HyperWorks
HyperWorks
2021.1
  1. Home
  2. Results Data
  3. Create Entities
  4. Create Derived Results
    The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperView.
  5. HyperWorks Result Math
    A result manipulation library that enables user-defined data types to be added to a result, and transitions complex data manipulation tasks from HyperView to a reusable, modifiable set of libraries that focus solely on result processing tasks.
  6. Result Math Reference Guide
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021.1
HyperWorks
  • What's New
    View new features for HyperWorks 2021.1.
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
    HyperMesh composites modelings.
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
    • Working with Models
    • Animate and Visualize Results
    • Create Entities
      • Create Derived Results
        • Output Parameters
          The output parameters section of the Expression Builder allows you to define the data type label and output for the newly created result.
        • Operators
          The list of available operators is controlled by the template file selected when loading a model and result, and it can be modified by adding or removing <using /> statements in the template.
        • Table Selection
          Once an operator is selected, tables must be selected to form the input.
        • Default Arguments
        • Constant Value Arguments
          When an argument is passed as a constant, it is converted to a constant value table by the Expression Builder.
        • Additional Resources
          Additional resources can be attached to the analysis for the purpose of adding new tables.
        • Authoring Expressions
          The Expression Builder uses a Templex-like syntax to author Result Math XML commands.
        • HyperWorks Result Math
          • Results Browser
          • Result Math Templates
            Various Result Math templates are available whenever a model/result pair is loaded into HyperView.
          • Creating New Datatypes
          • Operator Library Reference
            Result Math operators are contained within a set of related functions organized by category or industry vertical known as libraries.
          • Error Handling
          • Known Limitations
          • Result Math Reference Guide
      • Derived Load Cases
        The Loadcase tool allows you to create a derived load case from other load cases, or from a combination of other load cases and simulation steps.
      • Systems
        Create your own user defined coordinate systems or select result coordinate systems.
      • FLD
        Use the FLD tool a plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and minor strain output results of a forming simulation.
      • CFD Post-Processing
        HyperView offers CFD post-processing capabilities for a large class of industrial applications.
      • Tracking
        Use the Tracking tool to track any entity during animation.
      • Sets
        Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
    • Query Data
    • Annotate Models
    • Transform Models
    • Overlay Images/Videos
    • Rendering Models
    • Additional Tools for Post-Processing
    • Profiles
    • Preferences Menu
      From the Preferences menu, you can access the Options dialog.
    • Display/Visualization Options
    • HyperView - Upfront Data Loader
      A new workflow emphasizing upfront data loading for standard crash post processing use cases.
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
View All Altair Simulation Help
HyperWorks
HyperWorks
2021.1
  1. Home
  2. Results Data
  3. Create Entities
  • What's New
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
See the Result Math Reference Guide for additional information.
