_CONCRETE
- 112 - *MAT_FINITE_ELASTIC_STRAIN_PLASTICITY
- 113 - *MAT_TRIP
- 114 - *MAT_LAYERED_LINEAR_PLASTICITY
- 115 - *MAT_UNIFIED_CREEP
- 115_O - *MAT_UNIFIED_CREEP_ORTHO
- 116 - *MAT_COMPOSITE_LAYUP
- 117 - *MAT_COMPOSITE_MATRIX
- 119 - *MAT_GENERAL_NONLINEAR_6DOF_DISCRETE_BEAM
- 120 - *MAT_GURSON
- 120B - *MAT_GURSON_JC
- 120C - *MAT_GURSON_RCDC
- 121 - *MAT_GENERAL_NONLINEAR_1DOF_DISCRETE_BEAM
- 122 - *MAT_HILL_3R
- 122_3D - *MAT_HILL_3R_3D
- 123 - *MAT_MODIFIED_PIECEWISE_LINEAR_PLASTICITY_STOCHASTIC
- 123 - *MAT_MODIFIED_PIECEWISE_LINEAR_PLASTICITY_RATE
- 123 - *MAT_MODIFIED_PIECEWISE_LINEAR_PLASTICITY_RTCL
- 124 - *MAT_PLASTICITY_COMPRESSION_TENSION
- 125 - *MAT_KINEMATIC_HARDENING_TRANSVERSELY_ANISOTROPIC
- 125 - *MAT_KINEMATIC_HARDENING_TRANSVERSELY_ANISOTROPIC_NLP
- 126 - *MAT_MODIFIED_HONEYCOMB
- 127 - *MAT_ARRUDA_BOYCE_RUBBER
- 130 - *MAT_SPECIAL_ORTHOTROPIC
- 133 - *MAT_BARLAT_YLD2000
- 135 - *MAT_WTM_STM
- 135 - *MAT_WTM_STM_PLC
- 136 - *MAT_CORUS_VEGTER
- 138 - *MAT_COHESIVE_MIXED_MODE
- 140 - *MAT_VACUUM
- 141 - *MAT_RATE_SENSITIVE_POLYMER
- 142 - *MAT_TRANSVERSELY_ANISOTROPIC_CRUSHABLE_FOAM
- 143 - *MAT_WOOD
- 143 - *MAT_WOOD_FIR
- 143 - *MAT_WOOD_PINE
- 145 - *MAT_SCHWER_MURRAY_CAP_MODEL
- 146 - *MAT_1DOF_GENERALIZED_SPRING
- 148 - *MAT_GAS_MIXTURE
- 151 - *MAT_EMMI
- 154 - *MAT_DESHPANDE_FLECK_FOAM
- 155 - *MAT_PLASTICITY_COMPRESSION_TENSION_EOS
- 157 - *MAT_ANISOTROPIC_ELASTIC_PLASTIC
- 159 - *MAT_CSCM
- 159 - *MAT_CSCM_CONCRETE
- 160 - *MAT_ALE_INCOMPRESSIBLE
- 161 - *MAT_COMPOSITE_MSC
- 162 - *MAT_COMPOSITE_MSC_DMG
- 163 - *MAT_MODIFIED_CRUSHABLE_FOAM
- 165 - *MAT_PLASTIC_NONLINEAR_KINEMATIC
- 165B - *MAT_PLASTIC_NONLINEAR_KINEMATIC_B
- 166 - *MAT_MOMENT_CURVATURE_BEAM
- 168 - *MAT_POLYMER
- 169 - *MAT_ARUP_ADHESIVE
- 170 - *MAT_RESULTANT_ANISOTROPIC
- 172 - *MAT_CONCRETE_EC2
- 177 - *MAT_HILL_FOAM
- 178 - *MAT_VISCOELASTIC_HILL_FOAM
- 179 - *MAT_LOW_DENSITY_SYNTHETIC_FOAM
- 179 - *MAT_LOW_DENSITY_SYNTHETIC_FOAM_WITH_FAILURE
- 180 - *MAT_LOW_DENSITY_SYNTHETIC_FOAM_ORTHO
- 180 - *MAT_LOW_DENSITY_SYNTHETIC_FOAM_ORTHO_WITH_FAILURE
- 181 - *MAT_SIMPLIFIED_RUBBER_FOAM
- 181 - *MAT_SIMPLIFIED_RUBBER_FOAM_LOG_LOG_INTERPOLATION
- 181 - *MAT_SIMPLIFIED_RUBBER_FOAM_WITH_FAILURE
- 183 - *MAT_SIMPLIFIED_RUBBER_WITH_DAMAGE
- 183 - *MAT_SIMPLIFIED_RUBBER_WITH_DAMAGE_LOG_LOG_INTERPOLATION
- 184 - *MAT_COHESIVE_ELASTIC
- 185 - *MAT_COHESIVE_TH
- 186 - *MAT_COHESIVE_GENERAL
- 187 - *MAT_SAMP-1
- 188 - *MAT_THERMO_ELASTO_VISCOPLASTIC_CREEP
- 189 - *MAT_ANISOTROPIC_THERMOELASTIC
- 190 - *MAT_FLD_3-PARAMETER_BARLAT
- 191 - *MAT_SEISMIC_BEAM
- 193 - *MAT_DRUCKER_PRAGER
- 196 - *MAT_GENERAL_SPRING_DISCRETE_BEAM
- 202 - *MAT_STEEL_EC3
- 208 - *MAT_BOLT_BEAM
- 211 - *MAT_SPR_JLR
- 214 - *MAT_DRY_FABRIC
- 215 - *MAT_4A_MICROMEC
- 219 - *MAT_CODAM2
- 220 - *MAT_RIGID_DISCRETE
- 221 - *MAT_ORTHOTROPIC_SIMPLIFIED_DAMAGE
- 224 - *MAT_TABULATED_JOHNSON_COOK
- 224_GYS - *MAT_TABULATED_JOHNSON_COOK_GYS
- 225 - *MAT_VISCOPLASTIC_MIXED_HARDENING
- 226 - *MAT_KINEMATIC_HARDENING_BARLAT89
- 230 - *MAT_PML_ELASTIC
- 230 - *MAT_PML_ELASTIC_FLUID
- 234 - *MAT_VISCOELASTIC_LOOSE_FABRIC
- 235 - *MAT_MICROMECHANICS_DRY_FABRIC
- 240 - *MAT_COHESIVE_MIXED_MODE_ELASTOPLASTIC_RATE
- 241 - *MAT_JOHNSON_HOLMQUIST_JH1
- 242 - *MAT_KINEMATIC_HARDENING_BARLAT2000
- 243 - *MAT_HILL_90
- 244 - *MAT_UHS_STEEL
- 248 - *MAT_PHS_BMW
- 249 - *MAT_REINFORCED_THERMOPLASTIC
- 249_UDFIBER - *MAT_REINFORCED_THERMOPLASTIC_UDFIBER
- 251 - *MAT_TAILORED_PROPERTIES
- 252 - *MAT_TOUGHENED_ADHESIVE_POLYMER
- 254 - *MAT_GENERALIZED_PHASE_CHANGE
- 255 - *MAT_PIECEWISE_LINEAR_PLASTIC_THERMAL
- 260A - *MAT_STOUGHTON_NON_ASSOCIATED_FLOW
- 260A - *MAT_STOUGHTON_NON_ASSOCIATED_FLOW_XUE
- 260B - *MAT_MOHR_NON_ASSOCIATED_FLOW
- 260B - *MAT_MOHR_NON_ASSOCIATED_FLOW_XUE
- 261 - *MAT_LAMINATED_FRACTURE_DAIMLER_PINHO
- 262 - *MAT_LAMINATED_FRACTURE_DAIMLER_CAMANHO
- 264 - *MAT_TABULATED_JOHNSON_COOK_ORTHO_PLASTICITY
- 270 - *MAT_CWM
- 271 - *MAT_POWDER
- 274 - *MAT_PAPER
- 275 - *MAT_SMOOTH_VISCOELASTIC_VISCOPLASTIC
- 277 - *MAT_ADHESIVE_CURING_VISCOELASTIC
- 278 - *MAT_CF_MICROMECHANICS
- 279 - *MAT_COHESIVE_PAPER
- 280 - *MAT_GLASS
- 293 - *MAT_COMPRF
- B01 - *MAT_SEATBELT
- S1 - *MAT_SPRING_ELASTIC
- S2 - *MAT_DAMPER_VISCOUS
- S3 - *MAT_SPRING_ELASTOPLASTIC
- S4 - *MAT_SPRING_NONLINEAR_ELASTIC
- S5 - *MAT_DAMPER_NONLINEAR_VISCOUS
- S6 - *MAT_SPRING_GENERAL_NONLINEAR
- S7 - *MAT_SPRING_MAXWELL
