Use Add as Filter to Define Search Parameters
![](../../images/post_processing/results_browser_filter_example.png)
![](../../images/post_processing/results_browser_filter_example_unity.png)
The filter is added to the search field in the browser. If you add more than one filter type, it will be added to the search field, with the word AND.
![](../../images/post_processing/results_browser_filter_example2_unity.png)
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
Animation files are opened using the Load Model panel.
Use the Measure tool to measure various distances and angles between entities.
The Results Browser allows you to view the HyperView model structure while providing find, display, and editing control of entities.
Quickly display all entities of a specific type in the Results Browser.
The Results Browser contains several ways to filter results data to display specific entities in the browser.
The Local Display Controls affect the visual style of individual entities (such as shaded or wireframe).
Clicking the right mouse button on a folder or entity/item within the browser’s tree structure allows you to change a variety of options using the browser context-sensitive menu.
Use the Entity Editor section of the Results Browser to view and edit various entity conditions/properties.
Use the Parameters Browser to parameterize the contents of a session file or report template and automate a variety of analysis processes in Altair HyperWorks Desktop.
Entities can be selected using input collectors or the quick window selection method.
From the Preferences menu, you can access the Options dialog.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
