The results post-processing workflow is now embedded in HyperMesh, and you can seamlessly process solver native results in HyperMesh. The File Loader is used to generate the new results entity.
Enables exploring the element force and moment results (internal loads) from solver result files (grid point forces)
for further component sizing/optimization tasks and also for component certification/margin calculation.
In Nastran, the F06 file contains information related either to the diagnostic of the model, analysis check up and results.
This tool enables you to parse a defined number of information blocks and store them as a HyperMesh table entity with a given name.