- S8 - *MAT_SPRING_INELASTIC
- SPH_01 - *MAT_SPH_VISCOUS
- T1 - *MAT_THERMAL_ISOTROPIC
- T10- *MAT_THERMAL_ISOTROPIC_TD_LC
- T2 - *MAT_THERMAL_ORTHOTROPIC
- U1 - *MAT_UNSUPPORTED
MADYMO
- ACTUATOR
- AIRBAG_CHAMBER
- AMPLIFICATION.ABS_POLY
- AMPLIFICATION.EXP
- AMPLIFICATION.LOG
- AMPLIFICATION.POLY
- ANIMATION
- BELT
- BELT_FUSE
- BELT_RETRACTOR
- BELT_SEGMENT
- BELT_TYING
- BODY.DEFORMABLE
- BODY.FLEXIBLE_BEAM
- BODY.RIGID
- CHAR_MOD
- CHARACTERISTIC.CONTACT
- CHARACTERISTIC.LOAD
- CHARACTERISTIC.MATERIAL
- COMP_SIX_DOF
- COMPONENT
- CONNECT_N2
- CONNECT_N3
- CONSTRAINT.LINEAR
- CONSTRAINT.RIGID_FE
- CONSTRAINT.SIMPLE
- CONTACT_EVALUATE
- CONTACT.FE_FE
- CONTACT_FORCE
- CONTACT.MB_FE
- CONTACT.MB_MB
- CONTROL_AIRBAG
- CONTROL_ALLOCATION
- CONTROL_ANALYSIS
- CONTROL_FE_MODEL
- CONTROL_FE_TIME_STEP
- CONTROL_IMM
- CONTROL_OUTPUT
- CONTROL_SYSTEM
- CONTROLLER
- COORDINATE.CARTESIAN
- COORDINATE_REF.CARTESIAN
- COUPLING_BODY
- COUPLING_SURFACE
- DAMAGE
- ELEMENT.MASS1
- EQUATION.MASTER
- EQUATION.SLAVE
- FE_CRDSYS
- FE_MODEL
- FUNC_MOD
- FUNCTION.XY
- GAS
- GAS_FLOW_GRID
- GAS_MIXTURE
- GAS_MIXTURE_VARIABLE
- GROUP_FE
- GROUP_MB
- HOLE
- HOLE_AREA
- HOLE_SUBSEGMENT
- INFLATOR
- INFLATOR.CHAR
- INFLATOR.DEF
- INFLATOR.REF
- INJURY
- JET
- JOINT
- LAYER
- LOAD
- MADYMO
- MATERIAL.ANISO
- MATERIAL.FABRIC
- MATERIAL.FOAM
- MATERIAL.HOLE
- MATERIAL.HONEYCOMB
- MATERIAL.HONEYCOMB_PLASTIC
- MATERIAL.HYSISO
- MATERIAL.INTERFACE
- MATERIAL.ISOLIN
- MATERIAL ISOLIN
- MATERIAL ISOPLA
- MATERIAL.KELVIN1D
- MATERIAL.KELVIN1D_NL
- MATERIAL.KELVIN3D
- MATERIAL KELVIN3D_NL
- MATERIAL LINVIS
- MATERIAL MOONRIV
- MATERIAL NULL
- MATERIAL ORTHOLIN
- MATERIAL ORTHOLIN_LAYERED
- MATERIAL ORTHOPLA
- MATERIAL RIGID
- MATERIAL SANDWICH
- MATERIAL STRAP
- MATERIAL TONER
- MATERIAL USER
- MATERIAL.VISCO_NL
- MODE
- MODE_SHAPE
- MOTION.NODE
- MOTION_STRUCT_FE
- OPERATOR
- ORIENTATION.MATRIX
- ORIENTATION.SCREW_AXIS
- ORIENTATION.SUCCESSIVE_ROT
- ORIENTATION.VECTOR
- OUTPUT_AIRBAG_CHAMBER
- OUTPUT_ANIMATION
- OUTPUT_BELT
- OUTPUT_BODY
- OUTPUT_BODY_REL
- OUTPUT_CONTACT
- OUTPUT_CONTROL_SYSTEM
- OUTPUT_CROSS_SECTION
- OUTPUT_ELEMENT
- OUTPUT_ELEMENT_INITIAL
- OUTPUT_ENERGY_FE_MODEL
- OUTPUT_JET
- OUTPUT_JOINT_CONSTRAINT
- OUTPUT_JOINT_DOF
- OUTPUT_MARKER
- OUTPUT_MOTION_STRUCT
- OUTPUT_NODE
- OUTPUT_NODE_INITIAL
- OUTPUT_RESTRAINT
- OUTPUT_SENSOR
- OUTPUT_SYSTEM_COG
- PART
- PERMEABILITY
- POINT_OBJECT
- POINT_OBJECT_1_MB
- POINT_OBJECT_2_MB
- POINT_OBJECT_FE
- POINT_OBJECT_1_FE
- POINT_OBJECT_2_FE
- PORT
- PRINT_MARKER
- PRINT_OUTPUT_FE
- PROPERTY.BEAM2_BOX
- PROPERTY.BEAM2_CIRCULAR
- PROPERTY.BEAM2_DISCRETE
- PROPERTY.BEAM2_GENERAL
- PROPERTY2.BEAM2_PIPE
- PROPERTY.BEAM2_RECTANGULAR
- PROPERTY.BEAM2_USER
- PROPERTY.FACET6
- PROPERTY.INTERFACE4
- PROPERTY.MEM3
- PROPERTY.MEM3_LAYERED
- PROPERTY.MEM3NL
- PROPERTY.MEM3NL_LAYERED
- PROPERTY.MEM4
- PROPERTY.MEM4NL
- PROPERTY.SHELL3
- PROPERTY.SHELL4
- PROPERTY.SHELL4_LAYERED
- PROPERTY.SHELL6
- PROPERTY.SOLID4
- PROPERTY.SOLID8
- PROPERTY.TRUSS2
- PROPERTY.USERL2
- PROPERTY.USERL3
- PROPERTY.USERP3
- PROPERTY.USERP4
- PROPERTY.USERV8
- RATE
- RESTRAINT.CARDAN
- RESTRAINT.JOINT
- RESTRAINT.KELVIN
- RESTRAINT.POINT
- RESTRAINT.SIX_DOF
- RESULT_ANIMATION_FE
- RIGID_ELEMENT
- RUNID
- SCALING
- SELECT
- SENSOR
- SIGNAL
- SPOTWELD.NODE_NODE
- SPOTWELD.THREE_NODE
- STATE
- STRAP
- SUPPORT
- SURFACE.CYLINDER
- SURFACE.PLANE
- SWITCH
- SYSTEM.MODEL
- SYSTEM.REF_SPACE
- TIME_HISTORY_CONTACT
- TIME_HISTORY_ENERGY
- TIME_HISTORY_FE
- TIME_HISTORY_MB
- TIME_HISTORY_SYSTEM
- USER_INT
Marc
- ALLPOINTS (CONTROL CARD)
- AUTOLOAD
- ASSUMED (ASSUMED STRAIN)
- AUTO INCREMENT
- Body 3D Deformable
- Body 3D Rigid
- CBUSH
- Constant Dilatation
- Contact Header
- Contact Table
- CONTACT_TYPE
- Disp_chang
- DIST_LOADS
- DIST LOADS (CONTROL CARD)
- E_1
- E_2
- E_3
- E_5
- E_6
- E_7
- E_9
- E_10
- E_11
- E_14
- E_18
- E_20
- E_21
- E_25
- E_26
- E_27
- E_28
- E_29
- E_32
- E_33
- E_34
- E_35
- E_38
- E_39
- E_45
- E_52
- E_53
- E_54
- E_55
- E_57
- E_58
- E_59
- E_60
- E_61
- E_63
- E_64
- E_66
- E_67
- E_68
- E_69
- E_70
- E_74
- E_75
- E_78
- E_80
- E_81
- E_82
- E_83
- E_84
- E_89
- E_95
- E_96
- E_98
- E_114
- E_115
- E_116
- E_117
- E_118
- E_119
- E_120
- E_124
- E_125
- E_126
- E_127
- E_128
- E_129
- E_130
- E_134
- E_138
- E_139
- E_140
- E_157
- E-195
- ELSTO
- FEATURE
- Finite
- Fixed_Acce
- Fixed_Disp
- Fixed_Pres
- FOLLOW FOR
