View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
The Image Plane tool allows you to select and overlay images (such as company logos, watermarks, etc.) or videos in the graphics area for correlation and presentation purposes.
From the Preferences menu, you can access the Options dialog.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
