HyperWorks
HyperWorks
2021.1
  1. Home
  2. Aerospace
  3. Result Tools
  4. Free Body Diagram (FBD)
    Calculate free-body forces, moments, displacements and rotation.
  5. FBD Trace Plot
    Display free-body forces and moments at each cross-section along a node path.
  6. Select a Loadcase
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021.1
HyperWorks
  • What's New
    View new features for HyperWorks 2021.1.
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
    HyperMesh composites modelings.
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
    • Assembly Tools
      Create an assembly structure from a .csv file definition.
    • Panel Tools
    • Beam Tools
    • Check Tools
    • Composite Tools
    • Load/BCs Tools
    • Connection Tools
    • Spatial ID Manager Tools
    • Display Tools
    • Export Tools
    • Report Tools
    • Result Tools
      • Results Processing Tools in HyperMesh
        The results post-processing workflow is now embedded in HyperMesh, and you can seamlessly process solver native results in HyperMesh. The File Loader is used to generate the new results entity.
      • Matrix Browser
        Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
      • Results Explorer
        Enables exploring the element force and moment results (internal loads) from solver result files (grid point forces) for further component sizing/optimization tasks and also for component certification/margin calculation.
      • Free Body Diagram (FBD)
        • FBD Forces
          Calculate the contribution of one or more elements to the force and moment equilibrium at desired nodes.
        • FBD Displacement
          Plot displacements and rotations at nodes.
        • FBD Cross Section
          Define a cross-section plane.
        • FBD Trace Plot
          • Create Free-Body Sections
          • Set Properties of the Selected FBD Section Group
          • Select a Loadcase
          • Trace Plot Visualization Options
            Define visualization options for the trace plot.
          • Display the Trace Plot for the Selected Loadcase
        • FBD Potato/VMT Plots
          Potato plots are used to build load envelopes. VMT plots are used to build tensile, shear and bending moment diagrams.
        • FBD Panel Plot
          Display normal and shear loads of panel structural members.
        • FBD Bar Plot
          Display forces and moments acting on beam and bar elements.
      • F06 Parser
        In Nastran, the F06 file contains information related either to the diagnostic of the model, analysis check up and results. This tool enables you to parse a defined number of information blocks and store them as a HyperMesh table entity with a given name.
      • Import and Check Ground Check Forces
      • Fringe Post-Processing Using Different Volume Averaging Methods
        Use this tool to evaluate for the selected elements the average value of the selected result type.
    • Set Tools
    • System Tools
    • Node Tools
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
View All Altair Simulation Help
HyperWorks
HyperWorks
2021.1
  1. Home
  2. Aerospace
  3. Result Tools
  5. FBD Trace Plot
  • What's New
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
Select a Loadcase
Select a loadcase for the trace plot.