- FOUNDATION
- Init_Disp
- INITIAL_vel
- LARGE DISP
- Marlow Material
- MASSES
- MAT_FOAM
- MAT_ISOTROPIC
- MAT_MOONEY
- MAT_OGDEN
- MAT_ORTHOTROPIC
- MOMENT
- MPC CHECK
- NO LIST
- OPTIMIZE
- ORIENTATION
- OSET
- PBUSH
- PLASTICITY
- POINT_LOAD
- POST
- PROP_GEOMETRY
- RBE
- RBE2
- RBE3
- SHELL SECT
- SIZING
- SOLVER
- SPRING
- SUMMARY
- TABLE
- TIE
- TITLE
- TYING
- tying100
- UPDATE
- VERSION
Nastran
- ACMODL
- AECOMP
- AECOMPL
- AEFACT
- AEFORCE
- AELIST
- AEPARM
- AERO
- AEROS
- AESTAT
- AESURF
- ASCRCE
- ASET
- ASET1
- AUTOSPC
- B2GG
- B2PP
- BCBODY
- BCBODY1
- BCDPRP
- BCONECT
- BCONPRG
- BCONPRP
- BCPARA
- BCPROP
- BCTABLE
- BCTABL1
- BCTSET
- BEGIN BULK
- BMFACE
- BNDFREE1
- BNDFX1
- BOLT
- BOLTFOR
- BSET1
- BSURF
- BSURFS
- BULK-UNSUPPORTED_CARD
- CAABSF
- CACINF3
- CACINF4
- CAERO1
- CAERO2
- CASE-UNSUPPORTED CARD
- CBAR
- CBEAM
- CBEND
- CBUSH
- CBUSH1D
- CDAMP1
- CDAMP2
- CDAMP3
- CDAMP4
- CELAS1
- CELAS2
- CELAS3
- CELAS4
- CEND
- CFAST
- CGAP
- CHACAB
- CHBDYE
- CHBDYP
- CHEXA (20-noded)
- CHEXA (8-noded)
- CMASS1
- CMASS2
- CMASS3
- CMASS4
- CONM1
- CONM2
- CONROD
- CONVECTION
- CORD1C
- CORD1R
- CORD1S
- CORD2C
- CORD2R
- CORD2S
- CPENTA (6-noded)
- CPENTA (15-noded)
- CQUAD4
- CQUAD8
- CQUADR
- CQUADX
- CROD
- CSET1
- CSHEAR
- CSUPER
- CSUPEXT
- CTETRA (4-noded)
- CTETRA (10-noded)
- CTRIA3
- CTRIA6
- CTRIAX
- CTRIAX6
- CTRIAR
- CTUBE
- CVISC
- CWELD
- DAMPING
- DAREA
- DCONADD
- DCONSTR
- DDVAL
- DEFORM
- DELAY
- DEQATN
- DESGLB
- DESOBJ
- DESSUB
- DESVAR
- DIAG
- DLINK
- DLINK2
- DLOAD
- DOPTPRM
- DPHASE
- DRESP1
- DRESP2
- DSCREEN
- DTABLE
- DTISPECSEL
- DVCREL1
- DVCREL2
- DVMREL1
- DVMREL2
- DVPREL1
- DVPREL2
- ECHO
- EIGB
- EIGC
- EIGP
- EIGR
- EIGRL
- ELIST
- ENDDATA
- ERP
- ERPPNL
- EXEC_UNSUPPORTED_CARDS
- FLFACT
- FLSPOUT
- FLUTTER
- FLUX
- FORCE
- FREQ
- FREQ1
- FREQ2
- FREQ3
- FREQ4
- FREQ5
- GENEL
- GLOBAL
- GLOBAL CASE CONTROL
- GLOBAL OUTPUT REQUEST
- GRAV
- GRDSET
- GRID
- GUST
- HM_ELAS
- HM_SPRING
- HYBDAMP
- ID
- INCLUDE BULK
- INCLUDE_CTRL
- INCLUDE_EXEC
- K2GG
- K2PP
- LOAD
- LOADSEQ
- M2GG
- MARCOUT
- MAT1
- MAT2
- MAT4
- MAT5
- MAT8
- MAT9
- MAT10
- MATEP
- MATG
- MATHE
- MATHP
- MATS1
- MATT1
- MATT4
- MAXLINES
- MAXMIN
- MBOLT
- MBOLTUS
- MFLUID
- MINMAX
- MKAERO1
- MOMENT
- MONDSP1
- MONPNT
- MONPNT1
- MONPNT2
- MONPNT3
- MPC
- MPCADD
- NLAUTO
- NLDAMP
- NLMOPTS
- NLPARM
- NLRGAP
- NLSTEP
- NLSTRAT
- NOLIN1
- NSMADD
- NSM1
- NSML1
- NTHICK
- OMIT1
- OMIT_BEGIN_BULK
- OMIT_CEND
- OMIT_END_BULK
- P2G
- PAABSF
- PACABS
- PACBAR
- PACINF
- PAERO1
- PAERO2
- PANEL
- PARAM
- PAXSYMH
- PBAR
- PBARL
- PBEAM
- PBEAML
- PBEND
- PBUSH
- PBUSH1D
- PBUSHT
- PCOMP
- PCOMPG
- PCONV
- PCONVM
- PDAMP
- PELAS
- PELAST
- PFAST
- PGAP
- PHBDY
- PLPLANE
- PLOAD
- PLOAD1
- PLOAD2
- PLOAD4
- PLOTEL
- PLSOLID
- PMASS
- PROD
- PSEAM
- PSHEAR
- PSHELL
- PSHLN1
- PSOLID
- PRESSURE
- PTUBE
- PVISC
- PWELD
- QBDY1
- QSET1
- QVOL
- RADCAV
- RADIATION
- RADM
- RADSET
- RANDPS
- RBAR
- RBE2
- RBE3
- RESTART
- RESVEC
- RFORCE
- RIGID
- RJOINT
- RLOAD1
- RLOAD2
- ROTORG
- RROD
- RSPEC
- RSPINR
- RSPINT
- SEBNDRY
- SEBSET1
- SECSET1
- SEQSET1
- SESET
- SET
- SET (Control Card)
- SET1
- SET3
- SEUSET1
- SNORM
- SOL
- SPC
- SPC1
- SPCADD
- SPCD
- SPCR
- SPBLND1
- SPBLND2
- SPLINE1
- SPLINE2
- SPLINE4
- SPLINE5
- SPLINE6
- SPLINE7
- SPLINRB
- SPRELAX
- SPOINT
- SUBCASE
- SUBCOM
- SUBSEQ
- SUBTITLE
- SUPORT
- SUPORT1
- SWLDPRM
- TABDMP1
- TABLED1
- TABLED2
- TABLED3
- TABLED4
- TABLEM1
- TABLEM2
- TABLEM3
- TABLEM4
- TABLES1
- TABLEST
- TABRND1
- TEMP
- TEMPBC
- TEMPD
- TIC
- TIME
- TITLE
- TLOAD1
- TLOAD2
- TRIM
- TSTEP
- TSTEPNL (Load Collector)
- TSTEPNL (Control Card)
- USET
- USET1
- UXVEC
- VIEW
- VIEW3D
OptiStruct
- ACCELERATION
- ACCLR
- ACMODL
- ACSRCE
- ANALYSIS
- ASET
- ASET1
- ASSIGN
- AUTOSPC
- B2GG
- BASELIN
- BMFACE
- BORE
- CAABSF
- CAALOAD
- CBAR
- CBEAM
- CBUSH
- CBUSH1D
- CDAMP1
- CDAMP2
- CDAMP3
- CDAMP4
- CDSMETH
- CELAS1
- CELAS2
- CELAS3
- CELAS4
- CFAST
- CGAP
- CGAPG
- CGASK6
- CGASK8
- CGASK12
- CGASK16
- CHACAB
- CHBDYE
- CHECK
- CHEXA (8-noded)
- CHEXA (20-noded)
- CMASS1
- CMASS2
- CMASS3
- CMASS4
- CMBEAM
- CMBUSH
- CMBUSHC
- CMBUSHE
- CMBUSHT
- CMSMETH
- CMSPDP
- CMSPDPC
- CMSPDPE
- CMSPDPT
- CNTSTB
- CONM1
- CONM2
- CONROD
- CONTACT
- CONTF
- CONTPRM
- CONV
- CORD1C
- CORD1R
- CORD1S
- CORD2C
- CORD2R
- CORD2S
- CORD3R
- CORD4R
- CPENTA (6-noded)
- CPENTA (15-noded)
- CPYRA (5-noded)
