Add a Measure Group
Do one of the following:
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
Animation files are opened using the Load Model panel.
Use the Measure tool to measure various distances and angles between entities.
Learn more about measure Templex expressions in HyperView.
Measures can be defined on the nodes of a cross-section enabling a deeper analysis of the deformation of the section.
The Results Browser allows you to view the HyperView model structure while providing find, display, and editing control of entities.
Use the Parameters Browser to parameterize the contents of a session file or report template and automate a variety of analysis processes in Altair HyperWorks Desktop.
Entities can be selected using input collectors or the quick window selection method.
From the Preferences menu, you can access the Options dialog.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
Then, from the Measure panel, click Add under the Measure Groups list.
