HyperWorks
HyperWorks
2021.1
  1. Home
  2. Multibody Modeling
  3. Vehicle Modeling
  4. Tire Modeling
  5. User Written Tire and Road Models
    User Written Tire models are implemented as user subroutines that compute the tire forces and moments, and the user road model is implemented as a subroutine that computes the road height at a given point.
  6. Reading TeimOrbit Files
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021.1
HyperWorks
  • What's New
    View new features for HyperWorks 2021.1.
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
    HyperMesh composites modelings.
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
    • MotionView Overview
      MotionView is a general pre-processor for Multi-body Dynamics.
    • Model Browser
    • MotionView Ribbons
    • MotionView CAD Interfacing
    • Flexible Bodies
      MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
    • Preferences Menu
      From the Preferences menu, you can access the Options dialog.
    • Vehicle Modeling
      • Build and Analyze Models
      • Vehicle Libraries
      • Components Library
      • Leaf Spring Modeling
      • Road Modeling
      • Tire Modeling
        • Introduction to Tire Modeling
          Tires are critical elements to modeling a vehicle’s interaction with a road, with some tire models better suited to specific simulation domains.
        • Coordinate Systems and Output Requests
        • Multi-Threading and Tire Models
          Since computing tire forces and moments during a vehicle simulation is one of the most costly tasks, multi-threaded execution of tire models on a multi-core computer can substantially reduce the clock time for a simulation.
        • CDTire Modeling
          Altair HyperWorks integrates the Comfort and Durability family of tire models - CDTire - from Fraunhofer ITWM. As the name implies CDTire focuses on comfort and durability applications, however it also allows for handling analysis as well.
        • Fiala Tire
          The FIALA tire model serves as the first stepping stone in full vehicle simulation because it is simple enough to be comprehended completely by the MBD analyst. Furthermore, the forces and torques produced by the tire/road interaction use a series of physically meaningful parameters.
        • FTire Modeling
        • MF-Tyre/MF-SWIFT Modeling
          Altair HyperWorks integrates MF-Tyre and MF-SWIFT tire models from Siemens (branded by Siemens as Simcenter Tire).
        • PM Flex Tire
          This tire is a FE based flexible tire solution from Pratt Miller that can interact with EDEM particles representing soil, sand, gravel, and so on. The tire model requires a finite element modeling file (.bdf) and other associated files. The AutoTire entity in MotionView provides a utility to generate the required mesh files from a CAD file. The tire can then be transferred to EDEM through MotionView-EDEM coupling interface. PM-FlexTire software is available as an Altair Partner product under the Altair Units licensing system.
        • User Written Tire and Road Models
          • Writing Tire Models
          • Writing Road Models
          • About TeimOrbit Files
            TeimOrbit Files are ascii files that organize data into blocks, sub-blocks, tables, and parameters with a few simple rules.
          • Reading TeimOrbit Files
            • Open File
            • Close File
            • ATRTOU
            • Read Real
            • Read Integer
            • Read String
            • Read Table in a Block
            • Read Table Line
            • Read Spline in a Table
            • ACUNFN
            • Read Units Block
            • Units Block
            • Property File to MotionSolve Conversion Factors
            • Property File to SI Conversion Factors
            • Read Quoted String
            • Tire Subroutine Arguments
            • Utilities to Calculate Tire Kinematics, Forces, and Moments
      • Full Vehicle Events and Altair Driver
      • Road Tools
      • 1D Vehicle System Models
      • Update Model Utility
    • Tcl/Tk Reference Guide
      Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
    • MDL Reference Guide
    • MotionSolve Reference Guide
    • Templex and Math Reference Guide
    • MotionView Python Reference Guide
  • Media Files
  • Text Files
  • Tabulate Results
View All Altair Simulation Help
HyperWorks
HyperWorks
2021.1
  1. Home
  3. Vehicle Modeling
  4. Tire Modeling
  • What's New
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
MotionSolve provides the following functions for reading values from TeimOrbit files (click on the links below to learn more about each available function):
  • Open File
  • Close File
  • ATRTOU
  • Read Real
  • Read Integer
  • Read String
  • Read Table Line
  • ACUNFN
  • Read Units Block
  • Units Block