- CPYRA (13-noded)
- CQAXI
- CQUADR
- CQUAD4
- CQUAD8
- CROD
- CSHEAR
- CSTRAIN
- CSTRESS
- CSUPER
- CSUPEXT
- CTAXI
- CTETRA (4-noded)
- CTETRA (10-noded)
- CTRIAR
- CTRIAX6
- CTRIA3
- CTRIA6
- CTUBE
- CVISC
- CWELD
- DAMAGE
- DAREA
- DCOMP
- DCONADD
- DCONSTR
- DDVAL
- DEBUG
- DEFORM
- DENSITY
- DENSRES
- DEQATN
- DESGLB
- DESHIS
- DESOBJ
- DESSUB
- DESVAR
- DESVARG
- DGLOBAL
- DISPLACEMENT
- DLINK
- DLINK2
- DLOAD
- DMIGNAME
- DMIGROT (Control Card)
- DOBJREF
- DOPTPRM
- DPENTA6
- DQUAD4
- DRESP1
- DRESP2
- DRESP3
- DSCREEN
- DSHAPE
- DSHUFFLE
- DSIZE
- DSYSID
- DTABLE
- DTETRA4
- DTI_SPECSEL
- DTI_UNITS
- DTPG
- DTPL
- DTRIA3
- DVCREL1
- DVCREL2
- DVGRID
- DVMREL1
- DVMREL2
- DVPREL1
- DVPREL2
- ECHO
- EIGC
- EIGRA
- EIGRD
- EIGRL
- EIGVNAME
- EIGVRETRIEVE
- EIGVSAVE
- EL2PROP
- ELFORCE
- ELIST
- ENERGY
- ERP
- ERPPNL
- ESE
- EXCLUDE
- FATDEF
- FATEVNT
- FATLOAD
- FATPARM
- FATSEQ
- FLLWER
- FLUX
- FORCE
- FORCE1
- FORMAT
- FREQ
- FREQ1
- FREQ2
- FREQ3
- FREQ4
- FREQ5
- FREQUENCY
- FSI
- GAPPRM
- GLOBAL_CASE_CONTROL
- GLOBSUB
- GPFORCE
- GPSTRAIN
- GPSTRESS
- GRAV
- GRDSET
- GRID
- GROUND
- HISOUT
- HM_ELAS
- HMSPRING
- HYBDAMP
- IC
- INCLUDE_BULK
- INCLUDE_CTRL
- INFILE
- INVEL
- INVELB
- JOINT
- K2GG
- K2PP
- K42GG
- LABEL
- LIFE
- LOAD
- LOADJG
- LOADLIB
- M2GG
- MARKER
- MAT1
- MAT2
- MAT3
- MAT4
- MAT5
- MAT8
- MAT9
- MAT9ORT
- MAT10
- MATFAT
- MATF1
- MATF2
- MATF8
- MATF9
- MATF10
- MATHE
- MATPE1
- MATS1
- MATT1
- MATT2
- MATT4
- MATT5
- MATT8
- MATT9
- MATX02
- MATX13
- MATX27
- MATX33
- MATX36
- MATX42
- MATX44
- MATX62
- MATX65
- MATX70
- MATX82
- MBACT
- MBCNTDS
- MBCNTR
- MBCRV
- MBDCRV
- MBDEACT
- MBDSRF
- MBFORCE
- MBFRC
- MBFRCC
- MBLIN
- MBMNT
- MBMNTC
- MBPCRV
- MBREQ
- MBREQE
- MBREQM
- MBSEQ
- MBSIM
- MBSIMP
- MBVAR
- METHOD
- MGASK
- MFLUID
- MINMAX
- MLOAD
- MODEL
- MODEWEIGHT
- MOMENT
- MOMENT1
- MOTION
- MOTNG
- MOTNGC
- MPC
- MPCADD
- MPCFORCE
- MPCFORCES
- MSGLMT
- NESLEXPD
- NESLIMPD
- NESLNLGM
- NLADAPT
- NLENRG
- NLOAD (Constraint Load)
- NLOAD (Case Control)
- NLOAD1
- NLOUT
- NLPARM
- NLPARMX
- NLPRINT
- NOLIN2
- NOLIN3
- NOLIN4
- NSM (Global Case Control Card)
- NSMADD
- NSM1
- NSML1
- OFREQUENCY
- OLOAD
- OMODES
- OSDIAG
- OTIME
- OUTFILE
- OUTPUT
- P2G
- PAABSF
- PACABS
- PANEL
- PANELG
- PARAM
- PAXI
- PBAR
- PBARL
- PBEAM
- PBEAML
- PBUSH
- PBUSH1D
- PCOMP
- PCOMPG
- PCOMPP
- PCONT
- PCONTX
- PDAMP
- PEAKOUT (Control Card)
- PEAKOUT (Load Collector)
- PELAS
- PFAST
- PFAT
- PFBODY
- PFGRID
- PFMODE
- PFPANEL
- PFPATH
- PGAP
- PGASK
- PJOINTG
- PLOAD
- PLOAD1
- PLOAD2
- PLOAD4
- PLOTEL
- PLOTEL3
- PLOTEL4
- PLY
- PMASS
- PRBODY
- PRESSURE
- PROD
- PROPERTY
- PSHEAR
- PSHELL
- PSOLID
- PTADD
- PTUBE
- PVISC
- PWELD
- QBDY1
- QVOL
- RANDPS
- RBAR
- RBE2
- RBE3
- REQUEST
- RESPRINT
- RESTART
- RESULTANT
- RESULTS
- RESVEC
- RFORCE
- RGYRO
- RLOAD1
- RLOAD2
- ROTORG
- RROD
- RSPEC
- RSPEC (Case Control)
- RSPEED
- RSPINR
- RSPINT
- RWALL (Group)
- RWALL (Case Control)
- RWALLADD
- SCREEN
- SDAMPING
- SEALL (Global Case Control)
- SEBSET1
- SECSET1
- SECT
- SEDR (Case Control)
- SENSITIVITY
- SENSOUT
- SEQSET1
- SESET
- SET
- SET3
- SHAPE
- SHAPEOPT
- SHRES
- SOLVTYP
- SPC
- SPCADD
- SPCD
- SPCFORCES
- SPOINT
- STACK
- STATSUB
- STRAIN
- STRESS
- SUBCASE
- SUBCOM
- SUBMODEL
- SUBSEQ
- SUBTITLE
- SUPER (Case Control)
- SUPORT
- SUPORT1
- SURF
- SWLDPRM
- SYSSETTING
- TABDMP1
- TABFAT
- TABLED1
- TABLED2
- TABLED3
- TABLED4
- TABLEFAT
- TABLEG
- TABLEM1
- TABLEM2
- TABLEM3
- TABLEM4
- TABLEMD
- TABLES1
- TABLEST
- TABRND1
- TEMP
- TEMPD
- THERMAL
- THICKNESS
- THIN
- TIC
- TICA
- TIE
- TITLE
- TLOAD1
- TLOAD2
- TMPDIR
- TOTALFORCE
- TSTEP
- TSTEPNL
- TSTEPNX
- TTERM
- UNBALNC
- UNITS
- USET
- USET1
- VELOCITY
- WEIGHT
- XDAMP
- XHIST (Output Block)
- XHIST (Case Control)
- XHISTADD
- XSHLPRM
- XSOLPRM
- XSTEP (Load Collector)
PAM-CRASH 2G
- ACC3D/
- ACFLD/
- ACTUA/
- AIRBAGCHECK
- ANALYSIS
- AUTOSLEEP
- BAGIN/
- BAR/
- BDFOR/
- BDFOR / AFIELD
- BDFOR / INPRES
- BDFOR / VOLUME
- BDFOR / RADIAL
- BDFOR / ROTACC
- BDFOR / PRSTRS
- BDFOR / PRFORC
- BDFOR / PREND
- BEAM/
- BELTS/
- BOUNC/
- BSHEL/
- CCTRL/
- CDATA/
- CHAMBER
- CHEM/
- CKCTRL/
- CNODE/
- CNTAC/
- CNTAC / NTYPE = 1
- CNTAC / NTYPE = 10
- CNTAC / NTYPE = 21
- CNTAC / NTYPE = 33
- CNTAC / NTYPE = 34
- CNTAC / NTYPE = 36
- CNTAC / NTYPE = 37
- CNTAC / NTYPE = 43
- CNTAC / NTYPE = 44
- CNTAC / NTYPE = 46
- CNTAC / NTYPE = 54
- CNTAC / NTYPE = 61
