Options Dialog - Mouse
The Options dialog, Mouse option allows you to customize mouse controls.
Figure 1. Options dialog - Mouse
See Tools Menu - Options - Mouse in the HyperView Online Help for a detailed explanation of mouse controls.
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences menu, you can access the Options dialog.
Various options for your model are set in the Options dialog.
Display options such as background color, foreground color, and mesh lines are set from the Options dialog.
Visualization options can be set using the Options dialog, Visualization option.
The Options dialog, Lighting option provides light sources for illuminating graphics.
The Check Model options allow you to select which information from the model file will be displayed when the Check Model
tool
is run.
The Options dialog, Build Model option allows you to set the standard include files and enable/disable the wizard related menu items in the menu bar.
The Options dialog, Path Management option allows you to set the file paths referenced by MDL entities as a relative or absolute path.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
