Export a Line Definition File
To export the trimmed line definition file as a text file from the Tracing panel.
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
From the Preferences menu, you can access the Options dialog.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
Use the Tracing tool to trace system, component, and node entities during animation.