- CNTAC / NTYPE = 154
- CNTPTY/
- CONLO/
- DAMP/
- DAMP / SENSOR
- DAMP / TIDAMP
- DATACHECK
- DCOMP
- DEBUG
- DELEM/
- DIS3D/
- DIS3DM/
- DIS3DX/
- DMPEW
- DRAPF/
- DRAPP
- ECTRL/
- EIGEN/
- ELINK/
- ENDDATA
- EOCTRL/
- EXPORT/
- FILE
- FPCTRL/
- FPM
- FRAME/
- FRAME/ IAXIS = 0 (rectangular)
- FRAME/ IAXIS = 1 (rectangular)
- FRAME/ IAXIS = 2 (rectangular)
- FRAME/ IAXIS = 3 (rectangular)
- FRAME/ IAXIS = 4 (cylindrical)
- FRAME/ IAXIS = 5 (spherical)
- FRICT/
- FRICT / IFROPT = 1
- FRICT / IFROPT = 2
- FRICT / IFROPT = 3
- FRICT / IFROPT = 4
- FRICT / IFROPT = 5
- FRICT / IFROPT = 6
- FRICT / IFROPT = 10
- FRICT / IFROPT = 11
- FRICT / IFROPT = 12
- FRICT / IFROPT = 13
- FUNCT/
- FUNCSW/
- GASPEC/
- GES/KEYWORD = OGRP
- GROUP/
- HEAT/
- ICTRL/
- IMPFIL/
- IMPORT/
- INCLU/
- INFLATOR
- INPUTVERSION
- INTEM/
- INVEL/
- JOINT/
- KJOIN/
- KJOIN / JTYP = SPHERICA
- KJOIN / JTYP = TRANSLAT
- KJOIN / JTYP = REVOLUTE
- KJOIN / JTYP = CYLINDRI
- KJOIN / JTYP = PLANAR
- KJOIN / JTYP = UNIVERSA
- KJOIN / JTYP = GENERAL
- KJOIN / JTYP = FLEX-TOR
- LAYER/
- LCTRL/
- LEAKAGE
- LINCO/
- LLINK/
- LOOKU /
- MACTRL
- MASS/
- MATER /
- MATER / MATYP = 1
- MATER / MATYP = 2
- MATER / MATYP = 5
- MATER / MATYP = 6
- MATER / MATYP = 7
- MATER / MATYP = 8
- MATER / MATYP = 12
- MATER / MATYP = 15
- MATER / MATYP = 16
- MATER / MATYP = 20
- MATER / MATYP = 22
- MATER / MATYP = 24
- MATER / MATYP = 26
- MATER / MATYP = 28
- MATER / MATYP = 30
- MATER / MATYP = 31
- MATER / MATYP = 35
- MATER / MATYP = 36
- MATER / MATYP = 37
- MATER / MATYP = 38
- MATER / MATYP = 41
- MATER / MATYP = 42
- MATER / MATYP = 45
- MATER / MATYP = 47
- MATER / MATYP = 51
- MATER / MATYP = 52
- MATER / MATYP = 61
- MATER / MATYP = 62
- MATER / MATYP = 71
- MATER / MATYP = 80
- MATER / MATYP = 81
- MATER / MATYP = 82
- MATER / MATYP = 83
- MATER / MATYP = 85
- MATER / MATYP = 99
- MATER / MATYP = 100
- MATER / MATYP = 101
- MATER / MATYP = 103
- MATER / MATYP = 105
- MATER / MATYP = 106
- MATER / MATYP = 107
- MATER / MATYP = 108
- MATER / MATYP = 109
- MATER / MATYP = 110
- MATER / MATYP = 115
- MATER / MATYP = 116
- MATER / MATYP = 117
- MATER / MATYP = 118
- MATER / MATYP = 121
- MATER / MATYP = 126
- MATER / MATYP = 127
- MATER / MATYP = 128
- MATER / MATYP = 131
- MATER / MATYP = 143
- MATER / MATYP = 150
- MATER / MATYP = 151
- MATER / MATYP = 161
- MATER / MATYP = 162
- MATER / MATYP = 171
- MATER / MATYP = 180
- MATER / MATYP = 181
- MATER / MATYP = 182
- MATER / MATYP = 183
- MATER / MATYP = 184
- MATER / MATYP = 185
- MATER / MATYP = 200
- MATER / MATYP = 201
- MATER / MATYP = 202
- MATER / MATYP = 204
- MATER / MATYP = 205
- MATER / MATYP = 212
- MATER / MATYP = 213
- MATER / MATYP = 214
- MATER / MATYP = 220
- MATER / MATYP = 221
- MATER / MATYP = 222
- MATER / MATYP = 223
- MATER / MATYP = 224
- MATER / MATYP = 225
- MATER / MATYP = 226
- MATER / MATYP = 230
- MATER / MATYP = 301
- MATER / MATYP = 302
- MATER / MATYP = 303
- MATER / MATYP = 304
- MATER / MATYP = 305
- MATER / MATYP = 306
- MATER / MATYP = 371
- MATER / MATYP = 380
- MAXMEMORY
- MBSYS/
- MBSYS / H_POINT
- MCTRL/
- MEMBR/
- MERGEGAP
- META
- METRIC/
- METRICCHECK
- MMAT /
- MPART /
- MPART / ATYPE = SHELL
- MPART / ATYPE = SOLID
- MSTRM/
- MTOCO/
- MTOCO / ITMTO = 0
- MTOCO / ITMTO = 1
- MTOJNT/
- NLAVE/
- NODE/
- NSMAS/
- NSMAS2/
- NUMPAR
- OCTRL/
- OPTLIS
- ORTHF/
- ORTHP
- OTMCO/
- PART/
- PART / ATYPE = SOLID
- PART / ATYPE = BSHEL
- PART / ATYPE = TETRA
- PART / ATYPE = SPHEL
- PART / ATYPE = COS3D
- PART / ATYPE = SHELL
- PART / ATYPE = TSHEL
- PART / ATYPE = MEMBR
- PART / ATYPE = BAR
- PART / ATYPE = BEAM
- PART / ATYPE = ELINK
- PART / ATYPE = GAP
- PART / ATYPE = JOINT
- PART / ATYPE = KJOIN
- PART / ATYPE = LLINK
- PART / ATYPE = MBKJN
- PART / ATYPE = MBSPR
- PART / ATYPE = MTOJNT
- PART / ATYPE = MUSCLE
- PART / ATYPE = PLINK
- PART / ATYPE = SLINK
- PART / ATYPE = SPRGBM
- PART / ATYPE = SPRING
- PART / ATYPE = TIED
- PENTA6/
- PFSURF/
- PFLOW/
- PICEXP/
- PICIMP/
- PLINK/
- PLY/
- PLY / ITYP = 0
- PLY / ITYP = 1, MATYP = 131
- PLY / ITYP = 1, MATYP = 30
- PLY / ITYP = 2, SIGMAy
- PLY / ITYP = 2, CURVE
- PLY / ITYP = 2, POWER
- PLY / ITYP = 2, KRUPK
- PLY / ITYP = 3, SIGMAy
- PLY / ITYP = 3, CURVE
- PLY / ITYP = 3, POWER
- PLY / ITYP = 3, KRUPK
- PLY / ITYP = 7
- PLY/ITYP = 10
- PLY/ITYP = 15
- PLY / ITYP = 8, MATYP = 131
- PLY / FAILINP = 1
- PLY / FAILINP = 1, FAILTYP = 0
