Extract summed node force/moments-Ansys
A script for ANSYS result files, which allows you to extract total summation of nodal force and moments for the nodes of the selected elements.
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
Use the Add Object tool to add a graphical representation as an object to a specific component (part) or modify an existing object.
Use the Deformed tool to specify parameters for deformation display.
Use the Collision Detection tool to perform collision interference checking.
Use the Systems Review dialog to review the orientations of various element systems (1D, 2D, or 3D), as well as material and ply systems.
The Mask panel allows you to mask elements, components, and systems to reduce the number of entities displayed on the screen. With fewer entities displayed on the screen, it is easier to pick the necessary elements or visualize important areas of a model.
Visual properties such as shading, color, and mesh lines can be assigned to entities using the Entity Attributes panel.
The Apply Style options dialog allows you to select and apply display attributes of the active model in the current window to all models available in the current window, the current page, all pages, or selected HyperView windows in the session.
The Extract Solver Deck Assemblies tool allows you to import a HyperMesh exported input deck and extract the HyperMesh commands HMNAME, HMCOLOR, and HMASSEM.
The Generate PSM for MADYMO function allows you to save analysis results of nodes as a PSM (Prescribed Structural Motion) file. Displacement results from any animation can be exported as a PSM file.
The RAD2NOISE dialog in the utilities page allows you to create an input file based on your inputs. This input file can be used to run the RAD2NOISE solver in batch mode.
Use the Synchronize Animation dialog to synchronize windows that contain animation results in different units and/or begin at different time steps.
The Contour Measure Curves dialog allows you to quickly plot contour measure curves.
The Tools menu Import option allows you to access sub-menu options and dialogs for plot styles, sets, and views.
The Tools menu Export option allows you to access sub-menu options and dialogs for iso surface, plot styles, sets, and views.
From the Preferences menu, you can access the Options dialog.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
