Create Beam Sections Based on a Cross Section of Entities
For more information on creating beam cross-section entities, see the HyperBeam Panel topic.
View new features for HyperWorks 2021.1.
Edit the Parameter and Criteria files and define mesh controls using the Mesh Controls Browser.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
Supported 1D elements.
Use the Beam Sections tool to create and edit standard beam sections, cross beam sections, and HyperBeam sketches.
Beamsection collectors collect and organize beamsections and are used in HyperBeam to organize 1D beam section data.
Beamsection entities store 1D beam cross-section data.
Create 1D mesh, align, orient, and offset elements, and release degrees of freedom.
Use the 1D Mesh: Review tool to plot area moments of inertia and stiffness.
Use the Section Property tool to update properties assigned to bar2 or rod elements (target) using a cross section on various entities as the source.
Use the Beam Stress tool to display a contour of stress distribution on a tessellation of a beam cross section.
A surface mesh or "shell mesh" represents model parts that are relatively two-dimensional, such as sheet metal or a hollow plastic cowl or case.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
HyperMesh composites modelings.
ON THIS PAGE
ON THIS PAGE