- PLY / FAILINP = 1, FAILTYP = 1
- PLY / FAILINP = 1, FAILTYP = 2
- PLY / FAILINP = 1, FAILTYP = 3
- PLY / FAILINP = 1, FAILTYP = 4
- PLY / FAILINP = 1, FAILTYP = 5
- PLY / FAILINP = 1, FAILTYP = 6
- PLY / FAILINP = 1, FAILTYP = 7
- PLY / FAILINP = 1, FAILTYP = 8
- PLY / FAILINP = 1, FAILTYP = 9
- PLY / FAILINP = 1, FAILTYP = 10
- PLY / FAILINP = 1, FAILTYP = 11
- PRCTRL/
- PREBM/
- PREFA/
- PROFILE_DMP
- PYFUNC/
- PYVAR/
- RAC3D/
- RAN3D/
- RAN3DM/
- RAN3DX
- RBODY/
- RBODY / ITRB = 0
- RBODY / ITRB = 1
- RBODY / ITRB = 2
- RBODY / ITRB = 3
- RBODY / ITRB = 4
- RDA3D/
- RDD3D/
- RDV3D/
- RVE3D/
- REQUIRE_PRECISION
- REQUIRE_VERSION
- RESTARTFILES
- RETRA/
- RUNEND/
- RUPMO/
- RUPMO / IRUPT = 0
- RUPMO / IRUPT = 1
- RUPMO / IRUPT = 2
- RUPMO / IRUPT = 3
- RUPMO / IRUPT = 5
- RUPMO / IRUPT = 6
- RUPMO / IRUPT = 7
- RUPMO / IRUPT = 11
- RUPMO / IRUPT = 12
- RUPMO / IRUPT = 13
- RVE3D/
- SECFO/
- SECFO / NTYP = CONTACT
- SECFO / NTYP = LINK
- SECFO / NTYP = PLANE
- SECFO / NTYP = SECTION
- SECFO / NTYP = SUPPORT
- SECFO / NTYP = TIED_MS
- SECFO / NTYP = VOLFRAC
- SECFO / NTYP = CONT_MS
- SECFO / NTYP = DETECT
- SECURE/
- SECURE/ ENCRYTYP = MATER
- SECURE/ ENCRYTYP = MMAT
- SECURE/ ENCRYTYP = MPART
- SECURE/ ENCRYTYP = PLY
- SECURE/ ENCRYTYP = FUNCT
- SECURE/ ENCRYTYP = PART
- SECURE_NODE_VISU
- SELOUT
- SENPT/
- SENPTG/
- SENSOR/
- SENSOR/ ITYP = 1
- SENSOR/ ITYP = 2
- SENSOR/ ITYP = 3
- SENSOR/ ITYP = 4
- SENSOR/ ITYP = 5
- SENSOR/ ITYP = 6
- SENSOR/ ITYP = 7
- SENSOR/ ITYP = 8
- SENSOR/ ITYP = 9
- SENSOR/ ITYP = 10
- SENSOR/ ITYP = 11
- SENSOR/ ITYP = 12
- SENSOR/ ITYP = 13
- SENSOR/ ITYP = 14
- SHELL/
- SHELLCHECK
- SIGNAL
- SLINK/
- SLIPR/
- SOLID/
- SOLIDCHECK
- SOLVER
- SPCTRL/
- SPHEL/
- SPRGBM/
- SPRING/
- STOPRUN
- SUBDF/
- SUBRUN
- TCTRL/
- TEMBC/
- TETR4/
- TETR10/
- THELE/
- THLOC/
- THNOD/
- THNPO/
- TIED/
- TITLE/
- TRSFM/
- TRSSEQ/
- TSHEL/
- UNIT
- VEL3D/
Permas
- $ADDMODES
- $BEAM2
- $BECOC
- BECOP
- $BECOS
- BETAC
- BETOP
- CA1ZERF3
- CA2ZERF1
- CA2ZERF3
- $COMPONENT
- $COMPRESS
- CONAX2
- CONAX3
- $CONA3
- $CONA4
- $CONA6
- $CONA8
- $CONDUCTIVITY - materials
- $CONDUCTIVITY - loads
- $CONLOAD
- $CONS3
- $CONS4
- $CONS6
- $CONS8
- $CONSTRAINTS
- $CONTACT
- CONTLOCK
- CONTROL6
- $CONTVAL
- $COOR
- $DAMP1
- $DAMP3
- $DAMP6
- $DAMPING
- $DENSITY
- $DIELECTRIC
- $DISLOAD
- $DISLOADN
- $ECHO
- $ELASTIC
- $ELCONDUCT
- $ELPROP
- $ELSYS
- $ENTER MATERIAL
- $ESET
- $ESETBIN
- EXTERNAL
- $FLA2
- $FLA3
- $FLDENS
- $FLHEX8
- $FLHEX20
- $FLPENT6
- $FLPENT15
- $FLPYR5
- $FLTET4
- $FLTET10
- $FLUID
- $FREQLOAD
- $FREQUENCY
- $FSINTA3
- $FSINTA4
- $FSINTA6
- $FSINTA8
- $FUNCTION
- $GASKET
- $GEODAT
- $GEODAT SPRINGX
- $GKHEX8
- $GKHEX20
- $GKPNT6
- $GKPNT15
- $GSKLOAD
- $GSKUNLOAD
- $HARDENING
- $HEATCAP
- $HEXE8
- $HEXE20
- $INERTIA
- $INERTIAX
- $INIVAL
- $JOIN
- $LAMINATE
- $LOADA3
- $LOADA4
- $LOADA6
- $LOADA8
- $LOADING
- $LOADS
- $MASS3
- $MASS6
- $MATERIAL
- $MODDAMP
- $MPC ASSIGN
- $MPC GENERAL
- MPC_IQUAD4
- MPC_IQUAD8
- MPC_IQUAD9
- $MPC ISURFACE
- MPC_ITRIA3
- MPC_ITRIA6
- $MPC JOIN
- $MPC_RIGID
- $MPC_SAME
- $MPC WLDSURFACE
- $MPC WLSCON
- $MPC WLSSURFACE
- $NLDAMP
- $NLDAMPR
- $NLSTIFF
- $NLSTIFFR
- $NSET
- $NSETBIN
- $PENTA15
- $PENTA6
- $PERMEABILITY
- $PLASTIC
- $PLOTA3
- $PLOTA4
- $PLOTA6
- $PLOTA8
- $PLOTL2
- $PLOTL3
- $PLY
- $POINTS
- $PRESCRIBE/PREVAL
- PRESSFIT
- $PRETENSION LOAD
- $PRETENSION PLANE
- $PRETENSION THREAD
- $PYRA5
- $QUAD4
- QUAD4S
- $QUAM4
- QUAM8
- QUAMS4
- QUAX4
- $REFSYS
- $RIGID
- $ROTB
- $RSYS
- $SAME
- $SFSET
- $SHEAR4
- $SHELL3
- $SHELL4
- $SITUATION
- $SPRING1
- $SPRING3
- $SPRING6
- SPRINGX1
- SPRINGX2
- SPRINGX3
- SUBCOMP
- SUBVAR
- $SUPPRESS
- $SURFABS
- $SURFACE
- $SYSTEM
- TEMP
- TEMPFILM
- $TET4
- $TET10
- $THERMEXP
- $TRANSLOAD
- $TRIA3
- TRIA3S
- $TRIA3K
- $TRIM3
- $TRIM6
- TRIMS3
- $TRIMS6
- TRIMX6
- $VOLDRAG
- $X1DAMP3
- $X1DAMP6
- $X1GEN6
- $X2GEN6
- $X1MASS3
- $X1MASS6
- $X1STIFF3
- $X1STIFF6
- $X2DAMP3
- $X2DAMP6
- $X2GEN6
- $X2STIFF3
- $X2STIFF6
- $YIELD
Samcef
Radioss
- Radioss Starter
- #include
- #RADIOSS Starter
- /ACCEL
- /ACTIV
- /ADMAS
- /ADMESH/GLOBAL
- /ADMESH/SET
- /ADMESH/STATE/SH3N
- /ADMESH/STATE/SHELL
- /ALE/BCS
- /ALE/CLOSE
- /ALE/GRID/DISP
- /ALE/GRID/DONEA
- /ALE/GRID/SPRING
- /ALE/GRID/STANDARD
- /ALE/GRID/ZERO
- /ALE/MAT
- /ALE/MUSCL
- /AMS
- /ANALY
- /ANIM/VERS
- /ARCH
- /BCS
- /BEAM
- /BEGIN
- /BOX
- /BRIC20
- /BRICK
- /CAA
- /CLOAD
- /CLUSTER
- /CNODE
- /CYL_JOINT
