HyperWorks
HyperWorks
2021.1
  1. Home
  2. Results Data
  3. Animate and Visualize Results
  4. Contour
    Use the Contour tool to create contour plots of a model and graphically visualize the analysis results.
  5. Create and Manage Contour Plots
    Learn about creating and managing contour plots.
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021.1
HyperWorks
  • What's New
    View new features for HyperWorks 2021.1.
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
    HyperMesh composites modelings.
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
    • Working with Models
    • Animate and Visualize Results
      • Section Cut
        Use the Section Cut tool to cut planar or deformable sections through a model.
      • Contour
        • Create and Manage Contour Plots
          • Create a Contour Plot Based on Nodal Results
          • Create a Contour Plot Based on Elemental Results (Including Corner Results)
          • Change the Display Options
          • Manage the Legend Display
          • Overlay Result Display
          • Clear Contour
          • Create Plot Style
          • Control the Display of Iso Values
          • Select a Projection Rule
          • Query Results
        • Color Band Generation
          A contour plot generates color bands on the model, based on the values found in the results file.
        • Additional Comments
        • Layers
          Layers allow you to display a contour for a specified element layer when a layer definition is available for an element.
        • Value Filter
          The Value filter available in the Contour panel allows you to specify threshold criteria for processing results only in a specific range.
        • Composites Post-processing
          Composites post-processing is enhanced in HyperView with the reorganization of ply results as layers.
        • Cache Results
          After a contour plot has been applied in the Contour panel, the Cache feature will become active and allow you to add the currently active contour result to an internal cache.
        • Mid-side Node Elemental Results in Contour
          Mid-side nodes refers to the nodes in between the corner nodes of the 2nd order elements.
        • Post-process Abaqus Stress Results
        • Post-process Stress Results (solver independent)
      • Iso
        Use the Iso tool to display single iso values (iso surfaced for solids or iso line for shells) dependent on results data.
      • Vector
        Use the Vector tool to set options for a vector plot.
      • Tensor
        Use the Tensor tool to view tensor plots of stress and strain directions and magnitudes for various solvers from elemental values.
      • Edit Legend
        The Edit Legend dialog allows you to change the legend properties.
      • Graphical Editing of the Legend and Iso-slider
        You can edit the contour, vector, or tensor plot legend in the graphics area.
      • Complex Results
        Results in some analysis types come as complex numbers.
      • Computed Results
        A listing of results that are computed in HyperView.
      • Nodal Averaging of Elemental Results
        Nodal averaging of elemental results at a node refers to the average of all the element corner results passing through that node.
      • Averaging Options
        The averaging options allow you to limit the averaging of results to only a group of elements that are considered to be bound by same feature angle or face.
      • Multi-model Result Plotting
        HyperView allows for plotting (contour, iso, vector, or tensor) across multiple overlaid models.
      • Fatigue Manager
        The fatigue manager allows you to write stress and strain results from a finite element analysis to an external file that can be used to set up a fatigue analysis.
      • Fatigue Configuration File
        The fatigue configuration file is a user-defined external ASCII-file through which the data groups from results of static/modal/transient analysis of different solvers can be read.
    • Create Entities
    • Query Data
    • Annotate Models
    • Transform Models
    • Overlay Images/Videos
    • Rendering Models
    • Additional Tools for Post-Processing
    • Profiles
    • Preferences Menu
      From the Preferences menu, you can access the Options dialog.
    • Display/Visualization Options
    • HyperView - Upfront Data Loader
      A new workflow emphasizing upfront data loading for standard crash post processing use cases.
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
View All Altair Simulation Help
HyperWorks
HyperWorks
2021.1
  1. Home
  2. Results Data
  4. Contour
  • What's New
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
  • Clear Contour
  • Create Plot Style
  • Query Results