- /DAMP
- /DAMP/INTER
- /DEF_SHELL
- /DEF_SOLID
- /DEFAULT/INTER/TYPE11
- /DEFAULT/INTER/TYPE19
- /DEFAULT/INTER/TYPE2
- /DEFAULT/INTER/TYPE24
- /DEFAULT/INTER/TYPE7
- /DFS/DETCORD
- /DFS/DETLINE
- /DFS/DETPLAN
- /DFS/DETPOIN
- /DFS/DETPOIN/NODE
- /DFS/DETPLAN/NODE
- /DFS/DETLINE/NODE
- /DFS/LASER
- /DFS/WAV_SHA
- /DRAPE
- /END
- /EOS/GRUNEISEN
- /EOS/POLYNOMIAL
- /EOS/PUFF
- /EOS/SESAME
- /EOS/TILLOTSON
- /EOS/NOBEL-ABEL
- /EOS/LSZK
- /EOS/MURNAGHAN
- /EOS/IDEAL-GAS
- /EOS/OSBORNE
- /EOS/STIFF-GAS
- /EREF
- /EULER/MAT
- /FAIL/BIQUAD
- /FAIL/CHANG
- /FAIL/CONNECT
- /FAIL/EMC
- /FAIL/ENERGY
- /FAIL/FABRIC
- /FAIL/FLD
- /FAIL/HASHIN
- /FAIL/HC-DSSE
- /FAIL/ORTHSTRAIN
- /FAIL/JOHNSON
- /FAIL/LAD_DAMA
- /FAIL/NXT
- /FAIL/PUCK
- /FAIL/SNCONNECT
- /FAIL/SPALLING
- /FAIL/TAB1
- /FAIL/TBUTCHER
- /FAIL/TENSSTRAIN
- /FAIL/USERi
- /FAIL/WIERZBICKI
- /FAIL/WILKINS
- /FRAME/FIX
- /FRAME/MOV
- /FRAME/MOV2
- /FRAME/NOD
- /FUNCT
- /GAUGE
- /GAUGE/SPH
- /GRAV
- /GRBEAM
- /GRBRIC
- /GRNOD
- /GRPART
- /GRQUAD
- /GRSH3N
- /GRSHEL
- /GRSPRI
- /GRTRUS
- /HEAT/MAT
- /IMPACC
- /IMPDIS/FGEO
- /IMPDISP
- /IMPLICIT
- /IMPTEMP
- /IMPVEL
- /IMPVEL/FGEO
- /IMPVEL/LAGMUL
- /INIBRI
- /INIBRI/FILL
- /INICRACK
- /INIQUA/DENS
- /INIQUA/ENER
- /INIQUA/EPSP
- /INIQUA/STRESS
- /INISH3/AUX
- /INISH3/EPSP
- /INISH3/EPSP_F
- /INISH3/ORTH_LOC
- /INISH3/ORTHO
- /INISH3/STRA_F
- /INISH3/STRS_F
- /INISH3/STRS_F/GLOB
- /INISH3/THICK
- /INISHE/AUX
- /INISHE/EPSP
- /INISHE/EPSP_F
- /INISHE/FAIL
- /INISHE/ORTH_LOC
- /INISHE/ORTHO
- /INISHE/STRA_F
- /INISHE/STRS_F
- /INISHE/STRS_F/GLOB
- /INISHE/THICK
- /INISTA
- /INITEMP
- /INIVEL
- /INIVEL/AXIS
- /INIVOL
- /INTER/LAGMUL/TYPE7
- /INTER/SUB
- /INTER/TYPE1
- /INTER/TYPE10
- /INTER/TYPE11
- /INTER/TYPE12
- /INTER/TYPE14
- /INTER/TYPE15
- /INTER/TYPE18
- /INTER/TYPE19
- /INTER/TYPE2
- /INTER/TYPE20
- /INTER/TYPE21
- /INTER/TYPE22
- /INTER/TYPE23
- /INTER/TYPE24
- /INTER/TYPE25
- /INTER/TYPE3
- /INTER/TYPE5
- /INTER/TYPE6
- /INTER/TYPE7
- /INTER/TYPE8
- /INTER/TYPE9
- /IOFLAG
- /KEY
- /LEAK/MAT
- /LINE
- /LOAD/CETRI
- /LOAD/PFLUID
- /MAT/B-K-EPS
- /MAT/GAS
- /MAT/LAW0 (VOID)
- /MAT/LAW1 (ELAST)
- /MAT/LAW10 (DPRAG1)
- /MAT/LAW11 (BOUND)
- /MAT/LAW12 (3D_COMP)
- /MAT/LAW14 (COMPSO)
- /MAT/LAW15 (CHANG)
- /MAT/LAW16 (GRAY)
- /MAT/LAW18 (THERM)
- /MAT/LAW19 (FABRI)
- /MAT/LAW2 (PLAS_JOHNS)
- /MAT/LAW2 (PLAS_ZERIL)
- /MAT/LAW20 (BIMAT)
- /MAT/LAW21 (DPRAG)
- /MAT/LAW22 (DAMA)
- /MAT/LAW23 (PLAS_DAMA)
- /MAT/LAW24 (CONC)
- /MAT/LAW25 (COMPSH)
- /MAT/LAW3 (HYDRPLA)
- /MAT/LAW4 (HYD_JCOOK)
- /MAT/LAW5 (JWL)
- /MAT/LAW6 (HYDRO)
- /MAT/LAW6 (K-EPS)
- /MAT/LAW26 (SESAM)
- /MAT/LAW27 (PLAS_BRIT)
- /MAT/LAW28 (HONEYCOMB)
- /MAT/LAW32 (HILL)
- /MAT/LAW33 (FOAM_PLAS)
- /MAT/LAW34 (BOLTZMAN)
- /MAT/LAW35 (FOAM_VISC)
- /MAT/LAW36 (PLAS_TAB)
- /MAT/LAW37 (BIPHAS)
- /MAT/LAW38 (VISC_TAB)
- /MAT/LAW40 (KELVINMAX)
- /MAT/LAW41 (LEE-TARVER)
- /MAT/LAW42 (OGDEN)
- /MAT/LAW43 (HILL_TAB)
- /MAT/LAW44 (COWPER)
- /MAT/LAW46 (LES_FLUID)
- /MAT/LAW48 (ZHAO)
- /MAT/LAW49 (STEINB)
- /MAT/LAW50 (VISC_HONEY)
- /MAT/LAW51 (MULTIMAT)
- /MAT/LAW52 (GURSON)
- /MAT/LAW53 (TSAI_TAB)
- /MAT/LAW54 (PREDIT)
- /MAT/LAW57 (BARLAT3)
- /MAT/LAW58 (FABRI_A)
- /MAT/LAW59 (CONNECT)
- /MAT/LAW60 (PLAS_T3)
- /MAT/LAW62 (VISC_HYP)
- /MAT/LAW63 (HANSEL)
- /MAT/LAW64 (UGINE_ALZ)
- /MAT/LAW65 (ELASTOMER)
- /MAT/LAW66
- /MAT/LAW68 (COSSER)
- /MAT/LAW69
- /MAT/LAW70 (FOAM_TAB)
- /MAT/LAW71
- /MAT/LAW72 (HILL_MMC)
- /MAT/LAW73
- /MAT/LAW74
- /MAT/LAW75 (POROUS)
- /MAT/LAW76 (SAMP)
- /MAT/LAW77
- /MAT/LAW78
- /MAT/LAW79 (JOHN_HOLM)
- /MAT/LAW80
- /MAT/LAW81
- /MAT/LAW82
- /MAT/LAW83
- /MAT/LAW84
- /MAT/LAW87
- /MAT/LAW88
- /MAT/LAW90
- /MAT/LAW92
- /MAT/LAW93 (ORTH_HILL)
- /MAT/LAW94 (YEOH)
- /MAT/LAW95
- /MAT/LAW97 (/MAT/JWLB)
- /MAT/LAW100
- /MONVOL/AIRBAG1
- /MONVOL/AREA
- /MONVOL/COMMU1
- /MONVOL/FVMBAG1
- /MONVOL/GAS
- /MONVOL/PRES
- /MOVE_FUNCT
- /NODE
- /PARAMETER
- /PART
- /PENTA6
- /PLOAD
- /PLY
- /PROP/INJECT1
- /PROP/INJECT2
- /PROP/PCOMPP
- /PROP/TYPE0 (VOID)
- /PROP/TYPE1 (SHELL)
- /PROP/TYPE2 (TRUSS)
- /PROP/TYPE3 (BEAM)
- /PROP/TYPE4 (SPRING)
- /PROP/TYPE6 (SOL_ORTH)
- /PROP/TYPE8 (SPR_GENE)
- /PROP/TYPE9 (SH_ORTH)
- /PROP/TYPE10 (SH_COMP)
- /PROP/TYPE11 (SH_SANDW)
- /PROP/TYPE12 (SPR_PUL)
- /PROP/TYPE13 (SPR_BEAM)
- /PROP/TYPE14 (FLUID)
- /PROP/TYPE14 (SOLID)
- /PROP/TYPE15 (POROUS)
- /PROP/TYPE16 (SH_FABR)
- /PROP/TYPE17 (STACK)
- /PROP/TYPE18 (INT_BEAM)
- /PROP/TYPE19 (PLY)
- /PROP/TYPE20 (TSHELL)
- /PROP/TYPE21 (TSH_ORTH)
- /PROP/TYPE22 (TSH_COMP)
- /PROP/TYPE25 (SPR_AXI)
- /PROP/TYPE26 (SPR_TAB)
- /PROP/TYPE28 (NSTRAND)
- /PROP/TYPE32 (SPR_PRE)
- /PROP/TYPE33 (KJOINT)
- /PROP/TYPE34 (SPH)
- /PROP/TYPE36 (PREDIT)
- /PROP/TYPE43 (CONNECT)
- /PROP/TYPE44 (SPR_CRUS)
- /PROP/TYPE45 (KJOINT2)
- /PROP/TYPE46 (SPR_MUSCLE)
- /PROP/TYPE51
- /QUAD
- /RADIATION
- /RANDOM
- /RBE2
- /RBE3
- /RBODY
- /REFSTA
- /RLINK
- /RWALL
- /RWALL/THERM
- /SECT
- /SECT/CIRCLE
- /SECT/PARAL
- /SENSOR
- /SH3N
- /SHELL
- /SKEW/FIX
- /SKEW/MOV
- /SKEW/MOV2
- /SPH/INOUT
- /SPH/RESERVE
- /SPHBCS
- /SPHCEL
- /SPHGLO
- /SPMD
- /SPRING
- /STACK
- /STAMPING
- //SUBMODEL
- /SUBSET
- /SURF/BOX
- /SURF/DSURF
- /SURF/GRBRIC/EXT
- /SURF/GRBRIC/FREE
- /SURF/GRSH3N
- /SURF/GRSHEL
- /SURF/MAT
- /SURF/MAT/ALL
- /SURF/MAT/EXT
- /SURF/PART
- /SURF/PART/ALL
- /SURF/PART/EXT
- /SURF/PLANE
- /SURF/PROP
- /SURF/PROP/ALL
- /SURF/PROP/EXT
- /SURF/SEG
- /SURF/SUBMODEL
- /SURF/SUBSET
- /SURF/SUBSET/ALL
- /SURF/SUBSET/EXT
- /SURF/SURF
- /TABLE
- /TETRA4
- /TETRA10
- /TH/ACCEL
- /TH/BEAM
- /TH/BRIC
- /TH/CLUSTER
- /TH/CYL_JO
- /TH/FRAME
- /TH/GAUGE
- /TH/INTER
- /TH/MONVOL
- /TH/NODE
- /TH/NSTRAND
- /TH/PART
- /TH/QUAD
- /TH/RBODY
- /TH/RWALL
- /TH/SECTIO
- /TH/SH3N
- /TH/SHEL
- /TH/SPHCEL
- /TH/SPRING
- /TH/SUBS
- /TH/SURF
- /TH/TRUSS
- /THERM_STRESS/MAT
- /TITLE
- /TRANSFORM/MATRIX
- /TRANSFORM/ROT
- /TRANSFORM/SCA
- /TRANSFORM/SYM
- /TRANSFORM/TRA
- /TRUSS
- /UPWIND
- /VISC/PRONY
- /XELEM
- /XREF
- Radioss Engine
- /@TFILE
- /@TFILE/Keyword2
- /ABF
- /ALE/GRID/DISP
- /ALE/GRID/DONEA
- /ALE/GRID/SPRING
- /ALE/GRID/ZERO
- /ALE/SPRING
- /ALE/STANDARD
- /ALE/ZERO
- /ALESUB
- /ANIM/BRICK/DAMA
- /ANIM/BRICK/TDEL
- /ANIM/BRICK/TDET
- /ANIM/BRICK/TENS
- /ANIM/BRICK/TENS/STRAIN
- /ANIM/BRICK/TENS/STRESS
- /ANIM/BRICK/VDAM
- /ANIM/CUT/1
- /ANIM/CUT/2
- /ANIM/CUT/3
- /ANIM/DT
- /ANIM/Eltyp/FORCE
- /ANIM/Eltyp/Restype
- /ANIM/ELEM/TDET
- /ANIM/QUAD/TDET
- /ANIM/ELEM/EINT
- /ANIM/GPS/TENS
- /ANIM/GPS1
- /ANIM/GPS2
- /ANIM/GZIP
- /ANIM/LSENSOR
- /ANIM/MASS
- /ANIM/MAT
- /ANIM/NODA
- /ANIM/SHELL/DAMA
- /ANIM/SHELL/EPSP
- /ANIM/SHELL/NXTFACTOR
- /ANIM/SHELL/PHI
- /ANIM/SHELL/SIG1H
- /ANIM/SHELL/SIG2H
- /ANIM/SHELL/TDEL
- /ANIM/SHELL/TENS
- /ANIM/SHELL/IDPLY
- /ANIM/SHELL/FLDZ
- /AMIN/SHELL/FLDF
- /ANIM/SENSOR
- /ANIM/TITLE
- /ANIM/VECT
- /ANIM/VERS
- /ATFILE
- /BCS/ALE
- /BCS/LAG
- /BCS/ROT
- /BCS/TRA
- /BCSR/ALE
- /BCSR/LAG
- /BCSR/ROT
- /BCSR/TRA
- /DAMP
- /DEL
- /DEL/Eltyp/1
- /DEL/INTER
- /DELINT
- /DT
- /DT/CST_AMS
- /DT/ALE
- /DT/AMS
- /DT/Eltyp/Iflag
- /DT/Eltyp/Keyword3/Iflag
- /DT/GLOB
- /DT/NODA/Keyword3
- /DT/SHELL
- /DT/SHNOD
- /DT/SPHCEL
- /DT/SPHCEL/Keyword3
- /DT/THERM
- /DT1/SHELL
- /DTIX
- /DTSDE
- /DYREL
- /DYREL/1
- /END/ENGINE
- /FVMBAG/MODIF
- /IMPL/AUTOSPC
- /IMPL/BUCKL/1
- /IMPL/BUCKL/2
- /IMPL/CHECK
- /IMPL/DIVERG/n
- /IMPL/DT/1
- /IMPL/DT/2
- /IMPL/DT/3
- /IMPL/DT/FIXPOINT
- /IMPL/DT/STOP
- /IMPL/DTINI
- /IMPL/DYNA/1
- /IMPL/DYNA/2
- /IMPL/DYNA/DAMP
- /IMPL/DYNA/FSI
- /IMPL/GSTIF/OFF
- /IMPL/INTER/KCOMP
- /IMPL/INTER/KNONL
- /IMPL/LBFGS/L
- /IMPL/LINEAR
- /IMPL/LINEAR/INTER
- /IMPL/LSEARCH/n
- /IMPL/LSEARCH/OFF
- /IMPL/MONVOL/OFF
- /IMPL/NCYCLE/STOP
- /IMPL/NONLIN
- /IMPL/NONLIN/SMDISP
- /IMPL/NONLIN/SOLVINFO
- /IMPL/PREPAT
- /IMPL/PRINT/LINEAR
- /IMPL/PRINT/NONLIN
- /IMPL/PSTIF/OFF
- /IMPL/QSTAT
- /IMPL/QSTAT/DTSCAL
- /IMPL/QSTAT/MRIGM
- /IMPL/RREF/INTERF/n
- /IMPL/RREF/LIMIT
- /IMPL/RREF/OFF
- /IMPL/SBCS/MSGLV
- /IMPL/SBCS/ORDER
- /IMPL/SBCS/OUTCORE
- /IMPL/SHPOFF
- /IMPL/SHPON
- /IMPL/SINIT
- /IMPL/SOLVER
- /IMPL/SPRBACK
- /IMPL/SPRING
- /INCMP
- /INIV/ROT
- /INIV/ROT/Keyword3/1
- /INIV/TRA
- /INIV/TRA/Keyword3/1
- /INTER
- /KEREL
- /KEREL/1
- /KILL
- /MADYMO
- /MON
- /OUTP
- /OUTP/LSENSOR
- /PARITH
- /RAD2RAD/ON
- /RERUN
- /RBODY
- /RFILE
- /RFILE/n
- /RUN
- /RUN/Run Name/Run Number/Restart Letter
- /SHSUB
- /STATE/BRICK/AUX/FULL
- /STATE/BRICK/FAIL
- /STATE/BRICK/ORTHO
- /STATE/BRICK/STRAIN/FULL
- /STATE/BRICK/STRAIN/GLOBFULL
- /STATE/BRICK/STRES/FULL
- /STATE/BRICK/STRESS/GLOBFULL
- /STATE/DT
- /STATE/LSENSOR
- /STATE/NO_DEL
- /STATE/NODE/TEMP
- /STATE/SHELL/AUX/FULL
- /STATE/SHELL/EPSP/FULL
- /STATE/SHELL/FAIL
- /STATE/SHELL/ORTHL
- /STATE/SHELL/STRAIN/FULL
- /STATE/SHELL/STRESS/FULL
- /STATE/STR_FILE
- /STOP
- /STOP/LSENSOR
- /TFILE
- /TH/VERS
- /THERMAL
- /TITLE
- /UPWIND
- /UPWM/SUPG
- /UPWM/TG
- /VEL/ALE
- /VEL/ROT
- /VEL/TRA
- /VERS
